Je n’ai pas pu me résoudre à lâcher l’affaire.
J’ai retrouvé les fichiers, j’ai bien transféré dans le bon dossier.
Et j’ai lancé la commande.
root@jeedup:/home# cp -R /tmp/V4/* /var/www/html/
root@jeedup:/home# sudo php /var/www/html/install/update.php
[START UPDATE]
[PROGRESS][1]
Update from 4.4.5 (2024-05-03 11:02:55)
Parameters :
Send begin of update event…OK
Check update…Error during update : [MySQL] Error code : 42S22 (1054). Unknown column ‹ updateDate › in ‹ field list › : SELECT id, type, logicalId, name, localVersion, remoteVersion, status, configuration, source, updateDa te
FROM update ORDER BY FIELD( status, « update »,« ok »,« depreciat ed ») ASC,FIELD( type,« plugin »,« core ») DESC, name ASCDetails : Array
[0] => Array
[file] => /var/www/html/core/class/update.class.php
[line] => 214
[function] => Prepare
[class] => DB
[type] => ::
[args] => Array
[0] => SELECT id, type, logicalId, name, localVersi on, remoteVersion, status, configuration, source, updateDate
[1] => Array
[2] => 1
[3] => 8
[4] => update
[1] => Array
[line] => 45
[function] => all
[class] => update
[type] => ::
[args] => Array
[0] =>
[2] => Array
[file] => /var/www/html/install/update.php
[line] => 66
[function] => checkAllUpdate
[class] => update
[type] => ::
[args] => Array
[0] =>
[1] =>
[END UPDATE ERROR]
PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S22 (1054). Unknown column ‹ updateDate › in ‹ field list › : SELECT id, type, logicalId, name , localVersion, remoteVersion, status, configuration, source, updateD ate
FROM update ORDER BY FIELD( status, « update »,« ok »,« depreciat ed ») ASC,FIELD( type,« plugin »,« core ») DESC, name ASC in /var/www/html/core/c lass/DB.class.php:102
Stack trace:
#0 /var/www/html/core/class/update.class.php(214): DB::Prepare(‹ SELECT id, `t. … ›, Array, 1, 8, ‹ update ›)
#1 /var/www/html/core/class/update.class.php(45): update::all(‹ ›)
#2 /var/www/html/install/update.php(66): update::checkAllUpdate(‹ ›, false)
#3 {main}
thrown in /var/www/html/core/class/DB.class.php on line 102
root@jeedup:/home#
Une idée?
Encore merci!
Matthieu
