Le toggle est possible mais la faut je repasse sur toute les conf pas sur d’avoir le courage de le faire…
Bonjour Loic
mise à jour effectuée ce matin, les matériels Lidl sont plus nombreux par contre la simple prise SAPZ est reprise 2 fois et la multi SPSZ n’y est pas
edi : autant pour moi
, trop vite regardé, c est parfait avec les 3 interr de gérables, super !!
juste la fonction Etat qui bug
Erreur lors de la requete : http://127.0.0.1:8484/device/command(PUT), data : {"ieee":"bc:33:ac:ff:fe:XX:XX:XX","cmd":[{"endpoint":11,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"Endpoint not found : 11","code":0}
merci
Comme toujours sans le json je ne peux rien faire.
Ca sera disponible demain
LEDVANCE SMART+ JARDIN POLE
Dimmable toutes les couleurs
"ieee": "7c:b0:3e:aa:0a:07:8a:e9",
"nwk": 43297,
"status": 2,
"lqi": "151",
"rssi": "-75",
"last_seen": "1614758371.4213738",
"node_descriptor": "01:40:8e:aa:bb:40:00:00:00:00:00:00:03",
"endpoints": [
"id": 3,
"status": 1,
"device_type": 528,
"profile_id": 49246,
"manufacturer": "OSRAM",
"model": "Gardenpole RGBW-Lightify",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "OSRAM"
"id": 5,
"name": "model",
"value": "Gardenpole RGBW-Lightify"
"id": 6,
"name": "date_code",
"value": "20140331CNWT****"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "V1.04.93"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 254
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 24939
"id": 4,
"name": "current_y",
"value": 24701
"id": 7,
"name": "color_temperature",
"value": 370
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64527,
"name": "OsramLight",
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 48042,
"maximum_buffer_size": 64,
"maximum_incoming_transfer_size": 0,
"server_mask": 0,
"maximum_outgoing_transfer_size": 0,
"descriptor_capability_field": 3
"endpoints": {
"3": {
"device_type": 528,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64527
25
"class": "zhaquirks.osram.gardenpolesrgbw"
Ca sera disponible dans la beta de demain
J’imagine bien le taf que ça représente, sait-on jamais
Peut-être l’intégrer pour tes prochains saisies de type « éclairage ».
Merci et bonne journée
Si je le fait a un endroit je dois le faire partout sinon c’est pas propre…
@tous : avez vous remarqué des surconsommation de pile de certain module ?
Ok demain yaura une nouvelle version du plugin qui rajoute ca :
Pour l’instant c’est complexe (et ca le restera mais plus tard le plugin auto configurera ces champs). Pour ikea (télécommande) il faudrait mettre en long pool 1160. Source ici [Bug report / Enhancement request] Broken configuration and batteries draining of all IKEA controlling device · Issue #679 · zigpy/zigpy · GitHub
C’est du test car j’ai du ikea et pas soucis de batterie dessus…
« Configuration spécifique », manque le « o » ![]()
Oui !!
Sur les interrupteurs ikeas On/Off et parfois sur les 5 boutons .
La pile se vide en 24/48 heures parfois
@Loic, je viens de faire la mise à jour pour avoir le correctif des télécommandes Ikea, mais impossible de démarrer le démon sur mes 2 clés (EZSP et Zigate Wifi) et j’ai les logs c-dessous.
J’ai fait une restauration pour retrouver mes clés en attendant.
logs zigbeed_1
usage: zigbeed.py [-h] [--device DEVICE] [--loglevel LOGLEVEL]
[--callback CALLBACK] [--apikey APIKEY] [--cycle CYCLE]
[--pid PID] [--controller CONTROLLER]
[--sub_controller SUB_CONTROLLER]
[--data_folder DATA_FOLDER] [--device_folder DEVICE_FOLDER]
[--socketport SOCKETPORT] [--channel CHANNEL]
[--folder_OTA FOLDER_OTA]
[--zigpy_advance_config ZIGPY_ADVANCE_CONFIG]
zigbeed.py: error: argument --device_folder: expected one argument
zigbeed_2
Pareil… Je viens de faire la MAJ des dépendances au cas où…
Bonjour. Même problème ce matin. J’ai faire une restauration et c’est reparti.
J’avais fait une mise à jour des dépendances hier soir et pourtant démon NON OK avec mise à jour de ce matin…
Je viens de pousser la correction
