bonjour j ai une erreur lorsque le plugin Arlo essaye d envoyer une capture par le biais de telegram.
[2021-05-10 09:11:20][DEBUG] : Call url https://api.telegram.org/bot1275250639:AAGmHM9quedhQ-dTg1onTs77kHb-Nljw2-Q/sendPhoto with option Array ( [disable_notification] => 0 [parse_mode] => Markdown [photo] => CURLFile Object ( [name] => /var/www/html/plugins/arlo/data/snapshots/A5D1097VA1AF7/20210510081119327548.jpg [mime] => [postname] => ) [caption] => Capture depuis Poulailler_camera [chat_id] => 1185532380 )
[2021-05-10 09:11:23][DEBUG] : Result : {"ok":false,"error_code":400,"description":"Bad Request: can't parse entities: Can't find end of the entity starting at byte offset 25"}
[2021-05-10 09:11:23][ERROR] : Erreur exécution de la commande [Maison][Tele com][Tous] : Erreur lors de l'envoi telegram : {"ok":false,"error_code":400,"description":"Bad Request: can't parse entities: Can't find end of the entity starting at byte offset 25"}
[2021-05-10 09:11:24][DEBUG] : Call url https://api.telegram.org/bot1275250639:AAGmHM9quedhQ-dTg1onTs77kHb-Nljw2-Q/sendPhoto with option Array ( [disable_notification] => 0 [parse_mode] => Markdown [photo] => CURLFile Object ( [name] => /var/www/html/plugins/arlo/data/snapshots/A5D1097VA1AF7/20210510081123796598.jpg [mime] => [postname] => ) [caption] => Capture depuis Poulailler_camera [chat_id] => 1185532380 )
[2021-05-10 09:11:27][DEBUG] : Result : {"ok":false,"error_code":400,"description":"Bad Request: can't parse entities: Can't find end of the entity starting at byte offset 25"}
[2021-05-10 09:11:27][ERROR] : Erreur exécution de la commande [Maison][Tele com][Tous] : Erreur lors de l'envoi telegram : {"ok":false,"error_code":400,"description":"Bad Request: can't parse entities: Can't find end of the entity starting at byte offset 25"}
