je viens d’acheter le plugin jeedore pour communiquer avec mon equipement delta dore dont une tydom 2
pour l’installation du plugin pas de soucis
dependance statut ok
etat statut ok
daemon statut NOK
dans la configuration j’ai mis l’adresse mac de la tydom, l’adresse IP , le mot de passe et le code de l’alarme et en reseau local
au niveau des logs ca me marque que il n’arrive pas a lancer le daemon
je suis sur un pc avec une machine virtuel virtual box
sa0153|09/24/2023 12:39:33 - Jeedore Daemon connection has been closed...
0154|09/24/2023 12:39:33 - Connection to DeltaDore server has been closed...
0155|09/24/2023 12:39:59 - Websocket connection initialization....
0156|09/24/2023 12:39:59 - Connecting to '192.168.1.4'
0157|09/24/2023 12:40:03 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0158|09/24/2023 12:40:03 - Jeedore Daemon connection has been closed...
0159|09/24/2023 12:40:03 - Connection to DeltaDore server has been closed...
0160|09/24/2023 12:40:29 - Websocket connection initialization....
0161|09/24/2023 12:40:29 - Connecting to '192.168.1.4'
0162|09/24/2023 12:40:34 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0163|09/24/2023 12:40:34 - Jeedore Daemon connection has been closed...
0164|09/24/2023 12:40:34 - Connection to DeltaDore server has been closed...
0165|09/24/2023 12:40:37 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0166|09/24/2023 12:40:37 - Jeedore Daemon connection has been closed...
0167|09/24/2023 12:40:37 - An error with websocket connection has occured...
0168|09/24/2023 12:40:37 - Error websocket : 'An error has occurred in sending data.
0169|09/24/2023 12:40:37 - Jeedore Daemon has received a DeltaDore error...
0170|09/24/2023 12:40:59 - Websocket connection initialization....
0171|09/24/2023 12:40:59 - Connecting to '192.168.1.4'
0172|09/24/2023 12:41:03 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0173|09/24/2023 12:41:03 - Jeedore Daemon connection has been closed...
0174|09/24/2023 12:41:03 - Connection to DeltaDore server has been closed...
0175|09/24/2023 12:41:29 - Websocket connection initialization....
0176|09/24/2023 12:41:29 - Connecting to '192.168.1.4'
0177|09/24/2023 12:41:33 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0178|09/24/2023 12:41:33 - Jeedore Daemon connection has been closed...
0179|09/24/2023 12:41:33 - Connection to DeltaDore server has been closed...
0180|09/24/2023 12:41:59 - Websocket connection initialization....
0181|09/24/2023 12:41:59 - Connecting to '192.168.1.4'
0182|09/24/2023 12:42:03 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0183|09/24/2023 12:42:03 - Jeedore Daemon connection has been closed...
0184|09/24/2023 12:42:03 - Connection to DeltaDore server has been closed...
0185|09/24/2023 12:42:29 - Websocket connection initialization....
0186|09/24/2023 12:42:29 - Connecting to '192.168.1.4'
0187|09/24/2023 12:42:32 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0188|09/24/2023 12:42:32 - Jeedore Daemon connection has been closed...
0189|09/24/2023 12:42:32 - Connection to DeltaDore server has been closed...
0190|09/24/2023 12:42:59 - Websocket connection initialization....
0191|09/24/2023 12:42:59 - Connecting to '192.168.1.4'
0192|09/24/2023 12:43:03 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0193|09/24/2023 12:43:03 - Jeedore Daemon connection has been closed...
0194|09/24/2023 12:43:03 - Connection to DeltaDore server has been closed...
0195|09/24/2023 12:43:29 - Websocket connection initialization....
0196|09/24/2023 12:43:29 - Connecting to '192.168.1.4'
0197|09/24/2023 12:43:32 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
0198|09/24/2023 12:43:32 - Jeedore Daemon connection has been closed...
0199|09/24/2023 12:43:32 - Connection to DeltaDore server has been closed...
0200|09/24/2023 12:43:59 - Websocket connection initialization....
0201|09/24/2023 12:43:59 - Connecting to '192.168.1.4'isissez ou collez du code ici
saisi 2023-09-24 22:41:44 jeedore Attention : installation des dépendances lancée 12
2023-09-24 18:43:45 jeedore Impossible to find command with id : alarmMode1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : systOpenIssue1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : networkDefect1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : zone1State1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : zone2State1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : zone3State1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : outTemperature1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : gsmLevel1679071734#1679071734
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510609#1679510609
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510609#1679510609
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510670#1679510670
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510670#1679510670
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510717#1679510717
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510717#1679510717
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510778#1679510778
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510778#1679510778
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510821#1679510821
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510821#1679510821
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510866#1679510866
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510866#1679510866
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510896#1679510896
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510935#1679510935
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510935#1679510935
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679510981#1679510981
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679510981#1679510981
2023-09-24 18:43:45 jeedore Impossible to find command with id : autoProtect1679511129#1679511129
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679511129#1679511129
2023-09-24 18:43:45 jeedore Impossible to find command with id : intrusionDetect1679511129#1679511129
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679512907#1679512907
2023-09-24 18:43:45 jeedore Impossible to find command with id : techSmokeDefect1679512907#1679512907
2023-09-24 18:43:45 jeedore Impossible to find command with id : battDefect1679513177#1679513177
2023-09-24 18:43:45 jeedore Impossible to find command with id : techSmokeDefect1679513177#1679513177
2023-09-24 18:43:45 jeedore Impossible to find command with id : position1681316038#1681316038
2023-09-24 12:29:08 jeedore Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2023-09-24 12:28:32
2023-09-24 12:07:53 jeedore Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement 3638
2023-09-24 12:05:33 jeedore Impossible to launch le daemon JeeDore...ssez ou collez du code ici
