Bonjour a vous,
Je n’arrive pas a activer le plugin somfy alarme de fdp1,
j’ai mes equipements de reconnu par contre lorsque je veux activer cela m’affiche « sauvegarde effectuée » mais la coche du plugin ne reste pas. voici ce que j’ai dans les logs :
0013|[Tue Mar 29 17:13:51.750742 2022] [access_compat:error] [pid 12170] [client 192.168.0.22:48075] AH01797: client denied by server configuration: /var/www/html/plugins/protexiom/doc, referer: http://19************/index.php?v=d&m=protexiom&p=protexiom&id=357
0013|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Garage-247753-357 from parent.
0014|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Centrale from parent.
0015|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Chambre from parent.
0016|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Clavier from parent.
0017|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Porte Entree from parent.
0018|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Porte fenetre from parent.
0019|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling S.A.M from parent.
0020|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Sirene Ext from parent.
0021|[2022-03-29 17:13:41]INFO : [somfy-357] 12170 Enabling Sirene Int from parent.
0022|[2022-03-29 17:13:45]DEBUG : [somfy-357] 12170 Status refreshed
0023|[2022-03-29 17:13:45]DEBUG : [somfy-357] 12170 Setting new battery value to 10
0024|[2022-03-29 17:13:50]DEBUG : [somfy-357] 12170 Elements refreshed
0025|[2022-03-29 17:13:50]DEBUG : [somfy-357] 12170 Pull elements... Done
0026|[2022-03-29 17:13:50]DEBUG : [somfy-357] 12170 Pull status... Done
0027|[2022-03-29 17:13:50]DEBUG : [somfy-357] 12170 Logging off during daemon_stop
0028|[2022-03-29 17:13:50]DEBUG : [*-*] 12170 Daemon started (launchable=ok)
0029|[2022-03-29 17:13:50]DEBUG : [somfy-357] 12170 Running postsave method...
0030|[2022-03-29 17:13:51]DEBUG : [somfy-357] 12170 Logging off during daemon_stop
0031|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Centralisation lumières from parent.
0032|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Centralisation volets from parent.
0033|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Couloir CHB-247752-357 from parent.
0034|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Couloir Entree-247755-357 from parent.
0035|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Cuisine-336905-357 from parent.
0036|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Garage-247753-357 from parent.
0037|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Centrale from parent.
0038|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Chambre from parent.
0039|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Clavier from parent.
0040|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Porte Entree from parent.
0041|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Porte fenetre from parent.
0042|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling S.A.M from parent.
0043|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Sirene Ext from parent.
0044|[2022-03-29 17:13:51]INFO : [somfy-357] 12170 Disabling Sirene Int from parent.
0045|[2022-03-29 17:13:51]DEBUG : [somfy-357] 12170 Logging off during daemon_stop
0046|[2022-03-29 17:13:51]DEBUG : [*-*] 12170 Daemon unlaunchable. Won't start (launchable=nok)
0047|[2022-03-29 17:13:51]DEBUG : [somfy-357] 12170 Running postsave method...
0048|[2022-03-29 17:13:51]DEBUG : [somfy-357] 12170 Logging off during daemon_stop
0049|[2022-03-29 17:13:51]DEBUG : [somfy-357] 12170 Logging off during daemon_stop
0050|[2022-03-29 17:13:51]DEBUG : [*-*] 12170 Daemon unlaunchable. Won't start (launchable=nok)
J’ai mis le plugin a jour git avec le nouveau lien pour les design.
