Suite à un crash de ma box luna j’ai du refaire une install sur un mini PVC à partir d’une sauvegarde
Depuis plus de mesure je ne comprend pas pourquoi peut être un problème dans le package des dépendances
log emporia
[2024-04-22 19:43:20] ERROR : Could not authenticate with Emporia API (err= get_customer_details() takes 1 positional argument but 2 were given)
Log emporia package
+ touch /tmp/jeedom_install_in_progress_emporiapro
+ echo 1
+ echo 2
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 3
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3
python3 is already the newest version (3.9.2-3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pip
python3-pip is already the newest version (20.3.4-4+deb11u1).
+ echo 5
++ find /usr/local/lib/python3.9/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 6
+ sudo pip3 cache purge
Files removed: 130
+ echo 7
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.9/dist-packages (24.0)
DEPRECATION: gpg 1.14.0-unknown has a non-standard version number. pip 24.1 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of gpg or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 8
+ sudo pip3 install --force-reinstall --upgrade pyudev
Collecting pyudev
Downloading pyudev-0.24.1-py3-none-any.whl.metadata (4.6 kB)
Downloading pyudev-0.24.1-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.9/62.9 kB 2.3 MB/s eta 0:00:00
Installing collected packages: pyudev
Attempting uninstall: pyudev
Found existing installation: pyudev 0.24.1
Uninstalling pyudev-0.24.1:
Successfully uninstalled pyudev-0.24.1
Successfully installed pyudev-0.24.1
+ echo 9
+ sudo pip3 install --force-reinstall --upgrade pyserial
Collecting pyserial
Downloading pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB)
Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 90.6/90.6 kB 3.1 MB/s eta 0:00:00
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 10
+ sudo pip3 install --force-reinstall --upgrade pyemvue
Collecting pyemvue
Downloading pyemvue-0.18.5-py3-none-any.whl.metadata (9.6 kB)
Collecting pycognito>=2024.2.0 (from pyemvue)
Downloading pycognito-2024.2.0-py3-none-any.whl.metadata (24 kB)
Collecting python-dateutil>=2.8.2 (from pyemvue)
Downloading python_dateutil-2.9.0.post0-py2.py3-none-any.whl.metadata (8.4 kB)
Collecting requests>=2.26.0 (from pyemvue)
Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
Collecting typing-extensions>=4.0.1 (from pyemvue)
Downloading typing_extensions-4.11.0-py3-none-any.whl.metadata (3.0 kB)
Collecting boto3>=1.10.49 (from pycognito>=2024.2.0->pyemvue)
Downloading boto3-1.34.88-py3-none-any.whl.metadata (6.6 kB)
Collecting envs>=1.3 (from pycognito>=2024.2.0->pyemvue)
Downloading envs-1.4-py3-none-any.whl.metadata (842 bytes)
Collecting pyjwt>=2.8.0 (from pyjwt[crypto]>=2.8.0->pycognito>=2024.2.0->pyemvue)
Downloading PyJWT-2.8.0-py3-none-any.whl.metadata (4.2 kB)
Collecting six>=1.5 (from python-dateutil>=2.8.2->pyemvue)
Downloading six-1.16.0-py2.py3-none-any.whl.metadata (1.8 kB)
Collecting charset-normalizer<4,>=2 (from requests>=2.26.0->pyemvue)
Downloading charset_normalizer-3.3.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (33 kB)
Collecting idna<4,>=2.5 (from requests>=2.26.0->pyemvue)
Downloading idna-3.7-py3-none-any.whl.metadata (9.9 kB)
Collecting urllib3<3,>=1.21.1 (from requests>=2.26.0->pyemvue)
Downloading urllib3-2.2.1-py3-none-any.whl.metadata (6.4 kB)
Collecting certifi>=2017.4.17 (from requests>=2.26.0->pyemvue)
Downloading certifi-2024.2.2-py3-none-any.whl.metadata (2.2 kB)
Collecting botocore<1.35.0,>=1.34.88 (from boto3>=1.10.49->pycognito>=2024.2.0->pyemvue)
Downloading botocore-1.34.88-py3-none-any.whl.metadata (5.7 kB)
Collecting jmespath<2.0.0,>=0.7.1 (from boto3>=1.10.49->pycognito>=2024.2.0->pyemvue)
Downloading jmespath-1.0.1-py3-none-any.whl.metadata (7.6 kB)
Collecting s3transfer<0.11.0,>=0.10.0 (from boto3>=1.10.49->pycognito>=2024.2.0->pyemvue)
Downloading s3transfer-0.10.1-py3-none-any.whl.metadata (1.7 kB)
Collecting cryptography>=3.4.0 (from pyjwt[crypto]>=2.8.0->pycognito>=2024.2.0->pyemvue)
Downloading cryptography-42.0.5-cp39-abi3-manylinux_2_28_x86_64.whl.metadata (5.3 kB)
Downloading urllib3-1.26.18-py2.py3-none-any.whl.metadata (48 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 48.9/48.9 kB 7.5 MB/s eta 0:00:00
Collecting cffi>=1.12 (from cryptography>=3.4.0->pyjwt[crypto]>=2.8.0->pycognito>=2024.2.0->pyemvue)
Downloading cffi-1.16.0-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (1.5 kB)
Collecting pycparser (from cffi>=1.12->cryptography>=3.4.0->pyjwt[crypto]>=2.8.0->pycognito>=2024.2.0->pyemvue)
Downloading pycparser-2.22-py3-none-any.whl.metadata (943 bytes)
Downloading pyemvue-0.18.5-py3-none-any.whl (17 kB)
Downloading pycognito-2024.2.0-py3-none-any.whl (26 kB)
Downloading python_dateutil-2.9.0.post0-py2.py3-none-any.whl (229 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 229.9/229.9 kB 6.8 MB/s eta 0:00:00
Downloading requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 6.2 MB/s eta 0:00:00
Downloading typing_extensions-4.11.0-py3-none-any.whl (34 kB)
Downloading boto3-1.34.88-py3-none-any.whl (139 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 139.3/139.3 kB 12.8 MB/s eta 0:00:00
Downloading certifi-2024.2.2-py3-none-any.whl (163 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 163.8/163.8 kB 11.5 MB/s eta 0:00:00
Downloading charset_normalizer-3.3.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (142 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 142.3/142.3 kB 11.7 MB/s eta 0:00:00
Downloading envs-1.4-py3-none-any.whl (10 kB)
Downloading idna-3.7-py3-none-any.whl (66 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.8/66.8 kB 3.9 MB/s eta 0:00:00
Downloading PyJWT-2.8.0-py3-none-any.whl (22 kB)
Downloading six-1.16.0-py2.py3-none-any.whl (11 kB)
Downloading botocore-1.34.88-py3-none-any.whl (12.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 12.2/12.2 MB 57.9 MB/s eta 0:00:00
Downloading urllib3-1.26.18-py2.py3-none-any.whl (143 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 143.8/143.8 kB 10.8 MB/s eta 0:00:00
Downloading cryptography-42.0.5-cp39-abi3-manylinux_2_28_x86_64.whl (4.6 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.6/4.6 MB 58.9 MB/s eta 0:00:00
Downloading jmespath-1.0.1-py3-none-any.whl (20 kB)
Downloading s3transfer-0.10.1-py3-none-any.whl (82 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 82.2/82.2 kB 5.9 MB/s eta 0:00:00
Downloading cffi-1.16.0-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (443 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 443.4/443.4 kB 33.8 MB/s eta 0:00:00
Downloading pycparser-2.22-py3-none-any.whl (117 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 117.6/117.6 kB 12.4 MB/s eta 0:00:00
Installing collected packages: urllib3, typing-extensions, six, pyjwt, pycparser, jmespath, idna, envs, charset-normalizer, certifi, requests, python-dateutil, cffi, cryptography, botocore, s3transfer, boto3, pycognito, pyemvue
Attempting uninstall: urllib3
Found existing installation: urllib3 1.26.18
Uninstalling urllib3-1.26.18:
Successfully uninstalled urllib3-1.26.18
Attempting uninstall: typing-extensions
Found existing installation: typing_extensions 4.11.0
Uninstalling typing_extensions-4.11.0:
Successfully uninstalled typing_extensions-4.11.0
Attempting uninstall: six
Found existing installation: six 1.16.0
Uninstalling six-1.16.0:
Successfully uninstalled six-1.16.0
Attempting uninstall: pyjwt
Found existing installation: PyJWT 2.8.0
Uninstalling PyJWT-2.8.0:
Successfully uninstalled PyJWT-2.8.0
Attempting uninstall: pycparser
Found existing installation: pycparser 2.22
Uninstalling pycparser-2.22:
Successfully uninstalled pycparser-2.22
Attempting uninstall: jmespath
Found existing installation: jmespath 1.0.1
Uninstalling jmespath-1.0.1:
Successfully uninstalled jmespath-1.0.1
Attempting uninstall: idna
Found existing installation: idna 3.7
Uninstalling idna-3.7:
Successfully uninstalled idna-3.7
Attempting uninstall: envs
Found existing installation: envs 1.4
Uninstalling envs-1.4:
Successfully uninstalled envs-1.4
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 3.3.2
Uninstalling charset-normalizer-3.3.2:
Successfully uninstalled charset-normalizer-3.3.2
Attempting uninstall: certifi
Found existing installation: certifi 2024.2.2
Uninstalling certifi-2024.2.2:
Successfully uninstalled certifi-2024.2.2
Attempting uninstall: requests
Found existing installation: requests 2.31.0
Uninstalling requests-2.31.0:
Successfully uninstalled requests-2.31.0
Attempting uninstall: python-dateutil
Found existing installation: python-dateutil 2.9.0.post0
Uninstalling python-dateutil-2.9.0.post0:
Successfully uninstalled python-dateutil-2.9.0.post0
Attempting uninstall: cffi
Found existing installation: cffi 1.16.0
Uninstalling cffi-1.16.0:
Successfully uninstalled cffi-1.16.0
Attempting uninstall: cryptography
Found existing installation: cryptography 42.0.5
Uninstalling cryptography-42.0.5:
Successfully uninstalled cryptography-42.0.5
Attempting uninstall: botocore
Found existing installation: botocore 1.34.88
Uninstalling botocore-1.34.88:
Successfully uninstalled botocore-1.34.88
Attempting uninstall: s3transfer
Found existing installation: s3transfer 0.10.1
Uninstalling s3transfer-0.10.1:
Successfully uninstalled s3transfer-0.10.1
Attempting uninstall: boto3
Found existing installation: boto3 1.34.88
Uninstalling boto3-1.34.88:
Successfully uninstalled boto3-1.34.88
Attempting uninstall: pycognito
Found existing installation: pycognito 2024.2.0
Uninstalling pycognito-2024.2.0:
Successfully uninstalled pycognito-2024.2.0
Attempting uninstall: pyemvue
Found existing installation: pyemvue 0.18.5
Uninstalling pyemvue-0.18.5:
Successfully uninstalled pyemvue-0.18.5
Successfully installed boto3-1.34.88 botocore-1.34.88 certifi-2024.2.2 cffi-1.16.0 charset-normalizer-3.3.2 cryptography-42.0.5 envs-1.4 idna-3.7 jmespath-1.0.1 pycognito-2024.2.0 pycparser-2.22 pyemvue-0.18.5 pyjwt-2.8.0 python-dateutil-2.9.0.post0 requests-2.31.0 s3transfer-0.10.1 six-1.16.0 typing-extensions-4.11.0 urllib3-1.26.18
+ echo 11
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end emporiapro
+ echo 12
+ rm /tmp/jeedom_install_in_progress_emporiapro
merci de votre aide
Informations Jeedom Luna
Core : 4.4.3 (V4-stable)
DNS Jeedom Luna : oui
Plugin : Emporia Energy
Version : 2023-05-23 14:30:18 (stable)
Statut Démon : Démarré - (2024-04-22 19:43:17)
