J’essaye d’installer le plugn espeasy, ma jeedom est un rasp V4.
J’ai des erreurs lors de l’installation des dépendances.
Je suis pas une masse en linux et avant de tout casser ;o) si quelqu’un a une idée je suis preneur ;o)
--2021-12-18 13:38:46-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.110.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1552 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 3.22M=0s
2021-12-18 13:38:46 (3.22 MB/s) - 'dependencies.sh' saved [1552/1552]
dependencies.sh: 3: [: espeasy: unexpected operator
Version actuelle : 10
Hit:1 http://packages.azlux.fr/debian buster InRelease
Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Hit:3 http://deb.debian.org/debian buster InRelease
Hit:4 http://deb.debian.org/debian-security buster/updates InRelease
Hit:5 http://deb.debian.org/debian buster-updates InRelease
Reading package lists...
E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 285 not upgraded.
dependencies.sh: 29: dependencies.sh: [[: not found
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
The following packages will be REMOVED:
libc-ares2* libnode64* nodejs* nodejs-doc*
0 upgraded, 0 newly installed, 4 to remove and 285 not upgraded.
After this operation, 30.5 MB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 109857 files and directories currently installed.)
Removing nodejs (10.24.0~dfsg-1~deb10u1) ...
Removing libnode64:arm64 (10.24.0~dfsg-1~deb10u1) ...
Removing libc-ares2:arm64 (1.14.0-1+deb10u1) ...
Removing nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10) ...
dependencies.sh: 38: [: aarch64: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian-security buster/updates InRelease
Hit:3 http://packages.azlux.fr/debian buster InRelease
Hit:4 http://deb.debian.org/debian buster-updates InRelease
Get:5 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Error executing command, exiting
The following additional packages will be installed:
libc-ares2 libnode64 nodejs-doc
Suggested packages:
npm
libc-ares2 libnode64 nodejs nodejs-doc
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 4 newly installed, 0 to remove and 285 not upgraded.
Need to get 0 B/6426 kB of archives.
After this operation, 30.5 MB of additional disk space will be used.
Selecting previously unselected package libc-ares2:arm64.
(Reading database ... 109719 files and directories currently installed.)
Preparing to unpack .../libc-ares2_1.14.0-1+deb10u1_arm64.deb ...
Unpacking libc-ares2:arm64 (1.14.0-1+deb10u1) ...
Selecting previously unselected package libnode64:arm64.
Preparing to unpack .../libnode64_10.24.0~dfsg-1~deb10u1_arm64.deb ...
Unpacking libnode64:arm64 (10.24.0~dfsg-1~deb10u1) ...
Selecting previously unselected package nodejs.
Preparing to unpack .../nodejs_10.24.0~dfsg-1~deb10u1_arm64.deb ...
Unpacking nodejs (10.24.0~dfsg-1~deb10u1) ...
Selecting previously unselected package nodejs-doc.
Preparing to unpack .../nodejs-doc_10.24.0~dfsg-1~deb10u1_all.deb ...
Unpacking nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
Setting up libc-ares2:arm64 (1.14.0-1+deb10u1) ...
Setting up libnode64:arm64 (10.24.0~dfsg-1~deb10u1) ...
Setting up nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
Setting up nodejs (10.24.0~dfsg-1~deb10u1) ...
update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
ln: failed to create symbolic link '/usr/bin/nodejs': File exists
Version actuelle : v10.24.0
dependencies.sh: 61: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
