Bonjour, je rencontre toujours des problèmes de plugins KNX qui ne fonctionne pas au démarrage de jeedom V4 sur Raspberry B3+. A chaque redémarrage le daemon est ok mais aucune communication je suis obligé d’arrêter et redémarrer le daemon. Ci-dessous le log si quelqu’un peut m’aider ?
LOG DU DAEMON
Jeedom: Layer 4 [ 1:main 0.000] initialized
Jeedom: Layer 4 [ 1:main 0.000] setting up
Jeedom: Layer 3 [ 4:server/Server 0.001] registerLink: 4:server
Jeedom: Layer 3 [11:A.tcp/inet 0.001] registerLink: 11:A.tcp
Jeedom: Layer 3 [15:B.usb/Conn 0.001] registerLink: 15:B.usb
Jeedom: Layer 4 [ 1:main 0.001] setup OK
Jeedom: Layer 4 [ 1:main 0.001] trigger going up
Jeedom: Layer 3 [15:B.usb/Conn 0.001] Start: cfg:B.usb
Jeedom: Layer 5 [15:B.usb/Conn 0.001] down => >up
Jeedom: Layer 5 [15:B.usb/Conn 0.001] Starting
Jeedom: Layer 1 [18:B.usb/usbL 0.015] Detect
libusb: error [_get_usbfs_fd] libusb couldn't open USB device /dev/bus/usb/001/004: Permission denied
libusb: error [_get_usbfs_fd] libusb requires write access to USB device nodes.
Jeedom: Layer 1 [18:B.usb/usbL 0.016] No matching endpoint found.
Jeedom: Layer 1 [18:B.usb/usbL 0.016] Close G
Jeedom: Layer 1 [18:B.usb/usbL 0.016] Release
Jeedom: Layer 4 [15:B.usb/Conn 0.016] link state changed: >up
Jeedom: Layer 3 [ 4:server/Server 0.016] Start: cfg:server
Jeedom: Layer 5 [ 4:server/Server 0.016] down => >up
Jeedom: Layer 8 [ 4:server/Server 0.016] Open
Jeedom: Layer 0 [ 4:server/Server 0.019] Open
Jeedom: Layer 0 [ 4:server/Server 0.019] Opened
Jeedom: Layer 8 [22:router/driver 0.019] OpenD
Jeedom: Layer 8 [22:router/driver 0.020] OpenedD
Jeedom: Layer 3 [21:router/ConnC 0.020] registerLink: 21:router_21
Jeedom: Layer 3 [21:router/ConnC 0.020] Start: cfg:router
Jeedom: Layer 5 [21:router/ConnC 0.020] down => >up
