bonjour,
j’ai un soucis sur la partie disques dur sui ne se met plus a jour depuis la version de ce week-end:
sur le interne par exemple je suis maintenant vers 10%
la date de collecte ne change pas non plus, mais j’ai bien le refresh dans les logs en debug:
[2020-07-27 20:10:06][DEBUG] : ================= CRON pour l'actualisation de : Disque Dur ==================
[2020-07-27 20:10:06][DEBUG] : ┌───────── Début de Mise à jour
[2020-07-27 20:10:06][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v8/storage/disk/0([])
[2020-07-27 20:10:06][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"idle_duration":18,"spinning":true,"table_type":"msdos","firmware":"SC16","type":"internal","idle":true,"connector":0,"id":0,"state":"enabled","time_before_spindown":582,"total_bytes":250050000000,"model":"ST9250311CS","active_duration":0,"temp":46,"serial":"6VCW9YR4","partitions":[{"fstype":"ext4","total_bytes":244950000000,"label":"Disque dur","id":2,"internal":true,"fsck_result":"no_run_yet","state":"mounted","disk_id":0,"free_bytes":209650000000,"used_bytes":22830000000,"path":"L0Rpc3F1ZSBkdXI="}]}}
[2020-07-27 20:10:06][DEBUG] : └─────────
[2020-07-27 20:10:06][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v8/storage/disk/1000([])
[2020-07-27 20:10:06][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"type":"usb","total_bytes":4000000000000,"connector":0,"id":1000,"active_duration":0,"partitions":[{"fstype":"ntfs","total_bytes":4000000000000,"label":"SAMSUNG","id":1001,"internal":false,"fsck_result":"no_run_yet","state":"mounted","disk_id":1000,"free_bytes":62530000000,"used_bytes":3930000000000,"path":"L1NBTVNVTkc="}],"idle_duration":0,"state":"enabled","idle":false,"spinning":false,"model":"","table_type":"msdos","temp":0,"serial":"","firmware":""}}
