Pour faire suite au thread sur mes problèmes d’integration du Samjin Button ([Integration zigbee aeotec/samjin button - #7 par mizber])(Integration zigbee aeotec/samjin button - #7 par mizber), je reprends avec des informations propres.
J’utilise une passerelle Deconz USB connectée directement sur un Rasberry PI3+
Jeedom V 4.1.27
Plugin Zigbee à jour.
Site du Module:
https://aeotec.com/smartthings/zigbee-button.html
Configuration du Noeud:
"ieee": "28:6d:97:00:01:12:59:ea",
"nwk": 22965,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "02:40:80:41:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "Samjin",
"model": "button",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 2
"id": 1,
"name": "app_version",
"value": 17
"id": 3,
"name": "hw_version",
"value": 0
"id": 4,
"name": "manufacturer",
"value": "Samjin"
"id": 5,
"name": "model",
"value": "button"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": ""
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 27
"id": 33,
"name": "battery_percentage_remaining",
"value": 162
"id": 3,
"name": "Identify",
"attributes": []
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 2155
"id": 1280,
"name": "IAS Zone",
"attributes": []
"id": 2821,
"name": "Diagnostic",
"attributes": []
"signature": {
"model": "button",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4673,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
32,
1026,
1280,
2821
3,
25
"class": "zhaquirks.samjin.button"
Logs en Mode Debug:
lick Simple
[2021-10-23 13:00:42][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:42][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1 convert to 1
[2021-10-23 13:00:42][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-10-23 13:00:42][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-10-23 13:00:42][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"event":{"button_single":{"value":{"press_type":"single","command_id":0,"args":[1,0,0,0]},"cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:42][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_single::press_type => single convert to single
[2021-10-23 13:00:42][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-10-23 13:00:42][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_single::command_id => 0 convert to 0
[2021-10-23 13:00:42][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_single::args => Array convert to 1
Click Double
[2021-10-23 13:00:47][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_2","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:47][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_2 convert to 1
[2021-10-23 13:00:47][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-10-23 13:00:47][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-10-23 13:00:47][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-10-23 13:00:47][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"event":{"button_double":{"value":{"press_type":"double","command_id":0,"args":[2,0,0,0]},"cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:47][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_double::press_type => double convert to double
[2021-10-23 13:00:47][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_double::command_id => 0 convert to 0
[2021-10-23 13:00:47][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_double::args => Array convert to 1
Triple Click (Inutile je pense sur ce module)
[2021-10-23 13:00:55][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_2","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:55][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_2 convert to 1
[2021-10-23 13:00:55][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-10-23 13:00:55][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-10-23 13:00:55][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-10-23 13:00:55][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"event":{"button_double":{"value":{"press_type":"double","command_id":0,"args":[2,0,0,0]},"cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:55][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_double::press_type => double convert to double
[2021-10-23 13:00:55][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_double::command_id => 0 convert to 0
[2021-10-23 13:00:55][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_double::args => Array convert to 1
[2021-10-23 13:00:55][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:55][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1 convert to 1
[2021-10-23 13:00:55][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"event":{"button_single":{"value":{"press_type":"single","command_id":0,"args":[1,0,0,0]},"cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:00:55][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_single::press_type => single convert to single
[2021-10-23 13:00:55][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_single::command_id => 0 convert to 0
[2021-10-23 13:00:55][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_single::args => Array convert to 1
Appui/Click Long
[2021-10-23 13:01:03][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_2|Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:01:03][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_2|Alarm_1 convert to 1
[2021-10-23 13:01:03][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2021-10-23 13:01:03][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2021-10-23 13:01:03][DEBUG] : Search command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2021-10-23 13:01:03][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1280":{"event":{"button_hold":{"value":{"press_type":"hold","command_id":0,"args":[3,0,0,0]},"cluster_name":"IAS Zone"}}}}}}}
[2021-10-23 13:01:03][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_hold::press_type => hold convert to hold
[2021-10-23 13:01:03][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_hold::command_id => 0 convert to 0
[2021-10-23 13:01:03][DEBUG] : Search event command for 28:6d:97:00:01:12:59:ea logicalId : 1::1280::event::button_hold::args => Array convert to 1
Changement de thempérature
[2021-10-23 13:01:50][DEBUG] : {"devices":{"28:6d:97:00:01:12:59:ea":{"1":{"1026":[{"value":"2224","cluster_name":"Temperature Measurement"}]}}}}
[2021-10-23 13:01:50][DEBUG] : Search attribut for 28:6d:97:00:01:12:59:ea logicalId : 1::1026::0 => 2224 convert to 2224
