J’ai voulu réinstallé ce plugin sur ma smart et j’avais des erreurs d’installation des dépendances que j’ai réglée en modifiant la ligne 23 du fichier /plugins/brother/ressources/install_apt.sh comme cela (ajout de « –system… »):
try sudo -u www-data python3 -m venv $BASEDIR/venv --system-site-packages
Pour info le log lors de l’install défectueuse:
== Jeedom 4.4.8.1 smart in Debian GNU/Linux 10 (buster) on aarch64/arm64/64bits
== Python 3.7.3 (default, Mar 23 2024, 16:12:05) [GCC 8.3.0]
== brother v9 (2024-03-18 00:01:12) branch:stable
== 23/07/2024 12:18:59 == Dependencies installation for brother
[ 0% ] : Synchronize the package index...
[ 9% ] : Synchronize the package index : [ OK ]
[ 10% ] : Purge dynamic contents...
[ 29% ] : Purge dynamic contents : [ OK ]
[ 30% ] : Install python3 venv and pip debian packages...
[ 49% ] : Install python3 venv and pip debian packages : [ OK ]
[ 50% ] : Create a python3 Virtual Environment...
[ 69% ] : Create a python3 Virtual Environment : [ OK ]
[ 70% ] : Install required python3 libraries in venv...
[ 99% ] : Install required python3 libraries in venv : ERROR
[100% ] : Finished !
==KO== Installation Error
== ANALYSING ERRORS...
== NO KNOWN ERROR DETECTED
== Error in step : Install required python3 libraries in venv
== Line 26
== Command `sudo -u www-data /var/www/html/plugins/brother/resources/venv/bin/pip3 install --no-cache-dir -r /var/www/html/plugins/brother/resources/requirements.txt' have an issue
== Return code is 2
== Error message :
Collecting brother==1.0.2 (from -r /var/www/html/plugins/brother/resources/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/ae/db/da8c726d157a9f2cb8ccba1c5702db6e5607f206851a70ddd631ae3e1a6a/brother-1.0.2-py3-none-any.whl
Collecting pyasn1==0.4.8 (from -r /var/www/html/plugins/brother/resources/requirements.txt (line 2))
Downloading https://files.pythonhosted.org/packages/62/1e/a94a8d635fa3ce4cfc7f506003548d0a2447ae76fd5ca53932970fe3053f/pyasn1-0.4.8-py2.py3-none-any.whl (77kB)
Collecting requests==2.31.0 (from -r /var/www/html/plugins/brother/resources/requirements.txt (line 3))
Downloading https://files.pythonhosted.org/packages/70/8e/0e2d847013cb52cd35b38c009bb167a1a26b2ce6cd6965bf26b47bc0bf44/requests-2.31.0-py3-none-any.whl (62kB)
Collecting pysnmp (from brother==1.0.2->-r /var/www/html/plugins/brother/resources/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/1b/f9/9dbf762c9f3a80d600ccba79002d2a38b38badfa41fcbc9a522f586cfbc7/pysnmp-6.0.13-py3-none-any.whl (278kB)
Collecting idna<4,>=2.5 (from requests==2.31.0->-r /var/www/html/plugins/brother/resources/requirements.txt (line 3))
Downloading https://files.pythonhosted.org/packages/e5/3e/741d8c82801c347547f8a2a06aa57dbb1992be9e948df2ea0eda2c8b79e8/idna-3.7-py3-none-any.whl (66kB)
Collecting urllib3<3,>=1.21.1 (from requests==2.31.0->-r /var/www/html/plugins/brother/resources/requirements.txt (line 3))
Downloading https://files.pythonhosted.org/packages/d2/b2/b157855192a68541a91ba7b2bbcb91f1b4faa51f8bae38d8005c034be524/urllib3-2.0.7-py3-none-any.whl (124kB)
Collecting certifi>=2017.4.17 (from requests==2.31.0->-r /var/www/html/plugins/brother/resources/requirements.txt (line 3))
Downloading https://files.pythonhosted.org/packages/1c/d5/c84e1a17bf61d4df64ca866a1c9a913874b4e9bdc131ec689a0ad013fb36/certifi-2024.7.4-py3-none-any.whl (162kB)
Collecting charset-normalizer<4,>=2 (from requests==2.31.0->-r /var/www/html/plugins/brother/resources/requirements.txt (line 3))
Downloading https://files.pythonhosted.org/packages/28/76/e6222113b83e3622caa4bb41032d0b1bf785250607392e1b778aca0b8a7d/charset_normalizer-3.3.2-py3-none-any.whl (48kB)
Collecting pysmi<1.3.0,>=1.0.4 (from pysnmp->brother==1.0.2->-r /var/www/html/plugins/brother/resources/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/72/94/44c4c52a407c8241a8aaefe62acc9a5ad00a28a2c0339c22805b85a6272b/pysmi-1.2.1-py3-none-any.whl (79kB)
Collecting pysnmpcrypto<0.0.5,>=0.0.4 (from pysnmp->brother==1.0.2->-r /var/www/html/plugins/brother/resources/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/dd/ee/3ba0ddd4650ad5251479be614dacff65db920274f575825d48663a4ce7b9/pysnmpcrypto-0.0.4-py2.py3-none-any.whl
Collecting ply<4.0,>=3.11 (from pysmi<1.3.0,>=1.0.4->pysnmp->brother==1.0.2->-r /var/www/html/plugins/brother/resources/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/a3/58/35da89ee790598a0700ea49b2a66594140f44dec458c07e8e3d4979137fc/ply-3.11-py2.py3-none-any.whl (49kB)
Collecting cryptography; python_version >= "3.4" (from pysnmpcrypto<0.0.5,>=0.0.4->pysnmp->brother==1.0.2->-r /var/www/html/plugins/brother/resources/requirements.txt (line 1))
Downloading https://files.pythonhosted.org/packages/69/ec/9fb9dcf4f91f0e5e76de597256c43eedefd8423aa59be95c70c4c3db426a/cryptography-43.0.0.tar.gz (686kB)
Exception:
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/cli/base_command.py", line 143, in main
status = self.run(options, args)
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/commands/install.py", line 338, in run
resolver.resolve(requirement_set)
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/resolve.py", line 102, in resolve
self._resolve_one(requirement_set, req)
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/resolve.py", line 256, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
self.require_hashes
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 298, in prepare_linked_requirement
abstract_dist.prep_for_dist(finder, self.build_isolation)
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 100, in prep_for_dist
self.req.load_pyproject_toml()
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/req/req_install.py", line 428, in load_pyproject_toml
str(self)
File "/var/www/html/plugins/brother/resources/venv/lib/python3.7/site-packages/pip/_internal/pyproject.py", line 43, in load_pyproject_toml
pp_toml = pytoml.load(f)
File "/var/www/html/plugins/brother/resources/venv/share/python-wheels/pytoml-0.1.2-py2.py3-none-any.whl/pytoml/parser.py", line 303, in load
filename=fin.name)
File "/var/www/html/plugins/brother/resources/venv/share/python-wheels/pytoml-0.1.2-py2.py3-none-any.whl/pytoml/parser.py", line 370, in loads
toks.expect('=', 'expected_equals')
File "/var/www/html/plugins/brother/resources/venv/share/python-wheels/pytoml-0.1.2-py2.py3-none-any.whl/pytoml/parser.py", line 250, in expect
self.error(error_text)
File "/var/www/html/plugins/brother/resources/venv/share/python-wheels/pytoml-0.1.2-py2.py3-none-any.whl/pytoml/parser.py", line 253, in error
raise TomlError(message, self.pos[0][0], self.pos[0][1], self._filename)
pytoml.core.TomlError: /tmp/pip-install-8a3amsf7/cryptography/pyproject.toml(172, 5): expected_equals
Informations Jeedom Atlas
Core : 4.4.8.1 (V4-stable)
DNS Jeedom Atlas : oui
Plugin : Brother
Version : 2024-03-18 00:01:12 (stable)
