Bonjour, et encore merci pour se formidable plugin.
Il me reste plus que la sirène à ajouter pour passer à la configuration du plugin Alarme
Mais malheureusement, je rencontre un soucis car les commandes ne fonctionnent pas.
En regardant les informations brutes, je m’aperçois que le modèle que j’ai n’est pas le même que dans le plugin. Je me demande si il n’y a pas 2 modèles différents, car avec la configuration automatique la sirène est reconnue en LCA001 alors que dans la configuration brute, le modèle est TS0601.
Voici les informations et l’image au cas ou il faut ajouter un second modèle.
Marque neo Coolcam " mais reconnue en tant que tuya", modele NAS-AB02.
Et les informations brutes :
"ieee": "80:4b:50:ff:fe:04:74:61",
"nwk": 65216,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1027,
"profile_id": 260,
"manufacturer": "_TZE200_d0yu2xgi",
"model": "TS0601",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 83
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_d0yu2xgi"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 7,
"name": "power_source",
"value": 3
"id": 3,
"name": "Identify",
"attributes": []
"id": 61184,
"name": "Tuya Manufacturer Specicific",
"attributes": []
"id": 1026,
"name": "Temperature Measurement",
"attributes": []
"id": 1029,
"name": "Relative Humidity Measurement",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
3,
61184,
1026,
1029,
6
3,
25
"class": "zhaquirks.tuya.siren"
) sauf si j’ai loupé quelque-chose…
