Probleme de com Z2M
Bonjour depuis quelques temps je suis obligé de relancer le demon Z2m afin de pouvoir commander mes volets roulant (ts130F) ou/et mon TS004 (qutre sortie logiques).
ci joint une partie du log Z2M
|0041|[2026-04-24 19:17:03] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0042|[2026-04-24 19:17:03] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0043|[2026-04-24 19:17:03] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0044|[2026-04-24 19:17:03] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0045|[2026-04-24 19:22:20] e[31merrore[39m: |z2m: Publish 'set' 'state' to '0xa4c138db5b518a43' failed: 'Error: ZCL command 0xa4c138db5b518a43/1 genOnOff.off({}, {timeout:10000,disableResponse:false,disableRecovery:false,disableDefaultResponse:false,direction:0,reservedBits:0,writeUndiv:false}) failed (Timeout - 11718 - 1 - 250 - 6 - 11 after 10000ms)'|
|0046|[2026-04-24 19:24:02] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0047|[2026-04-24 19:24:02] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0048|[2026-04-24 19:24:02] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0049|[2026-04-24 19:24:02] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0050|[2026-04-24 19:24:16] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0051|[2026-04-24 19:24:16] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0052|[2026-04-24 19:25:09] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0053|[2026-04-24 19:25:09] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0054|[2026-04-24 19:40:03] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0055|[2026-04-24 19:40:03] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0056|[2026-04-24 19:40:06] e[31merrore[39m: |z2m: Publish 'set' 'state' to '0xa4c138db5b518a43' failed: 'Error: ZCL command 0xa4c138db5b518a43/1 genOnOff.off({}, {timeout:10000,disableResponse:false,disableRecovery:false,disableDefaultResponse:false,direction:0,reservedBits:0,writeUndiv:false}) failed (Timeout - 11718 - 1 - 15 - 6 - 11 after 10000ms)'|
|0057|[2026-04-24 19:42:02] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0058|[2026-04-24 19:42:02] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0059|[2026-04-24 19:45:55] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0060|[2026-04-24 19:45:55] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0061|[2026-04-24 19:46:02] e[31merrore[39m: |zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds|
|0062|[2026-04-24 19:46:02] e[31merrore[39m: |zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped|
|0063|[2026-04-24 19:53:06] e[31merrore[39m: |zh:ezsp:uart: --> Error: Error: {sequence:6} after 4000ms|
|0064|[2026-04-24 19:53:06] e[31merrore[39m: |zh:ezsp:uart: -!- break waiting (6)|
|0065|[2026-04-24 19:53:06] e[31merrore[39m: |zh:ezsp:uart: Can't send DATA frame (5,3,0): 8d00013400001da1040100ef010100010000090a05101f0b0200|
|0066|[2026-04-24 19:53:11] e[31merrore[39m: |zh:ezsp:uart: --> Error: Error: {sequence:6} after 4000ms|
|0067|[2026-04-24 19:53:11] e[31merrore[39m: |zh:ezsp:uart: -!- break rewaiting (6)|
|0068|[2026-04-24 19:53:11] e[31merrore[39m: |zh:ezsp:uart: Can't resend DATA frame (5,3,1): 8d00013400001da1040100ef010100010000090a05101f0b0200|
Merci à tous.
Informations Jeedom Atlas
Core : 4.5.3 (master)
DNS Jeedom Atlas : oui
Plugin : JeeZigbee
Version : 2026-04-13 01:01:55 (stable)
Statut Démon : Démarré - (2026-04-24 18:55:02)
Santé
🟢 Matériel : Atlas
🟢 Système à jour : OK
🟢 Cron actif : OK
🟢 Scénario actif : OK
🟢 Démarré : OK 2026-04-24 18:54:03
🟢 Date système (dernière heure enregistrée) : OK 2026-04-24 20:22:41 (2026-04-24 20:09:02)
🟢 Droits sudo : OK
🟢 Version Jeedom : 4.5.3
🟢 Version OS : debian 11.8
🟢 Version PHP : 7.4.33
🟢 Nombre de processus Apache : 13
🟢 Version OS : Linux JeedomAtlas 5.15.93-rockchip64 #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 aarch64 GNU/Linux  [11.8]
🟢 Version database : 10.5.21-MariaDB-0+deb11u1
🟢 Espace disque libre : 78 %
🟢 Connexion active/max/autorisée : 15/26/151
🟢 Taille base de données : 67.18 MB
🟢 Espace disque libre tmp : 98 %
🟢 Mémoire disponible : 81 % (Total 3864 Mo)
🟢 Mémoire suffisante : 0
🟢 Erreur I/O : 0
🟢 Swap disponible : 100 % (Total 1932 Mo)
🟢 Swappiness : 100 %
🟢 Charge : 0.85 - 1.28 - 1.21
🟢 Node : v22.21.0
🟢 Python 3 : Python 3.9.2
🟢 Persistance du cache : OK
🟢 Apache private tmp : OK
Plusieurs question :
1- es tu bien sur le contrôleur natif de l’Atlas ? (à priori oui)
2- as tu mis à jour ce dernier pour passer en ember ? à priori non
3- quelle est ta version de zigbee2mqtt (les dépendances) ? à priori 1.4.2 ou <
En gros en fonction de ta réponse tu devras ou pas mettre à jour le contrôleur de l’atlas et/ou les dépendances. Nous en sommes à la version 2.9.2 et chaque version apporte son lot de correctifs et d’amélioration dans les prises en charge… Et EZP +Z2m ne supporte pas les versions > 1.42
Avant toute chose :
J’ai une Atlas mais avec une clé ConbeeII , j’avais toutefois mis à jour le firmware sans soucis. (Atlas acheté en décembre 2023)
