Prise Niko 17033505
J’ai bien réussi à inclure la prise Niko 17033505 dans le plugin zigbee. Plutôt pas mal, bonne qualité de fabrication. Par contre les valeurs de puissance, consommation, courant et tension remontées sont un peu farfelues. Par ailleurs un calcul rentré dans la configuration d’une commande (par exemple #value# / 100) n’est pas pris en compte. Quelqu’un a de l’expérience avec cette prise ?
Bonjour @swa009
est ce que tu peux mettre les infos brutes du modules afin de voir sa configuration ?
merci
Voici:
    "ieee": "d0:cf:5e:ff:fe:bd:3a:ff",
    "nwk": 52670,
    "status": 2,
    "lqi": "144",
    "rssi": "-64",
    "last_seen": "1640036046.6149724",
    "node_descriptor": "01:40:8e:5f:12:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 266,
            "profile_id": 260,
            "manufacturer": "NIKO NV",
            "model": "Connected socket outlet",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 1
                            "id": 2,
                            "name": "stack_version",
                            "value": 6
                            "id": 3,
                            "name": "hw_version",
                            "value": 5
                            "id": 4,
                            "name": "manufacturer",
                            "value": "NIKO NV"
                            "id": 5,
                            "name": "model",
                            "value": "Connected socket outlet"
                            "id": 6,
                            "name": "date_code",
                            "value": "20191128"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "313-286-00"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 1794,
                    "name": "Metering",
                    "attributes": [
                            "id": 0,
                            "name": "current_summ_delivered",
                            "value": 2638
                    "id": 2820,
                    "name": "Electrical Measurement",
                    "attributes": [
                            "id": 1285,
                            "name": "rms_voltage",
                            "value": 2320
                            "id": 1288,
                            "name": "rms_current",
                            "value": 0
                            "id": 1291,
                            "name": "active_power",
                            "value": 100
                    "id": 2821,
                    "name": "Diagnostic",
                    "attributes": []
                    "id": 64512,
                    "name": "Manufacturer Specific",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4703,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 266,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    2821,
                    64512
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Personne n’a d’expérience avec ce module ?
Pour ceux qui l’utilise, avez-vous une remontée de données correcte / cohérente ?
bonjour,
J’en ai 8 chez moi. Et effectivement, les données sont incohérentes.
Ok merci. Dommage pour un équipement qui d’apparence semble de très bonne qualité. Mais si pas capable d’avoir une donnée de consommation fiable, autant alors prendre un équipement basique à 10€ qui fait juste du on/off…
Le matériel Niko fonctionne sans passerelle Niko? Directement en Zigbee?
Si oui ce serait parfait pour moi, je suis partout en niko et j’ai 2-3 interrupteurs derrière lesquels il m’est difficile d’ajouter un module domotique.
Merci,
Ludo
