Hello tout le monde,
Après avoir réinstallé un système frais sur ma nouvelle VM j’ai restauré ma sauvegarde Jeedom après avoir également réinstallé ce dernier.
Tou est ok SAUF openZwave (j’ai pas trop envie de passer sur le dernier plugin… tout reprendre, tout revoir, galérer avec les modules…bof)
Les dépendances s’installent mais voici ce que j’ai:
+ touch /tmp/jeedom_install_in_progress_openzwave
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
Lancement de l'installation/mise à jour des dépendances openzwave
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
/usr/local/lib/python3.9/dist-packages/pip/_vendor/pkg_resources/__init__.py:123: PkgResourcesDeprecationWarning: 1.14.0-unknown is an invalid version and will not be supported in a future release
warnings.warn(
WARNING: Skipping Cython as it is not installed.
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
apt-get install --force-yes -y cython
Reading package lists...
Building dependency tree...
Reading state information...
Package cython is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
W: --force-yes is deprecated, use one of the options starting with --allow instead.
E: Package 'cython' has no installation candidate
make: *** [Makefile:142: cython-deps] Error 100
Installing dependencies for python : 2 7 18
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
Package python-docutils is not available, but is referred to by another package.
Package python-pip is not available, but is referred to by another package.
However the following packages replace it:
python3-pip
E: Package 'python-pip' has no installation candidate
E: Package 'python-docutils' has no installation candidate
E: Unable to locate package python-louie
make: *** [Makefile:150: common-deps] Error 100
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxml.o
Building tinyxmlerror.o
Building tinyxmlparser.o
Building hid.o
Building aes_modes.o
Building aescrypt.o
Building aeskey.o
Building aestab.o
Building Alarm.o
Building ApplicationStatus.o
Building Association.o
Building AssociationCommandConfiguration.o
Building BarrierOperator.o
Building Basic.o
Building BasicWindowCovering.o
Building Battery.o
Building CRC16Encap.o
Building CentralScene.o
Building ClimateControlSchedule.o
Building Clock.o
Building Color.o
Building CommandClass.o
Building CommandClasses.o
Building Configuration.o
Building ControllerReplication.o
Building DeviceResetLocally.o
Building DoorLock.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function 'virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)':
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:14: warning: 'snprintf' argument 4 overlaps destination object 'usercode' [-Wrestrict]
312 | snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:307:9: note: destination object referenced by 'restrict'-qualified argument 1 was declared here
307 | char usercode[254];
Building EnergyProduction.o
Building Hail.o
Building Indicator.o
Building Language.o
Building Lock.o
Building ManufacturerProprietary.o
Building ManufacturerSpecific.o
Building Meter.o
Building MeterPulse.o
Building MultiChannelAssociation.o
Building MultiCmd.o
Building MultiInstance.o
Building NoOperation.o
Building NodeNaming.o
Building Powerlevel.o
Building Proprietary.o
Building Protection.o
Building SceneActivation.o
Building Security.o
Building SensorAlarm.o
Building SensorBinary.o
Building SensorMultilevel.o
Building SoundSwitch.o
Building SwitchAll.o
Building SwitchBinary.o
Building SwitchMultilevel.o
Building SwitchToggleBinary.o
Building SwitchToggleMultilevel.o
Building ThermostatFanMode.o
Building ThermostatFanState.o
Building ThermostatMode.o
Building ThermostatOperatingState.o
Building ThermostatSetpoint.o
Building TimeParameters.o
Building UserCode.o
Building Version.o
Building WakeUp.o
Building ZWavePlusInfo.o
Building Value.o
Building ValueBool.o
Building ValueButton.o
Building ValueByte.o
Building ValueDecimal.o
Building ValueInt.o
Building ValueList.o
Building ValueRaw.o
Building ValueSchedule.o
Building ValueShort.o
Building ValueStore.o
Building ValueString.o
Building Controller.o
Building Event.o
Building FileOps.o
Building HidController.o
Building Log.o
Building Mutex.o
Building SerialController.o
Building Stream.o
Building Thread.o
Building TimeStamp.o
Building Wait.o
Building EventImpl.o
Building FileOpsImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building ThreadImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building Driver.o
Building Group.o
Building Manager.o
Building Msg.o
Building Node.o
Building Notification.o
Building Options.o
Building Scene.o
Building Utils.o
Building ZWSecurity.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
File "setup-lib.py", line 26, in
from setuptools import setup, find_packages
ImportError: No module named setuptools
make: *** [Makefile:266: build] Error 1
Everything is successfully installed!
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end openzwave
+ rm /tmp/jeedom_install_in_progress_openzwave
Je comprends pas forcement tout, mais est-ce que python ou pip ne serait pas le fautif (veille version recherchée mais plus compatible?)
Merci d’avance pour vos aides.
