J’aurais besoin d’un éclairage au niveau des logs de Jmqtt, je n’ai plus de remontées des clients
Log Jmqtttd:
[2022-11-20 20:00:55,548][INFO] JMsg.Snd MainThread sender_start() : Started
[2022-11-20 20:00:55,565][INFO] Main MainThread h_newClient() : Creating Client for Broker 747.
[2022-11-20 20:01:00,568][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:01:02,473][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:01:07,476][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:02:01,699][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:02:06,704][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:03:02,233][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:03:07,238][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:04:02,262][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:04:07,262][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:05:02,486][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:05:07,488][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:06:01,911][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:06:06,916][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
[2022-11-20 20:07:02,141][INFO] Main MainThread h_newClient() : Client already exists for Broker 747. Restarting it.
[2022-11-20 20:07:07,146][ERROR] Client747 MainThread start() : Could not start MQTT client: timed out
Log Jmqtt_local:
[2022-11-20 20:41:01][INFO] : Démarrage du Client MQTT
[2022-11-20 20:42:01][INFO] : Démarrage du Client MQTT
[2022-11-20 20:43:01][INFO] : Démarrage du Client MQTT
[2022-11-20 20:44:02][INFO] : Démarrage du Client MQTT
[2022-11-20 20:45:03][INFO] : Démarrage du Client MQTT
[2022-11-20 20:46:02][INFO] : Démarrage du Client MQTT
[2022-11-20 20:47:02][INFO] : Démarrage du Client MQTT
[2022-11-20 20:48:12][INFO] : Démarrage du Client MQTT
[2022-11-20 20:49:01][INFO] : Démarrage du Client MQTT
[2022-11-20 20:50:01][INFO] : Démarrage du Client MQTT
[2022-11-20 20:51:02][INFO] : Démarrage du Client MQTT
[2022-11-20 20:52:01][INFO] : Démarrage du Client MQTT
Log jmqtt deamon:
[2022-07-31 08:38:41,820][INFO] BrkId: 747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/Hygrometre/Temperature", "payload": "24.70", "qos": 0, "retain": false}
[2022-07-31 08:38:42,822][INFO] BrkId: 747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/Hygrometre/Humidity", "payload": "57.30", "qos": 0, "retain": false}
[2022-07-31 08:38:43,825][INFO] BrkId: 747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", "payload": "0", "qos": 0, "retain": false}
[2022-07-31 08:38:46,930][INFO] BrkId: 747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", "payload": "0", "qos": 0, "retain": false}
[2022-07-31 08:38:51,939][INFO] BrkId: 747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", "payload": "0", "qos": 0, "retain": false}
[2022-07-31 08:38:53,338][INFO] Stop jMQTT python daemon
[2022-07-31 08:38:53,427][INFO] BrkId: 747 : Disconnected from broker.
[2022-07-31 08:38:53,442][INFO] BrkId: 747 : Sending message to Jeedom : {"cmd":"connection","state":false}
[2022-07-31 08:38:53,451][INFO] BrkId: 747 : Disconnected from Jeedom
[2022-07-31 08:38:53,940][INFO] BrkId: 683 : Disconnected from Jeedom
