J’ai remis l’adresse d’origine et depuis j’ai ca :
0243|[2025-03-05 14:38:00] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0244|[2025-03-05 14:38:01] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f36ab72e460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0245|[2025-03-05 14:38:05] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0246|[2025-03-05 14:38:08] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0247|[2025-03-05 14:38:13] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0248|[2025-03-05 14:38:24] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fafd30b3460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0249|[2025-03-05 14:38:28] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_1018) to end>
0250|[2025-03-05 14:38:29] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f0f353b4460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0251|[2025-03-05 14:38:30] ERROR : Previous call to python (InfosZonesE2_9715) is blocking other requests
0252|[2025-03-05 14:38:30] ERROR : Previous call to python (InfosZonesE2_9715) is blocking other requests
0253|[2025-03-05 14:38:31] ERROR : Previous call to python (InfosZonesE2_9715) is blocking other requests
0254|[2025-03-05 14:38:33] ERROR : Previous call to python (InfosZonesE2_9715) is blocking other requests
0255|[2025-03-05 14:38:33] ERROR : Previous call to python (InfosZonesE2_9715) is blocking other requests
0256|[2025-03-05 14:38:40] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f5d1d863460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0257|[2025-03-05 14:38:45] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fc948703460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0258|[2025-03-05 14:38:47] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_5398) to end>
0259|[2025-03-05 14:38:48] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0260|[2025-03-05 14:38:56] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0261|[2025-03-05 14:39:01] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7ff14440f460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0262|[2025-03-05 14:39:08] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_6719) to end>
0263|[2025-03-05 14:39:08] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_6719) to end>
0264|[2025-03-05 14:39:12] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f21b27fa460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0265|[2025-03-05 14:39:17] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f59458b3460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0266|[2025-03-05 14:39:21] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0267|[2025-03-05 14:39:32] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7ff4bf72c460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0268|[2025-03-05 14:39:34] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0269|[2025-03-05 14:39:35] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_8465) to end>
0270|[2025-03-05 14:39:35] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_8465) to end>
0271|[2025-03-05 14:39:35] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_8465) to end>
0272|[2025-03-05 14:39:36] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_8465) to end>
0273|[2025-03-05 14:39:36] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f4e01b3e460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0274|[2025-03-05 14:39:38] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0275|[2025-03-05 14:39:40] ERROR : Previous call to python (InfosZonesE2_2184) is blocking other requests
0276|[2025-03-05 14:39:40] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_2184) to end>
0277|[2025-03-05 14:39:42] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0278|[2025-03-05 14:39:43] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0279|[2025-03-05 14:39:47] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_3791) to end>
0280|[2025-03-05 14:39:51] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_3791) to end>
0281|[2025-03-05 14:39:51] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0282|[2025-03-05 14:39:52] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f3c67c66460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0283|[2025-03-05 14:40:01] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0284|[2025-03-05 14:40:06] ERROR : Previous call to python (InfosZonesE2_1663) is blocking other requests
0285|[2025-03-05 14:40:07] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7efe7ff06460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0286|[2025-03-05 14:40:11] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0287|[2025-03-05 14:40:13] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0288|[2025-03-05 14:40:17] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fe9a9738460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0289|[2025-03-05 14:40:21] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0290|[2025-03-05 14:40:21] ERROR : Error while iGetInformations : response was empty of malformed : <Timeout while waiting another python task (InfosZonesE2_4683) to end>
0291|[2025-03-05 14:40:29] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f4aacda8460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0292|[2025-03-05 14:40:37] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fef9e64a460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0293|[2025-03-05 14:40:38] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0294|[2025-03-05 14:40:40] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0295|[2025-03-05 14:40:45] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f50a718f460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0296|[2025-03-05 14:40:46] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0297|[2025-03-05 14:40:50] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0298|[2025-03-05 14:40:55] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f8a06b65460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0299|[2025-03-05 14:41:00] ERROR : Previous call to python (InfosZonesE2_6582) is blocking other requests
0300|[2025-03-05 14:41:06] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f2de5741460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0301|[2025-03-05 14:41:08] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0302|[2025-03-05 14:41:11] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fefa918d460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0303|[2025-03-05 14:41:21] ERROR : Previous call to python (InfosZonesE2_6487) is blocking other requests
0304|[2025-03-05 14:41:21] ERROR : Previous call to python (InfosZonesE2_6487) is blocking other requests
0305|[2025-03-05 14:41:24] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f910942d460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0306|[2025-03-05 14:41:28] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f20cbe2f460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0307|[2025-03-05 14:41:28] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0308|[2025-03-05 14:41:30] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0309|[2025-03-05 14:41:31] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0310|[2025-03-05 14:41:32] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0311|[2025-03-05 14:41:33] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0312|[2025-03-05 14:41:33] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0313|[2025-03-05 14:41:35] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0314|[2025-03-05 14:41:43] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0315|[2025-03-05 14:41:44] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0316|[2025-03-05 14:41:46] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f5049de5460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0317|[2025-03-05 14:41:46] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f9cb345e460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0318|[2025-03-05 14:41:47] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0319|[2025-03-05 14:41:48] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f5d2ddd0460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0320|[2025-03-05 14:41:48] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0321|[2025-03-05 14:41:52] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0322|[2025-03-05 14:41:52] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0323|[2025-03-05 14:42:07] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7ff87133f460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0324|[2025-03-05 14:42:09] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0325|[2025-03-05 14:42:10] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0326|[2025-03-05 14:42:24] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7ff5902ad460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0327|[2025-03-05 14:42:29] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"HTTPSConnectionPool(host='mytotalconnectcomfort.com', port=443): Max retries exceeded with url: \/Auth\/OAuth\/Token (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fcfdeb9b460>, 'Connection to mytotalconnectcomfort.com timed out. (connect timeout=15)'))"}>
0328|[2025-03-05 14:42:31] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
0329|[2025-03-05 14:42:32] ERROR : Error while iGetInformations : <{"success":false,"code":"Exception","message":"429 Client Error: Too Many Requests for url: https:\/\/mytotalconnectcomfort.com\/Auth\/OAuth\/Token"}>
2 messages tout les 10 mn
a partir de 14h34, 15 messages toute les minutes.
