Désolé, voici les infos :
Configuration MQTT Manager :
Les logs de démarrage :
[2025-02-08 17:06:42] INFO : Start mqtt2d
[2025-02-08 17:06:42] INFO : Log level on : debug
[2025-02-08 17:06:42] INFO : Socket port : 55035
[2025-02-08 17:06:42] INFO : MQTT : mqtt://127.0.0.1:1883
[2025-02-08 17:06:42] INFO : Username :
[2025-02-08 17:06:42] INFO : Password :
[2025-02-08 17:06:42] INFO : Root topic : jeedom
[2025-02-08 17:06:42] INFO : PID file : /tmp/jeedom/mqtt2/deamon.pid
[2025-02-08 17:06:42] INFO : Apikey : iF8wlqyFXc9GPqTBEFn5r35HTfCnJ1DzoeERsrzmpnYMKKNInAIi9n3F9WIrVElY
[2025-02-08 17:06:42] INFO : Callback : http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php
[2025-02-08 17:06:42] INFO : Cycle : 0.3
[2025-02-08 17:06:42] INFO : Client key : undefined
[2025-02-08 17:06:42] INFO : Client crt : undefined
[2025-02-08 17:06:42] INFO : CA : undefined
[2025-02-08 17:06:42] INFO : Connect to mqtt server
[2025-02-08 17:06:42] DEBUG : HTTP listen on 127.0.0.1 port : 55035 started
[2025-02-08 17:06:42] INFO : Connection to mqtt server successfull
[2025-02-08 17:06:42] INFO : Subscription to all topics
[2025-02-08 17:06:42] INFO : Subscription to all topics succesfull
[2025-02-08 17:06:42] DEBUG : Received message on topic : jeedom/state => online
[2025-02-08 17:06:42] INFO : Subscription to SYS topic
[2025-02-08 17:06:42] DEBUG : Received message on topic : $SYS/broker/version => mosquitto version 2.0.11
[2025-02-08 17:06:42] DEBUG : Received message on topic : $SYS/broker/uptime => 242 seconds
La conf de ZwaveJS :
La log des dépendances :
+ touch /tmp/jeedom_install_in_progress_zwavejs
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ echo 'Pre installation de l'\''installation/mise à jour des dépendances zwavejs'
Pre installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
++ cd /var/www/html/core/class/../../plugins/zwavejs/resources
++ pwd
+ BASEDIR=/var/www/html/plugins/zwavejs/resources
+ cd /var/www/html/plugins/zwavejs/resources
+ source ../core/config/zwavejs.config.ini
+ echo 'Wanted Version: 9.20.0'
+ rm -R zwave-js-ui
+ git clone --branch v9.20.0 --depth 1 https://github.com/zwave-js/zwave-js-ui
Cloning into 'zwave-js-ui'...
Note: switching to 'bf3bdc3f13d903cf100b0ba9c3333101ffd29418'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
+ echo 'Pre install finished'
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
+ echo 4
apt: no process found
apt-get: no process found
+ sudo apt update
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [27.2 kB]
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
Fetched 27.2 kB in 2s (17.1 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 5
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
apt-utils is already the newest version (2.2.4).
lsb-release is already the newest version (11.1.0).
git is already the newest version (1:2.30.2-1+deb11u4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[Check Version NodeJS actuelle : v20.18.2 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Clean npm cache
npm warn using --force Recommended protections disabled.
+ echo 6
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ echo 'Post installation de l'\''installation/mise à jour des dépendances zwavejs'
Post installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
++ pwd
+ cd zwave-js-ui
+ sudo npm install
npm warn deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated docsify-server-renderer@4.13.1: docsify-server-renderer 4.x and below is no longer supported while we investigate the future of SSR and SSG for Docsify
npm warn deprecated csurf@1.11.0: Please use another csrf package
npm warn deprecated @types/extract-zip@2.0.1: This is a stub types definition. extract-zip provides its own type definitions, so you do not need this installed.
npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
npm warn deprecated @humanwhocodes/config-array@0.11.14: Use @eslint/config-array instead
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
npm warn deprecated vue@2.7.16: Vue 2 has reached EOL and is no longer actively maintained. See https://v2.vuejs.org/eol/ for more details.
added 1681 packages, and audited 1682 packages in 2m
335 packages are looking for funding
run `npm fund` for details
30 vulnerabilities (10 low, 14 moderate, 6 high)
To address issues that do not require attention, run:
npm audit fix
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
+ sudo npm run build
> zwave-js-ui@9.20.0 build
> npm-run-all 'build:*'
> zwave-js-ui@9.20.0 build:server
> tsc
> zwave-js-ui@9.20.0 build:ui
> vite build
vite v5.3.1 building for production...
transforming...
✓ 547 modules transformed.
rendering chunks...
computing gzip size...
dist/registerSW.js 0.14 kB
dist/manifest.webmanifest 0.50 kB
dist/index.html 1.69 kB │ gzip: 0.74 kB
dist/assets/MaterialIcons-Regular-DOtZ65Va.woff2 125.12 kB
dist/assets/MaterialIcons-Regular-BjXOXp5c.eot 143.45 kB
dist/assets/MaterialIcons-Regular-FsbMSDLx.woff 160.58 kB
dist/assets/MaterialIcons-Regular-DEUTIz1o.ttf 347.59 kB
dist/assets/DialogHealthCheck-Droliepd.css 0.04 kB │ gzip: 0.06 kB
dist/assets/DialogGatewayValue-A-SkCATO.css 0.06 kB │ gzip: 0.08 kB
dist/assets/NodeDetails-CBP3OPmg.css 0.06 kB │ gzip: 0.08 kB
dist/assets/FrameDetails-CIQ12EOu.css 0.07 kB │ gzip: 0.09 kB
dist/assets/QrReader-HjYxZaii.css 0.09 kB │ gzip: 0.10 kB
dist/assets/NodePanel-CZwLOHLG.css 0.09 kB │ gzip: 0.10 kB
dist/assets/RichValue-B_0TC6eQ.css 0.13 kB │ gzip: 0.12 kB
dist/assets/CCTreeView-WxmqzfXk.css 0.13 kB │ gzip: 0.12 kB
dist/assets/Settings-DbLZdPoT.css 0.15 kB │ gzip: 0.14 kB
dist/assets/Mesh-DSRRNttk.css 0.27 kB │ gzip: 0.21 kB
dist/assets/ValueId-C5xZLsvS.css 0.31 kB │ gzip: 0.18 kB
dist/assets/ExpandedNode--E63FB__.css 0.39 kB │ gzip: 0.26 kB
dist/assets/DialogAdvanced-B3IdLJdP.css 0.45 kB │ gzip: 0.23 kB
dist/assets/index-D5uuzJlz.css 0.51 kB │ gzip: 0.18 kB
dist/assets/Zniffer-BYjnQyPs.css 0.53 kB │ gzip: 0.24 kB
dist/assets/Store-DS7bGYpj.css 0.79 kB │ gzip: 0.33 kB
dist/assets/Multipane-CEm3CnxI.css 1.57 kB │ gzip: 0.46 kB
dist/assets/BgRssiChart-DbNj0r-M.css 1.65 kB │ gzip: 0.71 kB
dist/assets/Login-1yco1U5P.css 5.43 kB │ gzip: 1.52 kB
dist/assets/ZwaveGraph-Dfn_CqSH.css 220.21 kB │ gzip: 31.03 kB
dist/assets/index-r8JReBOx.css 645.00 kB │ gzip: 86.98 kB
dist/assets/MultipaneResizer-BWRp-8Tf.js 0.23 kB │ gzip: 0.20 kB
dist/assets/InvertedCheckbox-BKe96SLH.js 0.42 kB │ gzip: 0.30 kB
dist/assets/ControllerChart-7GxoToPo.js 0.63 kB │ gzip: 0.39 kB
dist/assets/ColumnFilterBoolean-Dlw5IVbg.js 0.67 kB │ gzip: 0.42 kB
dist/assets/ReinterviewBadge-P-jUEJlg.js 0.78 kB │ gzip: 0.52 kB
dist/assets/BlinkIcon-DP_t2iuE.js 0.85 kB │ gzip: 0.42 kB
dist/assets/ColumnFilterDate-DkQZJt-f.js 1.16 kB │ gzip: 0.56 kB
dist/assets/MissingKeysAlert-Bgdg8v4b.js 1.17 kB │ gzip: 0.56 kB
dist/assets/ColumnFilterString-BIwSCVLZ.js 1.22 kB │ gzip: 0.62 kB
dist/assets/DialogAdvanced-Bhs_8BWn.js 1.30 kB │ gzip: 0.68 kB
dist/assets/CCTreeView-ChRxhkA3.js 1.43 kB │ gzip: 0.77 kB
dist/assets/StatisticsArrows-BI8z0kpo.js 1.44 kB │ gzip: 0.77 kB
dist/assets/ErrorPage-CQyeMUEl.js 1.55 kB │ gzip: 0.79 kB
dist/assets/Multipane-DFLS9oP2.js 1.63 kB │ gzip: 0.82 kB
dist/assets/ColumnFilterNumber-eClVU_w_.js 1.74 kB │ gzip: 0.74 kB
dist/assets/file-input-B4SR49dD.js 1.83 kB │ gzip: 0.86 kB
dist/assets/RichValue-BRQppQoo.js 2.04 kB │ gzip: 0.87 kB
dist/assets/StatisticsCard-DqAruet3.js 2.55 kB │ gzip: 1.00 kB
dist/assets/FrameDetails-F6k0BPq5.js 2.68 kB │ gzip: 1.06 kB
dist/assets/DialogSceneValue-2Y04CTd_.js 3.18 kB │ gzip: 1.23 kB
dist/assets/Mesh-haZu0lAF.js 3.18 kB │ gzip: 1.36 kB
dist/assets/ColumnFilter-DoUVVYSw.js 3.26 kB │ gzip: 1.30 kB
dist/assets/UserCodeTable-Dz40xPSc.js 4.12 kB │ gzip: 1.64 kB
dist/assets/Login-DT9nslnM.js 4.13 kB │ gzip: 1.64 kB
dist/assets/ListInput-DK0gk4Ui.js 4.38 kB │ gzip: 1.41 kB
dist/assets/AssociationGroups-DGsCpLMi.js 4.46 kB │ gzip: 1.65 kB
dist/assets/OTAUpdates-BDNMxnyc.js 5.09 kB │ gzip: 2.09 kB
dist/assets/Scenes-HsjDySf8.js 5.81 kB │ gzip: 1.98 kB
dist/assets/DialogLinkReliability-3FOnnyOC.js 5.89 kB │ gzip: 1.91 kB
dist/assets/DialogAssociation-CvDSlRuw.js 5.94 kB │ gzip: 2.10 kB
dist/assets/prismeditor.esm-DJCfCG3y.js 7.58 kB │ gzip: 2.69 kB
dist/assets/NodeScheduler-qahfvCd7.js 7.86 kB │ gzip: 2.60 kB
dist/assets/HomeAssistant-CmWDVy9b.js 8.23 kB │ gzip: 2.43 kB
dist/assets/DialogGatewayValue-TQV4M_Uw.js 8.38 kB │ gzip: 2.56 kB
dist/assets/ControlPanel-CIT7JoKr.js 9.53 kB │ gzip: 3.53 kB
dist/assets/SmartView-VDBxTG-G.js 9.89 kB │ gzip: 3.30 kB
dist/assets/ValueId-Dzj-_hV-.js 10.45 kB │ gzip: 2.92 kB
dist/assets/Store-CE_bHZL9.js 10.95 kB │ gzip: 3.41 kB
dist/assets/NodeDetails-Dwklj2UX.js 12.18 kB │ gzip: 3.39 kB
dist/assets/DialogHealthCheck-DX70lQ06.js 12.38 kB │ gzip: 3.59 kB
dist/assets/SmartStart-DcNO40LA.js 13.83 kB │ gzip: 3.91 kB
dist/assets/ExpandedNode-Dip24ge3.js 15.15 kB │ gzip: 5.18 kB
dist/assets/Debug-0FVl0EX8.js 16.04 kB │ gzip: 4.18 kB
dist/assets/NodePanel-zK1ErbaX.js 16.11 kB │ gzip: 4.39 kB
dist/assets/Zniffer-DaFxRe8b.js 16.23 kB │ gzip: 5.28 kB
dist/assets/index-CGscpZTT.js 20.82 kB │ gzip: 6.13 kB
dist/assets/QrReader-C-Xpoqpd.js 20.89 kB │ gzip: 7.29 kB
dist/assets/qr-scanner-worker.min-D85Z9gVD.js 43.95 kB │ gzip: 10.46 kB
dist/assets/BgRssiChart-CjfwkkIu.js 54.97 kB │ gzip: 24.29 kB
dist/assets/vuedraggable.umd-BN2_1K0c.js 71.01 kB │ gzip: 24.88 kB
dist/assets/Settings-_GIJ6yNR.js 85.81 kB │ gzip: 19.99 kB
dist/assets/index-Blr6EMNg.js 91.82 kB │ gzip: 46.05 kB
dist/assets/ZwaveGraph-B7ZU-Qa8.js 560.41 kB │ gzip: 166.47 kB
dist/assets/index-arJYOLrt.js 1,237.32 kB │ gzip: 338.96 kB
(!) Some chunks are larger than 500 kB after minification. Consider:
- Using dynamic import() to code-split the application
- Use build.rollupOptions.output.manualChunks to improve chunking: https://rollupjs.org/configuration-options/#output-manualchunks
- Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
✓ built in 45.88s
PWA v0.20.0
Building src/sw.js service worker ("es" format)...
transforming...
✓ 65 modules transformed.
rendering chunks...
dist/sw.mjs 16.17 kB │ gzip: 5.42 kB
✓ built in 831ms
PWA v0.20.0
mode injectManifest
format: es
precache 82 entries (3262.43 KiB)
files generated
dist/sw.js
+ chown -R www-data:www-data CHANGELOG.md LICENSE README.md SECURITY.md api certs dist docker docs esbuild-register.js esbuild.js genereteDocs.ts index.html kubernetes kustomization.yaml node_modules nodemon.json package-lock.json package.json package.sh pkg public server server_config.js snippets src store test tsconfig.eslint.json tsconfig.json vite.config.mjs wallaby.js
+ '[' -e /dev/ttyAMA0 ']'
+ sudo sed -i 's/console=ttyAMA0,115200//; s/kgdboc=ttyAMA0,115200//' /boot/cmdline.txt
+ sudo sed -i 's|[^:]*:[^:]*:respawn:/sbin/getty[^:]*ttyAMA0[^:]*||' /etc/inittab
sed: can't read /etc/inittab: No such file or directory
+ '[' -e /dev/ttymxc0 ']'
+ sudo systemctl mask serial-getty@ttyAMA0.service
+ sudo systemctl stop serial-getty@ttyAMA0.service
++ grep Revision /proc/cpuinfo
++ cut -d: -f2
++ tr -d ' '
+ RPI_BOARD_REVISION=b03111
+ [[ b03111 == \a\0\2\0\8\2 ]]
+ [[ b03111 == \a\2\2\0\8\2 ]]
+ [[ b03111 == \a\0\2\0\d\3 ]]
+ echo 'Everything is successfully installed!'
+ echo 7
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zwavejs
+ echo 8
+ rm /tmp/jeedom_install_in_progress_zwavejs
La Log du démarrage du service :
> zwave-js-ui@9.20.0 start
> node --preserve-symlinks server/bin/www.js
e[90m2025-02-08 18:11:37.021e[39m e[32mINFOe[39m e[1mAPPe[22m: Version: 9.20.0.bf3bdc3
e[90m2025-02-08 18:11:37.030e[39m e[32mINFOe[39m e[1mAPPe[22m: Application path:/var/www/html/plugins/zwavejs/resources/zwave-js-ui
______ __ __ _ _____ _ _ _____
|___ / \ \ / / | |/ ____| | | | |_ _|
/ /____\ \ /\ / /_ ___ _____ | | (___ | | | | | |
/ /______\ \/ \/ / _' \ \ / / _ \ _ | |\___ \ | | | | | |
/ /__ \ /\ / (_| |\ V / __/ | |__| |____) | | |__| |_| |_
/_____| \/ \/ \__,_| \_/ \___| \____/|_____/ \____/|_____|
e[90m2025-02-08 18:11:37.062e[39m e[33mWARNe[39m e[1mSTOREe[22m: scenes.json not found
La log du zwavejs :
[2025-02-08 18:11:33] DEBUG : [configureSettings] Informations reçues de MQTT Manager : {"ip":"127.0.0.1","port":"1883","protocol":"mqtt","user":"","password":""}
[2025-02-08 18:11:33] INFO : Démarrage du démon ZwaveJS : STORE_DIR=/var/www/html/plugins/zwavejs/data/store KEY_S0_Legacy=245A854498EC51D88CBA644D07A5D82C KEY_S2_Unauthenticated=7EF4CF1FCABD9816ED19F327836FA7BE KEY_S2_Authenticated=7EAB30E7F3084A313054C5BCFF72554D KEY_S2_AccessControl=81F80CBACC0CE88DB964ED4AA79B493C SESSION_SECRET=jeedomSession npm start
Mon dongle est reconnu, mais pas de valeurs, ni de commande :
