Plus de Zwave, installation dépendance KO
Depuis plusieurs jours impossible de Controller mes équipement Zwave.
Quand je vais vérifier le plugin les dépendances sont en KO et l’installation n’aboutie pas.
VOici les log que j’ai :
+ echo 8
+ sudo pip2 install --force-reinstall --upgrade requests
Collecting requests
Using cached https://files.pythonhosted.org/packages/2d/61/08076519c80041bc0ffa1a8af0cbd3bf3e2b62af10435d269a9d0f40564d/requests-2.27.1-py2.py3-none-any.whl
Collecting idna<3,>=2.5; python_version < "3" (from requests)
Using cached https://files.pythonhosted.org/packages/a2/38/928ddce2273eaa564f6f50de919327bf3a00f091b5baba8dfa9460f3a8a8/idna-2.10-py2.py3-none-any.whl
Collecting urllib3<1.27,>=1.21.1 (from requests)
Using cached https://files.pythonhosted.org/packages/33/cf/8435d5a7159e2a9c83a95896ed596f68cf798005fe107cc655b5c5c14704/urllib3-1.26.20-py2.py3-none-any.whl
Collecting certifi>=2017.4.17 (from requests)
Using cached https://files.pythonhosted.org/packages/37/45/946c02767aabb873146011e665728b680884cd8fe70dde973c640e45b775/certifi-2021.10.8-py2.py3-none-any.whl
Collecting chardet<5,>=3.0.2; python_version < "3" (from requests)
Using cached https://files.pythonhosted.org/packages/19/c7/fa589626997dd07bd87d9269342ccb74b1720384a4d739a1872bd84fbe68/chardet-4.0.0-py2.py3-none-any.whl
Installing collected packages: idna, urllib3, certifi, chardet, requests
Found existing installation: idna 2.10
Uninstalling idna-2.10:
Successfully uninstalled idna-2.10
Found existing installation: urllib3 1.26.20
Uninstalling urllib3-1.26.20:
Successfully uninstalled urllib3-1.26.20
Found existing installation: certifi 2021.10.8
Uninstalling certifi-2021.10.8:
Successfully uninstalled certifi-2021.10.8
Found existing installation: chardet 4.0.0
Uninstalling chardet-4.0.0:
Successfully uninstalled chardet-4.0.0
Found existing installation: requests 2.27.1
Uninstalling requests-2.27.1:
Successfully uninstalled requests-2.27.1
Successfully installed certifi-2021.10.8 chardet-4.0.0 idna-2.10 requests-2.27.1 urllib3-1.26.20
+ echo 9
+ sudo pip2 install --force-reinstall --upgrade setuptools
Collecting setuptools
Using cached https://files.pythonhosted.org/packages/e1/b7/182161210a13158cd3ccc41ee19aadef54496b74f2817cc147006ec932b4/setuptools-44.1.1-py2.py3-none-any.whl
Installing collected packages: setuptools
Found existing installation: setuptools 44.1.1
Uninstalling setuptools-44.1.1:
Successfully uninstalled setuptools-44.1.1
Successfully installed setuptools-44.1.1
+ echo 10
+ sudo pip2 install --force-reinstall --upgrade pyserial
Collecting pyserial
Using cached https://files.pythonhosted.org/packages/07/bc/587a445451b253b285629263eb51c2d8e9bcea4fc97826266d186f96f558/pyserial-3.5-py2.py3-none-any.whl
Installing collected packages: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 11
+ sudo pip2 install --force-reinstall --upgrade six
Collecting six
Using cached https://files.pythonhosted.org/packages/b7/ce/149a00dd41f10bc29e5921b496af8b574d8413afcd5e30dfa0ed46c2cc5e/six-1.17.0-py2.py3-none-any.whl
Installing collected packages: six
Found existing installation: six 1.17.0
Uninstalling six-1.17.0:
Successfully uninstalled six-1.17.0
Successfully installed six-1.17.0
+ echo 12
+ sudo pip2 install --force-reinstall --upgrade tornado
Collecting tornado
Collecting singledispatch (from tornado)
Using cached https://files.pythonhosted.org/packages/3f/09/2a17c6505a8373229cb3de6161e3af74ff90afcf4516719aa6cf32fad151/singledispatch-3.7.0-py2.py3-none-any.whl
Collecting futures (from tornado)
Using cached https://files.pythonhosted.org/packages/d4/ea/9d513529a89bcbcd07c8acbac9eecfad29e7562e0b9d69d14f475987ad70/futures-3.4.0-py2-none-any.whl
Collecting backports-abc>=0.4 (from tornado)
Using cached https://files.pythonhosted.org/packages/7d/56/6f3ac1b816d0cd8994e83d0c4e55bc64567532f7dc543378bd87f81cebc7/backports_abc-0.5-py2.py3-none-any.whl
Collecting six (from singledispatch->tornado)
Installing collected packages: six, singledispatch, futures, backports-abc, tornado
Found existing installation: singledispatch 3.7.0
Uninstalling singledispatch-3.7.0:
Successfully uninstalled singledispatch-3.7.0
Found existing installation: futures 3.4.0
Uninstalling futures-3.4.0:
Successfully uninstalled futures-3.4.0
Found existing installation: backports-abc 0.5
Uninstalling backports-abc-0.5:
Successfully uninstalled backports-abc-0.5
Found existing installation: tornado 5.1.1
Uninstalling tornado-5.1.1:
Successfully uninstalled tornado-5.1.1
Successfully installed backports-abc-0.5 futures-3.4.0 singledispatch-3.7.0 six-1.17.0 tornado-5.1.1
+ echo 13
+ sudo chmod +x /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
Lancement de l'installation/mise à jour des dépendances openzwave
mkdir: cannot create directory ‘/opt’: File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
Not uninstalling cython at /usr/lib/python2.7/dist-packages, outside environment /usr
Can't uninstall 'Cython'. No files were found to uninstall.
apt-get install --force-yes -y cython
Reading package lists...
Building dependency tree...
Reading state information...
cython is already the newest version (0.29.2-2).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
W: --force-yes is deprecated, use one of the options starting with --allow instead.
Installing dependencies for python : 2 7 16
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
python-louie is already the newest version (1.1-4).
python-dev is already the newest version (2.7.16-1).
python-docutils is already the newest version (0.14+dfsg-4).
python-pip is already the newest version (18.1-5).
python-setuptools is already the newest version (40.8.0-1).
apt-get install --force-yes -y build-essential libudev-dev g++
build-essential is already the newest version (12.6).
g++ is already the newest version (4:8.3.0-1).
libudev-dev is already the newest version (241-7~deb10u10).
pip install nose-html
Requirement already satisfied: nose-html in /usr/local/lib/python2.7/dist-packages (1.1)
Requirement already satisfied: nose>=0.11.1 in /usr/lib/python2.7/dist-packages (from nose-html) (1.3.7)
pip install nose-progressive
Requirement already satisfied: nose-progressive in /usr/local/lib/python2.7/dist-packages (1.5.2)
Requirement already satisfied: nose>=1.2.1 in /usr/lib/python2.7/dist-packages (from nose-progressive) (1.3.7)
Requirement already satisfied: blessings<2.0,>=1.3 in /usr/local/lib/python2.7/dist-packages (from nose-progressive) (1.7)
Requirement already satisfied: six in /usr/local/lib/python2.7/dist-packages (from blessings<2.0,>=1.3->nose-progressive) (1.17.0)
pip install coverage
Requirement already satisfied: coverage in /usr/local/lib/python2.7/dist-packages (5.5)
pip install nose
Requirement already satisfied: nose in /usr/lib/python2.7/dist-packages (1.3.7)
pip install pylint
Collecting pylint
Using cached https://files.pythonhosted.org/packages/36/3b/fa4025a424adafd85c6195001b1c130ecb8d8b30784a1c4cb68e7b5e5ae7/pylint-1.9.5-py2.py3-none-any.whl
Requirement already satisfied: singledispatch; python_version < "3.4" in /usr/local/lib/python2.7/dist-packages (from pylint) (3.7.0)
Collecting mccabe (from pylint)
Using cached https://files.pythonhosted.org/packages/87/89/479dc97e18549e21354893e4ee4ef36db1d237534982482c3681ee6e7b57/mccabe-0.6.1-py2.py3-none-any.whl
Requirement already satisfied: configparser; python_version == "2.7" in /usr/lib/python2.7/dist-packages (from pylint) (3.5.0b2)
Collecting astroid<2.0,>=1.6 (from pylint)
Using cached https://files.pythonhosted.org/packages/8b/29/0f7ec6fbf28a158886b7de49aee3a77a8a47a7e24c60e9fd6ec98ee2ec02/astroid-1.6.6-py2.py3-none-any.whl
Collecting isort>=4.2.5 (from pylint)
Using cached https://files.pythonhosted.org/packages/e5/b0/c121fd1fa3419ea9bfd55c7f9c4fedfec5143208d8c7ad3ce3db6c623c21/isort-4.3.21-py2.py3-none-any.whl
Collecting backports.functools-lru-cache; python_version == "2.7" (from pylint)
Using cached https://files.pythonhosted.org/packages/08/e3/1387bd1c9aa95e354064ee29b8a1dfd3e795b066cc869af8f8d6b70ae4aa/backports.functools_lru_cache-1.6.6-py2.py3-none-any.whl
Requirement already satisfied: six in /usr/local/lib/python2.7/dist-packages (from pylint) (1.17.0)
Requirement already satisfied: enum34>=1.1.3; python_version < "3.4" in /usr/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.1.6)
Collecting lazy-object-proxy (from astroid<2.0,>=1.6->pylint)
Using cached https://files.pythonhosted.org/packages/6f/3e/7c80e8536b9d5eb66e784fff4c359adf9e55b37460fd6928192256ba71f2/lazy-object-proxy-1.7.0.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Complete output from command python setup.py egg_info:
running egg_info
creating pip-egg-info/lazy_object_proxy.egg-info
writing pip-egg-info/lazy_object_proxy.egg-info/PKG-INFO
writing top-level names to pip-egg-info/lazy_object_proxy.egg-info/top_level.txt
writing dependency_links to pip-egg-info/lazy_object_proxy.egg-info/dependency_links.txt
writing manifest file 'pip-egg-info/lazy_object_proxy.egg-info/SOURCES.txt'
File "<string>", line 1, in <module>
File "/tmp/pip-install-06L4t_/lazy-object-proxy/setup.py", line 146, in <module>
distclass=BinaryDistribution,
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/__init__.py", line 162, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 296, in run
self.find_sources()
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 303, in find_sources
mm.run()
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 534, in run
self.add_defaults()
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 570, in add_defaults
sdist.add_defaults(self)
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/command/py36compat.py", line 36, in add_defaults
self._add_defaults_ext()
File "/tmp/pip-build-env-z3tZGn/lib/python2.7/site-packages/setuptools/command/py36compat.py", line 118, in _add_defaults_ext
if self.distribution.has_ext_modules():
File "/tmp/pip-install-06L4t_/lazy-object-proxy/setup.py", line 70, in has_ext_modules
return super().has_ext_modules() or 'SETUP_PY_ALLOW_PURE' not in os.environ
TypeError: super() takes at least 1 argument (0 given)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-06L4t_/lazy-object-proxy/
make: *** [Makefile:163: tests-deps] Error 1
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Security.o
Building Proprietary.o
Building CentralScene.o
Building CommandClass.o
Building Meter.o
Building Indicator.o
Building SensorBinary.o
Building SwitchBinary.o
Building Configuration.o
Building SensorAlarm.o
Building ThermostatMode.o
Building SwitchToggleBinary.o
Building MultiInstance.o
Building TimeParameters.o
Building ClimateControlSchedule.o
Building Color.o
Building MeterPulse.o
Building BarrierOperator.o
Building ThermostatFanState.o
Building EnergyProduction.o
Building DoorLock.o
Building SwitchMultilevel.o
Building ApplicationStatus.o
Building Language.o
Building MultiChannelAssociation.o
Building Protection.o
Building ThermostatOperatingState.o
Building NodeNaming.o
Building DeviceResetLocally.o
Building WakeUp.o
Building BasicWindowCovering.o
Building ManufacturerProprietary.o
Building MultiCmd.o
Building Association.o
Building Hail.o
Building Lock.o
Building SceneActivation.o
Building UserCode.o
Building Powerlevel.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function ‘virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)’:
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: warning: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Wrestrict]
snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
Building AssociationCommandConfiguration.o
Building SensorMultilevel.o
Building Battery.o
Building ThermostatFanMode.o
Building CRC16Encap.o
Building Version.o
Building SoundSwitch.o
Building ZWavePlusInfo.o
Building Clock.o
Building Alarm.o
Building Basic.o
Building CommandClasses.o
Building ManufacturerSpecific.o
Building ThermostatSetpoint.o
Building NoOperation.o
Building SwitchAll.o
Building ControllerReplication.o
Building SwitchToggleMultilevel.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Controller.o
Building Wait.o
Building Thread.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++   -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
/usr/lib/python2.7/dist-packages/Cython/Compiler/Main.py:367: FutureWarning: Cython directive 'language_level' not set, using 2 for now (Py2). This will change in a later release! File: /opt/python-openzwave/src-lib/libopenzwave/libopenzwave.pyx
tree = Parsing.p_module(s, pxd, full_module_name)
building 'libopenzwave' extension
creating build
creating build/temp.linux-aarch64-2.7
creating build/temp.linux-aarch64-2.7/src-lib
creating build/temp.linux-aarch64-2.7/src-lib/libopenzwave
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/reproducible-path/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-aarch64-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:638:
openzwave/cpp/src/aes/aes.h:75: warning: ignoring #pragma warning  [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93: warning: ignoring #pragma warning  [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function ‘PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)’:
src-lib/libopenzwave/libopenzwave.cpp:30325:204: warning: ‘bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)’ is deprecated [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
In file included from src-lib/libopenzwave/libopenzwave.cpp:643:
openzwave/cpp/src/Manager.h:1731:19: note: declared here
DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
creating build/lib.linux-aarch64-2.7
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/reproducible-path/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/reproducible-path/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-aarch64-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-aarch64-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/egg
copying build/lib.linux-aarch64-2.7/libopenzwave.so -> build/bdist.linux-aarch64/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-aarch64/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-aarch64/egg
running install_data
creating build/bdist.linux-aarch64/egg/config
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
writing build/bdist.linux-aarch64/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.1-py2.7-linux-aarch64.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing libopenzwave-0.3.1-py2.7-linux-aarch64.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Extracting libopenzwave-0.3.1-py2.7-linux-aarch64.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Processing dependencies for libopenzwave==0.3.1
Searching for six==1.17.0
Best match: six 1.17.0
Adding six 1.17.0 to easy-install.pth file
Using /usr/local/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.1
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-aarch64-2.7/openzwave
creating build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/group.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/command.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/node.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/controller.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/network.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/value.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/option.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/__init__.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/object.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/scene.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/singleton.py -> build/bdist.linux-aarch64/egg/openzwave
byte-compiling build/bdist.linux-aarch64/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/command.py to command.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/value.py to value.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/option.py to option.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/object.py to object.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/singleton.py to singleton.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it
Processing openzwave-0.3.1-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Processing dependencies for openzwave==0.3.1
Searching for libopenzwave==0.3.1
Best match: libopenzwave 0.3.1
libopenzwave 0.3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Searching for Louie==1.1
Best match: Louie 1.1
Adding Louie 1.1 to easy-install.pth file
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for openzwave==0.3.1
Installation of API finished.
sed: can't read /boot/cmdline.txt: No such file or directory
sed: can't read /etc/inittab: No such file or directory
Everything is successfully installed!
+ echo 14
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end openzwave
+ echo 15
+ rm /tmp/jeedom_install_in_progress_openzwave
Avez vous une idée de ce qui cloche ?
Page Santé ?
Quelle version de Debian ?
Si pas en Debian 10 c’est normal.
Sur la page santé j’ai une erreur :
Echec de la requête http : http://127.0.0.1:8083/network?type=info&info=getHealth&apikey=kJbT47JnT8c2LrQL4esZjHy0d51kZ8YhNSV3X4lOv75PCkKU Curl error : Failed to connect to 127.0.0.1 port 8083: Connection refused
Debian apparemment en version 10.13 via la commande : cat /etc/debian_version
Quelle version de Jeedom ?
Cela peut se trouver sur la page du centre de mise à jour si la page Santé est HS.
Le problème est probablement plus général qu’openzwave.
Qui est obsolète donc les dépôts disparaissent ou se vident, et problème pour installer les dépendances de fait.
Je suis en Jeedom 4.5
donc faut que je reparte sur une installation neuve ?
Une installation qui utilise un debian plus récent, debian 11 à minima.
Mais il faudra changer certains plugin probablement, typiquement openzwave doit être remplacé par zwavejs.
Hello, tu dois avoir ça dans t’es logs :
Et ces dépôts ne sont plus servis sur security.debian/ ftp.uk.debian (404 + “no longer has a Release file”). En clair : ta version de Linux est EOL et tes sources APT doivent être soit migrées vers l’archive, soit tu dois mettre à niveau Debian.
Pour résoudre rapidement va dans http://IPJEEDOM/index.php?v=d&p=system et lance cette commande pour mettre les dépôts d’archive :sudo cp -a /etc/apt/sources.list /etc/apt/sources.list.bak.$(date +%F) && printf '%s\n' 'deb https://archive.debian.org/debian buster main contrib non-free' 'deb https://archive.debian.org/debian buster-updates main contrib non-free' 'deb https://archive.debian.org/debian-security buster/updates main contrib non-free' | sudo tee /etc/apt/sources.list >/dev/null && echo 'Acquire::Check-Valid-Until "false";' | sudo tee /etc/apt/apt.conf.d/99no-check-valid-until >/dev/null && sudo apt-get clean && sudo apt-get update
Ensuite tu reboot le système et tu relance une réinstallation des dépendances ;). Dommage que la MAJ Jeedom Core n’est pas intégré de base cette modif.
Merci pour les info, çà ne change rien, je vais partit pour une installation propre en dernière version.
Merci en tout cas
  • Se connecter en ssh sur le jeedom
  • Aller dans le répertoire /var/www/html/plugins/openzwave/ressouces
  • lancer l’installation avec sudo ./install_apt.sh
Si tout est ok, au bout de 5 minutes le daemon se lance
Foutu pour foutu …
Cordialement Michel
Je ne suis pas sur de comprendre le but des deux posts.
Debian V10 buster n’étant plus supporté, voici quelques pistes:
Il faut regarder les logs du daemon qui se relance toutes les 5 minutes, ils peuvent donner une indication sur l’origine du problème
Z-Wave (openzwave tourne sous python V2)
Une des pistes peut être un module python non installé. Voici la liste sur cette config qui a très peu d’autres modules en plus de z-wave:
pi@jeedom-ssd:~ $ pip list -v
Package                       Version   Location        Installer
asn1crypto                    0.24.0    /usr/lib/python2.7/dist-packages
backports-abc                 0.5       /usr/local/lib/python2.7/dist-packages                                           pip
backports.functools-lru-cache 1.5       /usr/lib/python2.7/dist-packages
beautifulsoup4                4.7.1     /usr/lib/python2.7/dist-packages
blessings                     1.7       /usr/local/lib/python2.7/dist-packages                                           pip
certifi                       2018.8.24 /usr/lib/python2.7/dist-packages
chardet                       3.0.4     /usr/lib/python2.7/dist-packages
configparser                  3.5.0b2   /usr/lib/python2.7/dist-packages
coverage                      5.5       /usr/local/lib/python2.7/dist-packages                                           pip
cryptography                  2.6.1     /usr/lib/python2.7/dist-packages
Cython                        0.29.2    /usr/lib/python2.7/dist-packages
docutils                      0.14      /usr/lib/python2.7/dist-packages
entrypoints                   0.3       /usr/lib/python2.7/dist-packages
enum34                        1.1.6     /usr/lib/python2.7/dist-packages
fasteners                     0.16.3    /usr/local/lib/python2.7/dist-packages                                           pip
future                        0.18.2    /usr/local/lib/python2.7/dist-packages                                           pip
futures                       3.3.0     /usr/local/lib/python2.7/dist-packages                                           pip
gpg                           1.12.0    /usr/lib/python2.7/dist-packages
gpiozero                      1.6.2     /usr/lib/python2.7/dist-packages
html5lib                      1.0.1     /usr/lib/python2.7/dist-packages
idna                          2.6       /usr/lib/python2.7/dist-packages
ipaddress                     1.0.17    /usr/lib/python2.7/dist-packages
keyring                       17.1.1    /usr/lib/python2.7/dist-packages
keyrings.alt                  3.1.1     /usr/lib/python2.7/dist-packages
libopenzwave                  0.3.1     /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Louie                         1.1       /usr/lib/python2.7/dist-packages
lxml                          4.3.2     /usr/lib/python2.7/dist-packages
monotonic                     1.6       /usr/local/lib/python2.7/dist-packages                                           pip
nose                          1.3.7     /usr/lib/python2.7/dist-packages
nose-html                     1.1       /usr/local/lib/python2.7/dist-packages                                           pip
nose-progressive              1.5.2     /usr/local/lib/python2.7/dist-packages                                           pip
olefile                       0.46      /usr/lib/python2.7/dist-packages
openzwave                     0.3.1     /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Pillow                        5.4.1     /usr/lib/python2.7/dist-packages
pip                           18.1      /usr/lib/python2.7/dist-packages
pycrypto                      2.6.1     /usr/lib/python2.7/dist-packages
Pygments                      2.3.1     /usr/lib/python2.7/dist-packages
PyGObject                     3.30.4    /usr/lib/python2.7/dist-packages
pyOpenSSL                     19.0.0    /usr/lib/python2.7/dist-packages
pyserial                      3.5       /usr/local/lib/python2.7/dist-packages                                           pip
pyudev                        0.23.2    /usr/local/lib/python2.7/dist-packages                                           pip
pyxdg                         0.25      /usr/lib/python2.7/dist-packages
requests                      2.27.1    /usr/local/lib/python2.7/dist-packages                                           pip
roman                         2.0.0     /usr/lib/python2.7/dist-packages
RPi.GPIO                      0.7.0     /usr/local/lib/python2.7/dist-packages
SecretStorage                 2.3.1     /usr/lib/python2.7/dist-packages
setuptools                    44.1.1    /usr/local/lib/python2.7/dist-packages                                           pip
singledispatch                3.7.0     /usr/local/lib/python2.7/dist-packages                                           pip
six                           1.16.0    /usr/local/lib/python2.7/dist-packages                                           pip
soupsieve                     1.8       /usr/lib/python2.7/dist-packages
spidev                        3.5       /usr/lib/python2.7/dist-packages
tornado                       5.1.1     /usr/local/lib/python2.7/dist-packages                                           pip
urllib3                       1.24.1    /usr/lib/python2.7/dist-packages
urwid                         2.1.2     /usr/local/lib/python2.7/dist-packages                                           pip
webencodings                  0.5.1     /usr/lib/python2.7/dist-packages
wheel                         0.37.1    /usr/local/lib/python2.7/dist-packages                                           pip
P.S. Installation effectuée en 2022
drwxr-sr-x 3 root staff 4096 févr. 8 2022 libopenzwave-0.3.1-py2.7-linux-armv7l.egg
drwxr-sr-x 4 root staff 4096 févr. 8 2022 openzwave-0.3.1-py2.7.egg
