Problème de fonctionnement Sonde de Luminosité, Température et d’Humidité
Je rencontre un problème de fonctionnement de cette sonde qui actuellement n’affiche que la luminosité, pas de température ni d’humidité.
Voici l’équipement: Sonde Neo Coolcam (Tuya)
Ref: Modèle : TS0201 Fabricant : _TZ3000_qaaysllp Classe : zigpy.device
    "ieee": "84:71:27:ff:fe:fe:7f:eb",
    "nwk": 37716,
    "status": 2,
    "lqi": "136",
    "rssi": "-66",
    "last_seen": "1624456686.1974432",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 262,
            "profile_id": 260,
            "manufacturer": "_TZ3000_qaaysllp",
            "model": "TS0201",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 68
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_qaaysllp"
                            "id": 5,
                            "name": "model",
                            "value": "TS0201"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 1024,
                    "name": "Illuminance Measurement",
                    "attributes": [
                            "id": 0,
                            "name": "measured_value",
                            "value": 19543
                    "id": 57346,
                    "name": "Cluster",
                    "attributes": []
    "signature": {
        "model": "TS0201",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 262,
                "input_clusters": [
                    0,
                    1,
                    1024,
                    57346
                    25,
                    10
    "class": "zigpy.device"
Après de nombreuses lectures de poste sur ce forum je suis tombé sur ce poste qui indique que l’équipement a bien était intégré:
Ce qui est bien le cas, l’inclusion se passe sans aucun problème.
Serait-il possible d’avoir de l’aide ?
Hope for you is not as the one from moes that i Bought and send temp/ humidity sometimes only :frowning:
on your JSON (I didn’t see any temprature and humidity information)
You may try to remove it and reset the device and try again to reinclud eit. During the 30 s try to keep it active .
you may as well send log
Bonjour @lienrag35
J’ai bien constaté dans le JSON que je n’avais pas d’information pour la température et l’humidité.
Je viens de refaire une suppression avec réinitialisation et une nouvelle intégration, même résultat.
Caddddpture
Voici les logs:
[2021-06-23 19:21:34][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"15564","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:21:34][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 15564
[2021-06-23 19:21:38][DEBUG] : {"device_left":"84:71:27:ff:fe:fe:7f:eb"}
[2021-06-23 19:22:07][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2021-06-23 19:22:07][DEBUG] : null
[2021-06-23 19:22:07][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=0 type : GET
[2021-06-23 19:22:07][DEBUG] : {"with_attributes":0}
[2021-06-23 19:22:07][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2021-06-23 19:22:07][DEBUG] : [{"ieee":"80:4b:50:ff:fe:30:3b:77","nwk":"0x0000","lqi":255,"rssi":0,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[{"ieee":"84:2e:14:ff:fe:e5:77:10","nwk":"0x082a","lqi":139,"rssi":-66,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"RH3001","manufacturer":"TUYATEC-0l6xaqmi","offline":false,"supported":true},{"ieee":"00:15:8d:00:02:77:5c:62","nwk":"0xbc85","lqi":180,"rssi":-55,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:02:38:91:78","nwk":"0xf411","lqi":161,"rssi":-61,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:02:2d:2c:86","nwk":"0x6a04","lqi":182,"rssi":-62,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.sensor_magnet.aq2","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:03:e7:42:bb","nwk":"0xcd59","lqi":224,"rssi":-46,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.sensor_magnet.aq2","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:02:38:fa:ce","nwk":"0xfb8b","lqi":102,"rssi":-72,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:02:2f:dc:e1","nwk":"0x8852","lqi":179,"rssi":-54,"pan_id":"6d:0a:be:a6:26:89:81:f3","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true}]},{"ieee":"00:15:8d:00:02:77:5c:62","nwk":"0xbc85","lqi":180,"rssi":-55,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:02:38:91:78","nwk":"0xf411","lqi":156,"rssi":-61,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:03:e7:42:bb","nwk":"0xcd59","lqi":216,"rssi":-46,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:02:2d:2c:86","nwk":"0x6a04","lqi":152,"rssi":-62,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:02:2f:dc:e1","nwk":"0x8852","lqi":184,"rssi":-54,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:02:38:fa:ce","nwk":"0xfb8b","lqi":112,"rssi":-72,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"84:2e:14:ff:fe:e5:77:10","nwk":"0x082a","lqi":136,"rssi":-66,"device_type":"EndDevice","manufacturer":"TUYATEC-0l6xaqmi","model":"RH3001","offline":false,"neighbours":[]},{"ieee":"84:71:27:ff:fe:fe:7f:eb","nwk":"0x9354","lqi":88,"rssi":-78,"device_type":"EndDevice","manufacturer":"_TZ3000_qaaysllp","model":"TS0201","offline":false,"neighbours":[]},{"ieee":"00:12:4b:00:23:ae:42:1c","nwk":"0x1a31","lqi":88,"rssi":-78,"device_type":"Router","manufacturer":"eWeLink","model":"ZB-SW02","offline":false,"neighbours":[]}]
[2021-06-23 19:22:07][DEBUG] : [{"ieee":"80:4b:50:ff:fe:30:3b:77","nwk":0,"status":2,"lqi":"255","rssi":"0","last_seen":"1624462769.7441745","node_descriptor":"00:40:8f:cd:ab:52:80:00:41:2c:80:00:00","endpoints":[{"id":1,"status":1,"device_type":48879,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[],"input_clusters":[]},{"id":242,"status":1,"device_type":41440,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"manufacturer":"Silicon Labs","model":"EZSP","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":48879,"input_clusters":[],"output_clusters":[]},"242":{"profile_id":260,"device_type":41440,"input_clusters":[],"output_clusters":[33]}}},"class":"bellows.zigbee.application"},{"ieee":"00:15:8d:00:02:77:5c:62","nwk":48261,"status":2,"lqi":"180","rssi":"-55","last_seen":"1624466006.491075","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":3},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20161129"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.2},{"id":33,"name":"battery_percentage_remaining","value":146}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2082}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1015.41}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":7828}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:02:38:91:78","nwk":62481,"status":2,"lqi":"156","rssi":"-61","last_seen":"1624467735.014391","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":3},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20161129"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.4},{"id":33,"name":"battery_percentage_remaining","value":161}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2357}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1015}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":6670}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:03:e7:42:bb","nwk":52569,"status":2,"lqi":"216","rssi":"-46","last_seen":"1624466172.7651703","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","output_clusters":[{"id":0,"name":"BasicCluster","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":6,"name":"On\/Off","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":3},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":2},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.sensor_magnet.aq2"},{"id":6,"name":"date_code","value":"20161128"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":3,"name":"Identify","attributes":[]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.2},{"id":33,"name":"battery_percentage_remaining","value":146}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,3,1,65535],"output_clusters":[0,4,6,65535]}}},"class":"zhaquirks.xiaomi.aqara.magnet_aq2"},{"ieee":"00:15:8d:00:02:2d:2c:86","nwk":27140,"status":2,"lqi":"152","rssi":"-62","last_seen":"1624468510.0498724","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","output_clusters":[{"id":0,"name":"BasicCluster","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":0}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":3},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":2},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.sensor_magnet.aq2"},{"id":6,"name":"date_code","value":"20161128"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":3,"name":"Identify","attributes":[]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.4},{"id":33,"name":"battery_percentage_remaining","value":154}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,3,1,65535],"output_clusters":[0,4,6,65535]}}},"class":"zhaquirks.xiaomi.aqara.magnet_aq2"},{"ieee":"00:15:8d:00:02:2f:dc:e1","nwk":34898,"status":2,"lqi":"184","rssi":"-54","last_seen":"1624466156.1025527","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":3},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20161129"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":29.8},{"id":33,"name":"battery_percentage_remaining","value":111}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2251}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1015.18}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":6771}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:02:38:fa:ce","nwk":64395,"status":2,"lqi":"112","rssi":"-72","last_seen":"1624467323.2963011","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":3},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20161129"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":29.2},{"id":33,"name":"battery_percentage_remaining","value":75}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2096}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1015.12}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":7527}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"84:2e:14:ff:fe:e5:77:10","nwk":2090,"status":2,"lqi":"136","rssi":"-66","last_seen":"1624467389.1872966","node_descriptor":"02:40:80:02:10:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":1026,"profile_id":260,"manufacturer":"TUYATEC-0l6xaqmi","model":"RH3001","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":3},{"id":1,"name":"app_version","value":64},{"id":2,"name":"stack_version","value":0},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"TUYATEC-0l6xaqmi"},{"id":5,"name":"model","value":"RH3001"},{"id":6,"name":"date_code","value":""},{"id":7,"name":"power_source","value":3}]},{"id":10,"name":"Time","attributes":[]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30},{"id":33,"name":"battery_percentage_remaining","value":200}]},{"id":1280,"name":"IAS Zone","attributes":[]}]}],"signature":{"manufacturer":"TUYATEC-0l6xaqmi","model":"RH3001","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4098,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":1026,"input_clusters":[0,10,1,1280],"output_clusters":[25]}}},"class":"zigpy.device"},{"ieee":"84:71:27:ff:fe:fe:7f:eb","nwk":37716,"status":2,"lqi":"88","rssi":"-78","last_seen":"1624468894.1871066","node_descriptor":"02:40:80:02:10:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":262,"profile_id":260,"manufacturer":"_TZ3000_qaaysllp","model":"TS0201","output_clusters":[{"id":25,"name":"Ota","attributes":[]},{"id":10,"name":"Time","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":3},{"id":1,"name":"app_version","value":68},{"id":2,"name":"stack_version","value":0},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"_TZ3000_qaaysllp"},{"id":5,"name":"model","value":"TS0201"},{"id":6,"name":"date_code","value":""},{"id":7,"name":"power_source","value":3}]},{"id":1,"name":"Power Configuration","attributes":[]},{"id":1024,"name":"Illuminance Measurement","attributes":[{"id":0,"name":"measured_value","value":15564}]},{"id":57346,"name":"Cluster","attributes":[]}]}],"signature":{"manufacturer":"_TZ3000_qaaysllp","model":"TS0201","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4098,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":262,"input_clusters":[0,1,1024,57346],"output_clusters":[25,10]}}},"class":"zigpy.device"},{"ieee":"00:12:4b:00:23:ae:42:1c","nwk":6705,"status":2,"lqi":"88","rssi":"-78","last_seen":"1624468787.3988926","node_descriptor":"01:40:8e:00:00:50:a0:00:00:00:a0:00:00","endpoints":[{"id":1,"status":1,"device_type":256,"profile_id":260,"manufacturer":"eWeLink","model":"ZB-SW02","output_clusters":[{"id":0,"name":"Basic","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":4},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"eWeLink"},{"id":5,"name":"model","value":"ZB-SW02"},{"id":6,"name":"date_code","value":"20201026"},{"id":7,"name":"power_source","value":1},{"id":16384,"name":"sw_build_id","value":"1.0.3"}]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":0}]}]},{"id":2,"status":1,"device_type":256,"profile_id":260,"manufacturer":"eWeLink","model":"ZB-SW02","output_clusters":[{"id":0,"name":"Basic","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"eWeLink"},{"id":5,"name":"model","value":"ZB-SW02"},{"id":6,"name":"date_code","value":"20201026"},{"id":7,"name":"power_source","value":1},{"id":16384,"name":"sw_build_id","value":"1.0.3"}]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":0}]}]}],"signature":{"manufacturer":"eWeLink","model":"ZB-SW02","node_desc":{"logical_type":1,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":142,"manufacturer_code":0,"maximum_buffer_size":80,"maximum_incoming_transfer_size":160,"server_mask":0,"maximum_outgoing_transfer_size":160,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":256,"input_clusters":[0,3,4,5,6],"output_clusters":[0]},"2":{"profile_id":260,"device_type":256,"input_clusters":[0,3,4,5,6],"output_clusters":[0]}}},"class":"zigpy.device"}]
[2021-06-23 19:22:07][DEBUG] : {"ieee":"80:4b:50:ff:fe:30:3b:77","version":"0.34.0","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_ezsp.db","device":{"path":"\/dev\/ttyUSB0","baudrate":115200,"flow_control":"software"},"network":{"channel":15,"update_id":0,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","key":null,"key_sequence_number":0,"tc_address":null,"pan_id":null,"channels":34635776,"extended_pan_id":null},"ezsp":{"CONFIG_APS_UNICAST_MESSAGE_COUNT":12,"CONFIG_SOURCE_ROUTE_TABLE_SIZE":16,"CONFIG_ADDRESS_TABLE_SIZE":8},"topology_scan_skip_coordinator":false,"topology_scan_enabled":true,"ezsp_policies":[],"topology_scan_period":240,"handle_unknown_devices":false,"ota":{"otau_directory":null,"ikea_provider":false,"ledvance_provider":false},"ezsp_config":[],"source_routing":false},"ezsp":{"extendedPanId":"f3:81:89:26:a6:be:0a:6d","panId":"0xc787","radioTxPower":8,"radioChannel":15,"nwkManagerId":"0x0","nwkUpdateId":"0x0","version":"6.9.1.0 build 214"}}
[2021-06-23 19:22:21][DEBUG] : http://127.0.0.1:8089/device type : DELETE
[2021-06-23 19:22:21][DEBUG] : {"ieee":"84:71:27:ff:fe:fe:7f:eb"}
[2021-06-23 19:22:21][DEBUG] : ""
[2021-06-23 19:22:21][DEBUG] : {"device_removed":"84:71:27:ff:fe:fe:7f:eb"}
[2021-06-23 19:22:58][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2021-06-23 19:22:58][DEBUG] : {"duration":180}
[2021-06-23 19:22:59][DEBUG] : ""
[2021-06-23 19:23:05][DEBUG] : {"device_joined":"84:71:27:ff:fe:fe:7f:eb"}
[2021-06-23 19:23:22][DEBUG] : {"device_initialized":"84:71:27:ff:fe:fe:7f:eb"}
[2021-06-23 19:23:23][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":{"61441":{"value":"50","cluster_name":"Illuminance Measurement"}}}}}}
[2021-06-23 19:23:24][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"57346":{"53258":{"value":"40","cluster_name":"Cluster"},"53259":{"value":"10","cluster_name":"Cluster"}}}}}}
[2021-06-23 19:23:24][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"57346":{"53261":{"value":"90","cluster_name":"Cluster"},"53262":{"value":"20","cluster_name":"Cluster"}}}}}}
[2021-06-23 19:23:24][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"57346":{"53254":{"value":"enum8.undefined_0x02","cluster_name":"Cluster"}}}}}}
[2021-06-23 19:23:27][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"57346":{"53263":{"value":"enum8.undefined_0x02","cluster_name":"Cluster"},"53264":{"value":"0","cluster_name":"Cluster"}}}}}}
[2021-06-23 19:23:31][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"15683","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:23:35][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"15564","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:23:36][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"15564","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:23:38][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"15564","cluster_name":"Illuminance Measurement"}],"0":[{"value":"3","cluster_name":"Basic"},{"value":"68","cluster_name":"Basic"},{"value":"0","cluster_name":"Basic"},{"value":"1","cluster_name":"Basic"}]}}}}
[2021-06-23 19:23:40][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":[{"7":{"value":"PowerSource.Battery","cluster_name":"Basic"}}]}}}
[2021-06-23 19:23:41][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":[{"6":{"value":"","cluster_name":"Basic"}}]}}}
[2021-06-23 19:23:43][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"15799","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:23:51][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:23:52][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-06-23 19:23:52][DEBUG] : {"with_attributes":2}
[2021-06-23 19:23:53][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2021-06-23 19:23:53][DEBUG] : {"ieee":"84:71:27:ff:fe:fe:7f:eb","endpoint":1,"cluster":1029,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-06-23 19:23:53][INFO] : [Aucun][TZ3000_qaaysllp.TS0201 84:71:27:ff:fe:fe:7f:eb] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"84:71:27:ff:fe:fe:7f:eb","endpoint":1,"cluster":1029,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Cluster not found : 1029","code":0}
[2021-06-23 19:23:53][DEBUG] : {"ieee":"84:71:27:ff:fe:fe:7f:eb","endpoint":1,"cluster":1026,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-06-23 19:23:53][INFO] : [Aucun][TZ3000_qaaysllp.TS0201 84:71:27:ff:fe:fe:7f:eb] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"84:71:27:ff:fe:fe:7f:eb","endpoint":1,"cluster":1026,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Cluster not found : 1026","code":0}
[2021-06-23 19:23:53][DEBUG] : {"ieee":"84:71:27:ff:fe:fe:7f:eb","endpoint":1,"cluster":1024,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-06-23 19:23:59][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2021-06-23 19:23:59][DEBUG] : null
[2021-06-23 19:23:59][DEBUG] : http://127.0.0.1:8089/device/info?ieee=84%3A71%3A27%3Aff%3Afe%3Afe%3A7f%3Aeb type : GET
[2021-06-23 19:23:59][DEBUG] : {"ieee":"84:71:27:ff:fe:fe:7f:eb"}
[2021-06-23 19:23:59][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"}},"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:23:59][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
[2021-06-23 19:23:59][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:24:05][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:24:05][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
[2021-06-23 19:24:05][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-06-23 19:24:10][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}],"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-06-23 19:24:10][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
[2021-06-23 19:24:14][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}],"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-06-23 19:24:14][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
[2021-06-23 19:24:18][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:24:18][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
[2021-06-23 19:24:18][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-06-23 19:24:22][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}],"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-06-23 19:24:22][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
[2021-06-23 19:24:27][DEBUG] : {"devices":{"84:71:27:ff:fe:fe:7f:eb":{"1":{"1024":[{"value":"16436","cluster_name":"Illuminance Measurement"}]}}}}
[2021-06-23 19:24:27][DEBUG] : Search attribut for 84:71:27:ff:fe:fe:7f:eb logicalId : 1::1024::0 => 16436
Bonjour, @Martial210, j’ai exactement le même problème sur mes 3 capteurs.
En plus j’ai pas mal de perte de synchro avec ma clé Zigbee (lumière qui clignote)
Bonjour @lepalois, je constate les mêmes problèmes.
J’ai pu faire d’autre test avec une Smart Gateway Tuya, une fois l’équipement connecté tous remonte correctement dans l’application mobile Smart Life, température, humidité et luminosité.
Donc mon prochain objectif est de connecté la Smart Gateway Tuya directement dans Jeedom avec le plugin Zigbee. J’ai vu sur d’autre poste qu’il est possible de le faire et par la suite récupérer des information a travers cette Gateway des différent équipement connecté.
Cette méthode permettrait peux être de résoudre notre problème.
Bonsoir @Martial210, tu as réussi à faire remonter les informations ?
