Je suis sur la dernière version beta du plugin, et il ne fonctionne plus chez moi, vraisemblablement à cause des dépendances.
Je suppose que c’est à cause du « Passage sur Venv pour les dépendances (réinstallation automatique normalement) » du 11/07.
Mon Jeedom tourne sur un NAS Synology, voici les logs de l’install des dépendances : enphasesecur_update.txt (8,6 Ko)
Le demon est en NOK avec « dépendances non installées ».
The directory '/var/www/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/var/www/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting html-parser
Downloading https://files.pythonhosted.org/packages/fa/ae/4b752c60868d26d6d14e89882ade7204fd73543e1bde64b6e9b01c1d9856/html-parser-0.2.tar.gz
Collecting ply (from html-parser)
Downloading https://files.pythonhosted.org/packages/a3/58/35da89ee790598a0700ea49b2a66594140f44dec458c07e8e3d4979137fc/ply-3.11-py2.py3-none-any.whl (49kB)
Installing collected packages: ply, html-parser
Running setup.py install for html-parser: started
Running setup.py install for html-parser: finished with status 'done'
Successfully installed html-parser-0.2 ply-3.11
