Un grand merci je vais suivre la partie ssh effectivement tout y est! j’était sur un autre tuto sans cette partie. La effectivement c’est complet merci bcp
Bon je comprend pas je suie toutes la procédure mais pourtant quand je lance la commande manuellement sur le pi j’ai toujours des permission denied
[2020-01-26 08:51:02.958][DEBUG] : Daemon is ready
[2020-01-26 08:51:04.923][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 11): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:06.439][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 12): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:07.950][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 13): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:09.452][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 14): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:10.968][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 15): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:12.487][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 16): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:14.032][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 17): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:15.536][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 18): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:17.046][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 19): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:18.581][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 20): Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:20.083][ERROR] : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 20, error: Permission Denied)
[2020-01-26 08:51:20.088][INFO] : GLOBAL------Shutting down due to errors
[2020-01-26 08:51:20.099][DEBUG] : Send to jeedom : {'learn_mode': 0, 'source': 'Antenna2'}
[2020-01-26 08:51:20.152][DEBUG] : Starting new HTTP connection (1): 192.168.0.42:80
[2020-01-26 08:51:20.198][DEBUG] : http://192.168.0.42:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=XXXX HTTP/1.1" 200 0
[2020-01-26 08:51:22.098][DEBUG] : GLOBAL------Shutdown
[2020-01-26 08:51:22.102][DEBUG] : GLOBAL------Removing PID file /tmp/blead.pid
[2020-01-26 08:51:22.107][DEBUG] : GLOBAL------Closing all potential bluetooth connection
[2020-01-26 08:51:22.132][DEBUG] : LoopNetServer Thread stopped
[2020-01-26 08:51:22.138][DEBUG] : Exit 0
pourtant mon fichier visudo :
# User privilege specification
root ALL=(ALL:ALL) ALL
pi ALL=(ALL) NOPASSWD: ALL
# Allow members of group sudo to execute any command
%sudo ALL=(ALL) NOPASSWD: ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
J’ai oublier ou mal fait un truc? Je pense que je vais faire une réinstallation des 2 pi depuis zéro…
A tu trouvé la solution car j’ai le même probléme que toi?
Quel problème avez vous exactement ?
Vous ne pouvez pas dire : j’ai le même problème que toi, dans un fil ou tout est mélangé.
Qu’avez vous fait ?
Comment l’avez vous fait ?
Enfin, qu’avez vous exactement comme problème ?
Enfaite j’ai un raspberry Pi 2 ou j’ai installer une clé bluetooth pour pouvoir servir d’antennes mais après avoir suivi la doc du plugin et aussi ce tuto l’antenne ne marche pas mais je me suis dit que c’etait parce que javais autre chose qui tournait sur le Pi(Pi Hole) du coup refais une installe et j’ai réessayer mais le probleme n’est toujours pas résolus et je ne sais pas quoi essayer, d’autre aurait-tu une solution ?
Vous avez suivie le tutoriel à la lettre pret ?
Que donne le journal d’installation des dépendances de l’antenne elle même.
C’est partiel
Vous avez mis quoi comme clé Bluetooth ?
Que donne la commande hciconfig ?
La copie d’écran avec : Antenne pi2 v1.0-0
N’est pas ce qui est attendue, en principe la version doit être v2.9
C’est tu pourquoi ca donne v1.0 et pas v2.9 ?
Dans l’antenne BT, vous avez bien mis : hci0 ?
Montrez les écrans de configuration de l’antenne SVP.
Ok, il faut les journaux de log maintenant.
Car la, à l’oeil cela semble ok.
les log de l’antennes sont vide a par celle des dependances.
Vous êtes sur de cela ?
Vous avez tenté de démarrer le deamon manuellement ?
Juste pour voir, mettez les identifiants root de l’antenne à la place du compte plugintblea.
J’ai essayer de démarrer le deamon manuellement et il reste comme ca
pendant quelque temps mais ne remonte pas les données des équipement j’ai mis comme demandé les identifiants root et ca ne change pas énormement a première vu et les logs même après avoir cliqué sur ce bouton
Je vien de me rendre compte que cela avait changer mais comme dit ci-dessus le deamon c’est arréter.
Ok, donc, j’avez vous fait à 09h55 pour que cela fonctionne ?
Vous avez changé vos identifiants c’est cela ?
J’ai changer les identifiant relancé les dépendance pour voir si le changement avait marché et bien oui du coup et j’ai juste récuperer manuellement les logs.
