Problème avec le plugin zwave-js depuis changement de box
La suite donc:
Le log zwavejs
[2024-05-27 06:10:04] INFO  : Arrêt du démon ZwaveJS
[2024-05-27 06:10:05] DEBUG  : [configureSettings] Informations reçues de MQTT Manager : {"ip":"127.0.0.1","port":"1883","user":"jeedom","password":"***"}
[2024-05-27 06:10:05] INFO  : Démarrage du démon ZwaveJS : STORE_DIR=/var/www/html/plugins/zwavejs/data/store KEY_S0_Legacy=0102030405060708090A0B0C0D0E0F10 KEY_S2_Unauthenticated=B5E62B417E79F28B0FD86105EAA31951 KEY_S2_Authenticated=FF6A6747F6C56EC7B1586D09A60DDC2D KEY_S2_AccessControl=8A0226076B4664A5ECAE7672D68ACAE0 SESSION_SECRET=jeedomSession yarn start
le log zwavejsd
e[90m2024-05-27 06:10:09.838e[39m e[33mWARNe[39m e[1mSTOREe[22m: scenes.json not found
error Command failed with signal "SIGTERM".
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
yarn run v1.22.22
$ node --preserve-symlinks server/bin/www.js
e[90m2024-05-27 06:15:10.021e[39m e[32mINFOe[39m e[1mAPPe[22m: Version: 9.12.0.96eeb76
e[90m2024-05-27 06:15:10.027e[39m e[32mINFOe[39m e[1mAPPe[22m: Application path:/var/www/html/plugins/zwavejs/resources/zwave-js-ui
______  __          __                      _  _____     _    _ _____
|___  /  \ \        / /                     | |/ ____|   | |  | |_   _|
/ /____\ \  /\  / /_ ___   _____         | | (___     | |  | | | |
/ /______\ \/  \/ / _' \ \ / / _ \    _   | |\___ \    | |  | | | |
/ /__      \  /\  / (_| |\ V /  __/   | |__| |____) |   | |__| |_| |_
/_____|      \/  \/ \__,_| \_/ \___|    \____/|_____/     \____/|_____|
e[90m2024-05-27 06:15:10.059e[39m e[33mWARNe[39m e[1mSTOREe[22m: scenes.json not found
le log de JMQTT
[2024-05-27 06:15:10] INFO  : Cmd #[Maison][zwave][_CLIENTS:ZWAVE_GATEWAY-Jeedom:version]# <- {"value":"9.12.0","time":1716783310262}
[2024-05-27 06:15:10] INFO  : Cmd #[Maison][zwave][_CLIENTS:ZWAVE_GATEWAY-Jeedom:status]# <- {"value":true,"time":1716783310264}
[2024-05-27 06:15:12] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:15:15] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:15:19] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:15:25] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:15:35] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:15:52] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:16:09] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:16:26] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:16:43] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:17:00] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:17:17] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:17:34] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:17:52] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:18:09] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:18:26] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: The serial port closed unexpectedly! (ZW0100)","code":100}]}
[2024-05-27 06:18:43] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:18:59] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:19:17] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:19:34] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
[2024-05-27 06:19:52] INFO  : Cmd #[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]# <- {"data":[{"message":"Serial port errored: EIO: i/o error, write (ZW0100)","code":100}]}
Il y a un problème de port mais pourquoi alors par moment cela fonctionne?
Résultat de la commande dmesg | grep tty
[    0.000000] Kernel command line: root=UUID=dec02c02-ccd8-480d-9b4f-da9523ed969e rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=3552739c-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.001982] printk: console [tty1] enabled
[    2.035091] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 42, base_baud = 1500000) is a 16550A
[    2.035276] serial serial0: tty port ttyS0 registered
[    2.036273] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 43, base_baud = 1500000) is a 16550A
[    2.036550] printk: console [ttyS2] enabled
[    4.757967] systemd[1]: Created slice system-getty.slice.
[    4.762098] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.001596] systemd[1]: Found device /dev/ttyS2.
[    6.058664] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
[    6.766867] usb 5-1: FTDI USB Serial Device converter now attached to ttyUSB0
[    6.825691] usb 7-1: FTDI USB Serial Device converter now attached to ttyUSB1
Dans mqtt2 je peux voir parfois ce log
[2024-05-26 03:20:12][DEBUG] : Message reçu sans prise en charge par un plugin : {"jeedom":{"cmd":{"event":{"6395":{"value":"{\"data\":[{\"message\":\"Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)\\n    at Driver.sendMessage (\/var\/www\/html\/plugins\/zwavejs\/resources\/zwave-js-ui\/node_modules\/zwave-js\/src\/lib\/driver\/Driver.ts:5349:23)\\n    at ZWaveController.queryCapabilities (\/var\/www\/html\/plugins\/zwavejs\/resources\/zwave-js-ui\/node_modules\/zwave-js\/src\/lib\/controller\/Controller.ts:970:37)\\n    at Driver.initializeControllerAndNodes (\/var\/www\/html\/plugins\/zwavejs\/resources\/zwave-js-ui\/node_modules\/zwave-js\/src\/lib\/driver\/Driver.ts:1458:46)\\n    at Immediate.<anonymous> (\/var\/www\/html\/plugins\/zwavejs\/resources\/zwave-js-ui\/node_modules\/zwave-js\/src\/lib\/driver\/Driver.ts:1259:16) (ZW0100)\",\"code\":100}]}","humanName":"[Maison][zwave][_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error]","unite":"","name":"_EVENTS:ZWAVE_GATEWAY-Jeedom:driver:driver_error","type":"info","subtype":"string"}}}}}
Merci d’avance.
