Ben yen a un c’est le log et l’autre c’est dans configuration sur le module onglet informations brute
Bonsoir Loic,
Ci-joint le fichier de log : zigbeed_1.log (57,9 Ko)
Ainsi que le log brut de ma vanne thermostatique Eurotronic Spirit:
"ieee": "00:15:8d:00:03:2f:6f:bf",
"nwk": 53815,
"status": 2,
"lqi": "255",
"rssi": "-60",
"last_seen": "1606151949.3959782",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:2c:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 769,
"profile_id": 260,
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 513,
"name": "ThermostatCluster",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"name": "manufacturer",
"value": "Eurotronic"
"id": 5,
"name": "model",
"value": "SPZB0001"
"id": 1,
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 513,
"attributes": [
"id": 18,
"name": "occupied_heating_setpoint",
"value": 1600
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"signature": {
"manufacturer_name": "Eurotronic",
"model": "SPZB0001",
"node_descriptor": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 100,
"1": {
"profileid": 260,
"deviceid": 769,
"in_clusters": [
0,
1,
3,
513,
25,
10
"out_clusters": [
0,
1,
3,
4,
513,
25,
10
"class": "zhaquirks.eurotronic.spzb0001"
J’en profite pour te soumettre un autre pb avec une autre vanne thermostatique que j’ai achetée pour essayer : (MOES Tuya HY368 - Zigbee Radiator Actuator) : Aucun souci pour l’insérer. Elle est d’ailleurs reconnue immédiatement et les commandes créées tout de suite. Par contre, les commandes ne marchent pas :
msg d’erreur ci-dessous :
Erreur exécution de la commande [CH Léonie][Vanne][Thermostat] : Erreur lors de la requete : http://127.0.0.1:8484/device/attributes(PUT), data : {"ieee":"5c:02:72:ff:fe:7f:7c:16","attributes":[{"endpoint":1,"cluster_type":"in","cluster":513,"attributes":{"18":100}}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : 513","code":0}
- Informations brutes qui me semblent trop succinctes pour que ca puisse fonctionner :
"ieee": "5c:02:72:ff:fe:7f:7c:16",
"nwk": 3700,
"status": 2,
"lqi": "175",
"rssi": "-72",
"last_seen": "1606152287.5881073",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"value": "_TZE200_ckud7u2l"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"signature": {
"manufacturer_name": "_TZE200_ckud7u2l",
"model": "TS0601",
"byte1": 2,
"byte2": 64,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"maximum_outgoing_transfer_size": 82,
"1": {
"profileid": 260,
"deviceid": 81,
"in_clusters": [
0,
4,
5,
61184
"out_clusters": [
25,
10
"class": "zigpy.device"
Merci pour tout
Norbert
Bonjour a tous
Voulant passer aussi sur ce plugin bêta que je viens de payer mais je but déjà sur la partie mise a jour des dépendances qui crash vers les 95%
Je suis sur Pi/Conbee II, Jeedom et Debian sont a jour … Une idée ?
Si l’on passe de deconz vers ce nouveau Plugin doit on ré-inclure les équipements ?
C’est quoi le gain à part l’inter compatibilité des dongles ?
Alors pour le pool en faite c’est normal elle en a pas c’est bizarre… Bon ben. Ma correction servira pour d’autres module mais pour toi non… Je vais voir comment prévoir ce cas là
Pour la 2eme vanne c’est normal elle est pas dans les quirks et en a absolument besoin. Ya tout un pr sur zha handler la dessus mais ya encore de nombreux soucis donc pas sur que ça soit disponible avant plusieurs mois…
Oui tu dois tout reinclure (en vrai des trucs vont apparaître mais ça marchera mal mieux vaut reinclure)
Pour l’intérêt c’est compliqué a terme il devrait être plus pour l’équipe jeedom en cas de soucis au lieu de vous dire faut attendre que deconz corrige
Comme toujours sans log je vois pas comment quelqu’un pourrait aider…
J’ai des volets profalux zigbee et télécommande générale zoe, philips hue motion et legrand fil pilote si vous avez besoin de log j’essaierai de monter une machine de test
Merci Loïc pour ton retour, voici les logs en mode debug pour zigbee_update, les deux autres sont restés vides !
Launch install of zigbee dependancy
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
Skipping serial as it is not installed.
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
The following package was automatically installed and is no longer required:
rpi-eeprom-images
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
python3 is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
python3-setuptools is already the newest version (40.8.0-1).
python3-pip is already the newest version (18.1-5+rpt1).
rpi-eeprom-images
Requirement already up-to-date: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
Requirement already up-to-date: zigpy in /usr/local/lib/python3.7/dist-packages (0.28.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.16.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.9.9)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.7.3)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (5.0.2)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (20.3.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (2.6)
Requirement already up-to-date: bellows in /usr/local/lib/python3.7/dist-packages (0.20.3)
Requirement already satisfied, skipping upgrade: pure-pcapy3==1.0.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (1.0.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from bellows) (0.4)
Requirement already satisfied, skipping upgrade: click-log==0.2.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.2.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from bellows) (0.12.0)
Requirement already satisfied, skipping upgrade: Click in /usr/local/lib/python3.7/dist-packages (from bellows) (7.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.21.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.28.0)
Requirement already satisfied, skipping upgrade: setuptools in /usr/local/lib/python3.7/dist-packages (from pure-pcapy3==1.0.1->bellows) (45.2.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->bellows) (3.5)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (3.9.9)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (0.16.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (3.7.3)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.21.0->bellows) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (5.0.2)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.0.4)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.0.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.21.0->bellows) (2.6)
Collecting git+https://github.com/jeedom/zha-device-handlers
Cloning https://github.com/jeedom/zha-device-handlers to /tmp/pip-req-build-tybd4vsl
Requirement already satisfied, skipping upgrade: zigpy>=0.22.1 in /usr/local/lib/python3.7/dist-packages (from zha-quirks==0.0.45) (0.28.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.1->zha-quirks==0.0.45) (3.7.3)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.1->zha-quirks==0.0.45) (3.9.9)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.1->zha-quirks==0.0.45) (0.16.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.1->zha-quirks==0.0.45) (0.12.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.1->zha-quirks==0.0.45) (1.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (20.3.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (3.0.1)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (3.7.4.3)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (5.0.2)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.1->zha-quirks==0.0.45) (2.6)
Building wheels for collected packages: zha-quirks
Running setup.py bdist_wheel for zha-quirks: started
Running setup.py bdist_wheel for zha-quirks: finished with status 'done'
Stored in directory: /tmp/pip-ephem-wheel-cache-45h6be7i/wheels/01/74/9a/a448b61fc9f718991eee86044ff5f6ec08b203b481a6ed7682
Successfully built zha-quirks
Installing collected packages: zha-quirks
Found existing installation: zha-quirks 0.0.45
Uninstalling zha-quirks-0.0.45:
Successfully uninstalled zha-quirks-0.0.45
Successfully installed zha-quirks-0.0.45
Requirement already up-to-date: zigpy_znp in /usr/local/lib/python3.7/dist-packages (0.2.2)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.12.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.4)
Requirement already satisfied, skipping upgrade: coloredlogs in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (14.0)
Requirement already satisfied, skipping upgrade: async-timeout in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (3.0.1)
Requirement already satisfied, skipping upgrade: zigpy>=0.25.0 in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.28.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy_znp) (3.5)
Requirement already satisfied, skipping upgrade: humanfriendly>=7.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->zigpy_znp) (8.2)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (3.9.9)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (3.7.3)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (0.16.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (1.0)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (5.0.2)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (3.0.4)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.25.0->zigpy_znp) (2.6)
Requirement already up-to-date: zigpy-xbee in /usr/local/lib/python3.7/dist-packages (0.13.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.4)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.28.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-xbee) (3.5)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.12.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.9.9)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.16.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.7.3)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (1.0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.0->zigpy-xbee) (3.7.4.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (20.3.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (1.6.3)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (5.0.2)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.0->zigpy-xbee) (2.6)
Requirement already up-to-date: zigpy-deconz in /usr/local/lib/python3.7/dist-packages (0.11.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.24.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.28.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.4)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (0.12.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (3.7.3)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (0.16.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (3.9.9)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-deconz) (3.5)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (5.0.2)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (20.3.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (1.6.3)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.7.4.3)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.0.4)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.24.0->zigpy-deconz) (2.6)
Requirement already up-to-date: zigpy-zigate in /usr/local/lib/python3.7/dist-packages (0.7.3)
Requirement already satisfied, skipping upgrade: pyusb in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (1.1.0)
Requirement already satisfied, skipping upgrade: RPi.GPIO in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.7.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.4)
Requirement already satisfied, skipping upgrade: zigpy>=0.22.2 in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.28.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-zigate) (3.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.16.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.12.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.7.3)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.9.9)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (1.0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.22.2->zigpy-zigate) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (5.0.2)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.2->zigpy-zigate) (2.6)
Requirement already up-to-date: zigpy-cc in /usr/local/lib/python3.7/dist-packages (0.5.2)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.1 in /usr/local/lib/python3.7/dist-packages (from zigpy-cc) (0.28.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-cc) (0.4)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (0.12.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (0.16.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (3.9.9)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (3.7.3)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-cc) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.1->zigpy-cc) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (1.6.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.0.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (5.0.2)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.1->zigpy-cc) (2.6)
Requirement already up-to-date: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
Everything is successfully installed!
Salut @TheAbdel
A ce rythme la molette de ma sourie ne va pas durée longtemps
Pourrait tu faire un effort en utilisant </> …
Vraiment désolé j’ai justement cherché comment faire ça…
PS : c’est corrigé !
J’ai des interrupteurs Tuya (des simples et un double).
Interrupteur simple : ZigBee Switch Without Neutral Wire Single Live Switch 1 Gang | Light Switches | Tuya Expo
Fichier Json
"ieee": "84:2e:14:ff:fe:e3:63:ba",
"nwk": 34654,
"status": 2,
"lqi": "255",
"rssi": "-58",
"last_seen": "1606236114.397561",
"node_descriptor": "02:40:80:02:10:52:00:02:00:2c:00:02:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 1,
"name": "app_version",
"value": 65
"id": 4,
"value": "_TYZB01_qeqvmvti"
"id": 5,
"name": "model",
"value": "TS0011"
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"signature": {
"manufacturer_name": "_TYZB01_qeqvmvti",
"model": "TS0011",
"byte1": 2,
"byte2": 64,
"maximum_incoming_transfer_size": 512,
"maximum_outgoing_transfer_size": 512,
"1": {
"profileid": 260,
"deviceid": 256,
"in_clusters": [
0,
4,
5,
6
"out_clusters": [
25
Ma configuration actuelle :
"name": "Interrupteur",
"ref" : "TS0011",
"buylink" : "",
"commands": [
"name": "Etat",
"type": "info",
"subtype": "binary",
"generic_type": "LIGHT_STATE",
"isVisible": 1,
"isHistorized": 1,
"logicalId": "1::6::0"
"name": "On",
"generic_type": "LIGHT_ON",
"type": "action",
"subtype": "other",
"isVisible": 1,
"isHistorized": 0,
"value" : "Etat",
"logicalId": "1::on_off::on",
"template":{
"dashboard" : "light",
"mobile" : "light"
"name": "Off",
"generic_type": "LIGHT_OFF",
"type": "action",
"subtype": "other",
"isVisible": 1,
"isHistorized": 0,
"value" : "Etat",
"logicalId": "1::on_off::off",
"template":{
"mobile" : "light"
Interrupteur double Push Button Zigbee Switch Without Neutral Wire Single Live Smart Switch 2 Gang | Light Switches | Tuya Expo
Fichier JSON
"ieee": "84:2e:14:ff:fe:e3:64:4e",
"nwk": 47842,
"status": 2,
"lqi": "255",
"rssi": "-40",
"last_seen": "1606235844.6604662",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 1,
"value": 65
"id": 4,
"value": "_TYZB01_vzrytttn"
"id": 5,
"name": "model",
"value": "TS0012"
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 2,
"status": 1,
"device_type": 256,
"profile_id": 260,
"output_clusters": [],
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"name": "off_wait_time",
"value": 0
"signature": {
"manufacturer_name": "_TYZB01_vzrytttn",
"model": "TS0012",
"byte1": 2,
"byte2": 64,
"1": {
"profileid": 260,
"deviceid": 256,
"in_clusters": [
0,
4,
5,
6
"out_clusters": [
25
"2": {
"profileid": 260,
"deviceid": 256,
"in_clusters": [
4,
5,
6
"out_clusters": []
"name": "Interrupteur double",
"ref" : "TS0012",
"buylink" : "",
"commands": [
"name": "Etat 1",
"type": "info",
"isVisible": 1,
"isHistorized": 1,
"name": "On 1",
"type": "action",
"subtype": "other",
"isVisible": 1,
"isHistorized": 0,
"value" : "Etat",
"template":{
"mobile" : "light"
"name": "Off 1",
"type": "action",
"subtype": "other",
"isVisible": 1,
"isHistorized": 0,
"value" : "Etat",
"template":{
"mobile" : "light"
"name": "Etat 2",
"type": "info",
"isVisible": 1,
"isHistorized": 1,
"logicalId": "2::6::0"
"name": "On 2",
"type": "action",
"subtype": "other",
"isVisible": 1,
"isHistorized": 0,
"value" : "Etat",
"logicalId": "2::on_off::on",
"template":{
"mobile" : "light"
"name": "Off 2",
"type": "action",
"subtype": "other",
"isVisible": 1,
"isHistorized": 0,
"value" : "Etat",
"logicalId": "2::on_off::off",
"template":{
"mobile" : "light"
c’est mon premier post , soyez indulgents
D’après ce que j’ai compris il faut poster le JSON - contenu de l’onglet [Informations brutes] dans Configuration
Dénomination: Hue White Candle E14
Image:
"ieee": "00:17:88:01:08:f0:03:32",
"nwk": 17772,
"status": 2,
"lqi": "199",
"rssi": "-69",
"last_seen": "1606238640.4976928",
"node_descriptor": "01:40:8e:0b:10:52:80:00:00:2c:80:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 257,
"profile_id": 260,
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"value": "Philips"
"id": 5,
"name": "model",
"value": "LWE002"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64514,
"name": "Manufacturer Specific",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"manufacturer_name": "Philips",
"model": "LWE002",
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4107,
"maximum_incoming_transfer_size": 128,
"maximum_outgoing_transfer_size": 128,
"11": {
"profileid": 260,
"deviceid": 257,
"in_clusters": [
0,
3,
4,
5,
6,
8,
4096,
64514
"out_clusters": [
25
"242": {
"profileid": 41440,
"deviceid": 97,
"in_clusters": [],
"out_clusters": [
33
Si cela convient, j’ai une ampoule E27 LW001 , un ruban led OSRAM ainsi qu’un contacteur Modulaire Legrand Jour/Nuit
Damien
En associant un commutateur Aqara Switch, j’ai ces commandes:
Je ne comprends pas, je m’attendais à quelque chose du type: clic, double_clic, long_clic
C’est normal?
Le bouton est bien configuré dans le plugin:
OUi c’est normal car comme toute télécommande Zigbee, cette dernière émet un code numérique représentatif
- du bouton sur lequel une action a été faite
- de l’action faite sur ce bouton.
Exemples
1002 : relâchè après appui bref sur le bouton 1
4003 : relâché après appui long sur le bouton 4
etc …
Du coup comment je fais avec mon bouton Aqara pour:
- Allumer le chauffage du bureau avec un appui bref ?
- Allumer le chauffage de la chambre avec un appui long ?
Je ne vois pas comment le faire.
Merci pour les configuration ca sera disponible dans la prochaine beta du plugin
Merci ca sera dans la prochaine beta du plugin
Merci pour les config, voici pour le contacteur:
Legrand Contacteur DRIVIA with Netatmo multifonction
L’image:
le fichier de config:
"ieee": "00:04:74:00:00:83:7a:7d",
"nwk": 48021,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "11:40:8e:21:10:59:3f:00:00:2a:3f:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 266,
"profile_id": 260,
"id": 0,
"name": "Basic",
"attributes": []
"id": 64513,
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"value": " Legrand"
"id": 5,
"name": "model",
"value": " Contactor"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 64513,
"attributes": []
"id": 2820,
"name": "Electrical Measurement",
"attributes": []
"id": 15,
"name": "Binary Input (Basic)",
"attributes": []
"id": 64577,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"id": 33,
"attributes": []
"signature": {
"manufacturer_name": " Legrand",
"model": " Contactor",
"byte1": 17,
"byte2": 64,
"manufacturer_code": 4129,
"maximum_buffer_size": 89,
"maximum_incoming_transfer_size": 63,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 63,
"1": {
"profileid": 260,
"deviceid": 266,
"in_clusters": [
0,
3,
4,
6,
5,
64513,
2820,
15,
64577
"out_clusters": [
0,
64513,
25
"242": {
"profileid": 41440,
"deviceid": 97,
"in_clusters": [],
"out_clusters": [
33
Pour L’ampoule Hue E27
Le nom:
[LWA001] Hue White Ambiance E27
L’image:
Le fichier:
"ieee": "00:17:88:01:08:29:53:5b",
"nwk": 4117,
"status": 2,
"lqi": "135",
"rssi": "-77",
"last_seen": "1606323580.4589944",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 257,
"profile_id": 260,
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"value": "Philips"
"id": 5,
"name": "model",
"value": "LWA001"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"attributes": []
"id": 4096,
"attributes": []
"id": 64514,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"id": 33,
"attributes": []
"signature": {
"model": "LWA001",
"byte1": 1,
"byte2": 64,
"11": {
"profileid": 260,
"deviceid": 257,
"in_clusters": [
0,
3,
4,
5,
6,
8,
4096,
64514
"out_clusters": [
25
"242": {
"profileid": 41440,
"deviceid": 97,
"in_clusters": [],
"out_clusters": [
33
