Suite à la mise à jour, j’ai un souci d’installation des dépendances.
Voilà le log.
Si quelqu’un peut m’aider.
Merci d’avance,
0000|*************************************
0001|* Launch install of dependencies *
0002|*************************************
0003|Wed 09 Aug 2023 01:55:06 PM UTC
0004|Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
0005|Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
0006|Get:3 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
0007|Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
0008|Hit:5 https://oph.mdrjr.net/meveric all InRelease
0009|Hit:6 https://oph.mdrjr.net/meveric buster InRelease
0010|Get:7 http://www.deb-multimedia.org buster InRelease [18.1 kB]
0011|Reading package lists...
0012|E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
0013|E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
0014|E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
0015|E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
0016|*****************************
0017|Install modules using apt-get
0018|*****************************
0019|Reading package lists...
0020|Building dependency tree...
0021|Reading state information...
0022|python3-pip is already the newest version (18.1-5).
0023|python3-setuptools is already the newest version (40.8.0-1).
0024|python3 is already the newest version (3.7.3-1).
0025|python3-requests is already the newest version (2.21.0-1).
0026|The following additional packages will be installed:
0027|libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
0028|python3.7 python3.7-dev python3.7-minimal python3.7-venv
0029|Suggested packages:
0030|python3.7-doc binfmt-support
0031|The following NEW packages will be installed:
0032|python3-venv python3.7-venv
0033|The following packages will be upgraded:
0034|libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
0035|python3.7 python3.7-dev python3.7-minimal
0036|7 upgraded, 2 newly installed, 0 to remove and 252 not upgraded.
0037|Need to get 8,233 kB of archives.
0038|After this operation, 56.3 kB of additional disk space will be used.
0039|Err:1 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-dev arm64 3.7.3-2+deb10u4
0040|404 Not Found [IP: 151.101.10.132 80]
0041|Err:2 http://security.debian.org/debian-security buster/updates/main arm64 python3.7 arm64 3.7.3-2+deb10u4
0042|404 Not Found [IP: 151.101.10.132 80]
0043|Err:3 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7-dev arm64 3.7.3-2+deb10u4
0044|404 Not Found [IP: 151.101.10.132 80]
0045|Err:4 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7 arm64 3.7.3-2+deb10u4
0046|404 Not Found [IP: 151.101.10.132 80]
0047|Err:5 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7-stdlib arm64 3.7.3-2+deb10u4
0048|404 Not Found [IP: 151.101.10.132 80]
0049|Err:6 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-minimal arm64 3.7.3-2+deb10u4
0050|404 Not Found [IP: 151.101.10.132 80]
0051|Err:7 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7-minimal arm64 3.7.3-2+deb10u4
0052|404 Not Found [IP: 151.101.10.132 80]
0053|Err:8 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-venv arm64 3.7.3-2+deb10u4
0054|404 Not Found [IP: 151.101.10.132 80]
0055|Get:9 http://ftp.uk.debian.org/debian buster/main arm64 python3-venv arm64 3.7.3-1 [1,180 B]
0056|Fetched 1,180 B in 0s (11.2 kB/s)
0057|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-dev_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0058|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0059|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-dev_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0060|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0061|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-stdlib_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0062|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-minimal_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0063|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-minimal_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0064|E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-venv_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 151.101.10.132 80]
0065|E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
0066|*************************************
0067|Creating python 3 virtual environment
0068|*************************************
0069|The virtual environment was not created successfully because ensurepip is not
0070|available. On Debian/Ubuntu systems, you need to install the python3-venv
0071|package using the following command.
0072|apt-get install python3-venv
0073|You may need to use sudo with that command. After installing the python3-venv
0074|package, recreate your virtual environment.
0075|Failing command: ['/var/www/html/plugins/gardena/resources/venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
0076|Done
0077|*************************************
0078|Install the required python libraries
0079|*************************************
0080|/var/www/html/plugins/gardena/core/class/../../resources/venv/bin/python3: No module named pip
0081|/var/www/html/plugins/gardena/core/class/../../resources/venv/bin/python3: No module named pip
0082|Wed 09 Aug 2023 01:55:19 PM UTC
0083|***************************
0084|* Install ended *
