Depuis le 14/10, je n’ai plus de retour SIA.
Tout fonctionne bien, j’ai l’impression que dans les logs, j’ai les éléments qui vont bien mais sur mon entité Hub, elles ne change pas !
Toute la partie SIA, ne change jamais…
[2022-10-29 10:46:05][DEBUG] : http://127.0.0.1:80 "POST /plugins/ajaxSystem/core/php/jeeAjaxSystemSia.php?apikey=2F001163B2xxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2022-10-29 10:46:05][DEBUG] : Incoming line: ACDA0077"*SIA-DCS"1091L0#55555[5497968AF1D678C17D55DE2CB71A0721937B6CDDEB4751AAA4CAEBC1A1D54CDFD165BEE2E015350D371139BA94E009D4
[2022-10-29 10:46:05][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '3', 'code': 'CG', 'message': '503', 'xdata': None, 'timestamp': '08:47:05,10-29-2022'}
[2022-10-29 10:46:05][DEBUG] : Got an event : {"message_type": "SIA-DCS", "receiver": null, "line": "L0", "account": "55555", "sequence": "1091", "content": "69v\u0016,|#55555|Nri3/CG503]_08:47:05,10-29-2022", "ti": null, "id": null, "ri": "3", "code": "CG", "message": "503", "x_data": null, "timestamp": "2022-10-29T08:47:05+00:00", "event_qualifier": null, "event_type": null, "partition": null, "extended_data": null, "sia_code": {"code": "CG", "type": "Close Area", "description": "System has been partially armed", "concerns": "Area number"}}
[2022-10-29 10:46:05][DEBUG] : Send to jeedom : {'devices': {'503': {'message_type': 'SIA-DCS', 'receiver': None, 'line': 'L0', 'account': '55555', 'sequence': '1091', 'content': '69v\x16,|#55555|Nri3/CG503]_08:47:05,10-29-2022', 'ti': None, 'id': None, 'ri': '3', 'code': 'CG', 'message': '503', 'x_data': None, 'timestamp': '2022-10-29T08:47:05+00:00', 'event_qualifier': None, 'event_type': None, 'partition': None, 'extended_data': None, 'sia_code': {'code': 'CG', 'type': 'Close Area', 'description': 'System has been partially armed', 'concerns': 'Area number'}}}}
[2022-10-29 10:46:05][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2022-10-29 10:46:07][DEBUG] : Incoming line: 51790077"*SIA-DCS"1092L0#55555[F9E1F79F693ACF3C6AB7E3B03B525D34A0C1094C5AED6EB1E45203B7661A1234A45AA495503497D1983B4A4F3A56DB62
[2022-10-29 10:46:07][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '0', 'code': 'RP', 'message': '0000', 'xdata': None, 'timestamp': '08:47:07,10-29-2022'}
[2022-10-29 10:47:07][DEBUG] : Incoming line: 5FF80077"*SIA-DCS"1093L0#55555[18E5CEA14805B56646ABBF24483860F6E531AE6161D72845AC8C8CEC0F7E129F59DBE36F45490BEEEE0852ACF58B1819
[2022-10-29 10:47:07][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '0', 'code': 'RP', 'message': '0000', 'xdata': None, 'timestamp': '08:48:07,10-29-2022'}
[2022-10-29 10:48:07][DEBUG] : Incoming line: BBF30077"*SIA-DCS"1094L0#55555[802EABDDF5C47705BB6D76432303177B77434EA496D07E318AC36AE40AB74C6CBD241C3BE98E27F0E2D2AE82BB0D05A4
[2022-10-29 10:48:07][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '0', 'code': 'RP', 'message': '0000', 'xdata': None, 'timestamp': '08:49:07,10-29-2022'}
[2022-10-29 10:49:07][DEBUG] : Incoming line: 132C0077"*SIA-DCS"1095L0#55555[3D4D6E9FC473048344ECDF073A21C4828DE4DF2A2117293B762B9B29765A706964933FF952041329C0D30A572944B630
[2022-10-29 10:49:07][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '0', 'code': 'RP', 'message': '0000', 'xdata': None, 'timestamp': '08:50:07,10-29-2022'}
[2022-10-29 10:50:06][DEBUG] : Incoming line: 9AF60077"*SIA-DCS"1096L0#55555[2640C7CA2CB4577BC3488658F838A363A82576C8815434033241C3E8C1D5D25011666C34150874ADF4A6074D6C0D8FFC
[2022-10-29 10:50:06][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '0', 'code': 'RP', 'message': '0000', 'xdata': None, 'timestamp': '08:51:07,10-29-2022'}
[2022-10-29 10:51:06][DEBUG] : Incoming line: 0CA90077"*SIA-DCS"1097L0#55555[7DE70A3363BA09E8691F6111CC5A6989C978573657B637E0C385F451B830DEAD3B552385F2BF4F6C3CC85D1A50CB0F5C
[2022-10-29 10:51:06][DEBUG] : Content matches: {'account': '55555', 'ti': None, 'id': None, 'ri': '0', 'code': 'RP', 'message': '0000', 'xdata': None, 'timestamp': '08:52:07,10-29-2022'}
et ce qui est étrange, c’est dans la configuration du plugin, dans la partie configuration quand je fais sauvegarde, j’ai une erreur 500 jeedom (en rouge) !
cf log ajaxSystem_packages
Installing collected packages: dataclasses-json, pysiaalarm
Attempting uninstall: dataclasses-json
Found existing installation: dataclasses-json 0.5.3
Uninstalling dataclasses-json-0.5.3:
Successfully uninstalled dataclasses-json-0.5.3
Attempting uninstall: pysiaalarm
Found existing installation: pysiaalarm 3.0.2
Uninstalling pysiaalarm-3.0.2:
Successfully uninstalled pysiaalarm-3.0.2
Successfully installed dataclasses-json-0.5.2 pysiaalarm-3.0.0b9
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 7
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end ajaxSystem
+ rm /tmp/jeedom_install_in_progress_ajaxSystem
Pour info, je suis en beta sur le plugin.
Si une bonne âme charitable peut m’aider ?
