Bonjour, @Loic
Tu n’a pas répondu ici :
Je n’ai pas vu de double appui dans les log donc pas ajouté
Ok et pour les retombées d’état ?
J’ai repondu deja plus haut
pas trouvé bon tempi j’ai déjà un scenario pour dommage.
Bonjour Loic
Sur mon export du Plug Osram Extérieur, j’ai bien les infos manufacturer et model.
J’espère que tu pourras le rajouter. Merci
"ieee": "7c:b0:3e:aa:00:af:32:30",
"nwk": 60607,
"status": 2,
"lqi": "63",
"rssi": "-86",
"last_seen": "1614017600.2734919",
"node_descriptor": "01:40:8e:aa:bb:40:00:00:00:00:00:00:03",
"endpoints": [
"id": 3,
"status": 1,
"device_type": 16,
"profile_id": 49246,
"manufacturer": "OSRAM",
"model": "Plug 01",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 144
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "OSRAM"
"id": 5,
"name": "model",
"value": "Plug 01"
"id": 6,
"name": "date_code",
"value": "20140331DEOS****"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "V1.04.90"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64527,
"name": "Manufacturer Specific",
"attributes": []
"signature": {
"model": "Plug 01",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 48042,
"maximum_buffer_size": 64,
"maximum_incoming_transfer_size": 0,
"server_mask": 0,
"maximum_outgoing_transfer_size": 0,
"descriptor_capability_field": 3
"endpoints": {
"3": {
"device_type": 16,
"input_clusters": [
0,
3,
4,
5,
6,
4096,
64527
25
"class": "zhaquirks.osram.osramplug"
cela ressemble a ce model de chez ledvance qui est en ZLL
actuellement j’utilise cette configue, j’arrive a faire le on-off mais pas de retour d’état
en espérant que avec ton retour @Loic puisse l’intégrer
j’ai une sirene Heiman qui remonte mais n’est pas reconnue.
Si vous pouvez l’ajouter :
et le json
"ieee": "00:0d:6f:00:13:1a:cb:0b",
"nwk": 3421,
"status": 2,
"lqi": "132",
"rssi": "-62",
"last_seen": "1614023897.002188",
"node_descriptor": "01:40:8e:0b:12:52:52:00:00:00:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1027,
"profile_id": 260,
"manufacturer": "Heiman",
"model": "WarningDevice",
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 1
"id": 1,
"value": 18
"id": 2,
"value": 2
"id": 3,
"value": 16
"id": 4,
"value": "Heiman"
"id": 5,
"name": "model",
"value": "WarningDevice"
"id": 6,
"value": "2018.03.21"
"id": 7,
"value": 129
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 37
"id": 33,
"name": "battery_percentage_remaining",
"value": 82
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": []
"id": 1282,
"name": "IAS Warning Device",
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4619,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 0,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
4,
9,
1280,
1282
3,
25
"class": "zigpy.device"
Merci beaucoup
Bonsoir @Loic,
Je viens de recevoir un Smart Dial référencé TERNCY-SD01, serait il possible de l’ajouter ? Le « Manufacturer » est « null », mais il semblerait que ça soit fabriqué par Xiaoyan. Il y a a priori des actions sur la rotation, et sur le clic.
"ieee": "00:0d:6f:00:16:73:d1:16",
"nwk": 32996,
"status": 2,
"lqi": "255",
"rssi": "-50",
"last_seen": "1614026955.6982696",
"node_descriptor": "02:40:80:28:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 498,
"profile_id": 260,
"manufacturer": null,
"model": "TERNCY-SD01",
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 5,
"name": "model",
"value": "TERNCY-SD01"
"id": 7,
"value": 3
"id": 1,
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 64716,
"name": "Terncy Raw cluster",
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4648,
"server_mask": 11264,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 498,
"input_clusters": [
0,
1,
3,
32,
64716
25
"class": "zhaquirks.terncy.sd01"
Voici l’image correspondante :
Merci d’avance.
C’est du zll (l’ancetre du zigbee) donc les retours d’état ne sont pas automatique (il faut interroger le module). Dans la beta de demain la commande refresh sera la et permettra de la faire
Ca sera disponible demain dans la beta
Il faudrait jouer avec le bouton et m’envoyer la log filtré zigbee (tout court) pour que je vois ce qu’il remonte.
Bonjour Loic,
Je suis au niveau « debug » niveau log, et j’ai pas grand chose qui sort, même si le témoin d’activité du module s’allume, et que la valeur « last seen » évolue:
[2021-02-23 15:58:09][DEBUG] : {"ieee":"00:0d:6f:00:16:73:d1:16"}
[2021-02-23 15:59:16][DEBUG] : {"ieee":"00:0d:6f:00:16:73:d1:16"}
[2021-02-23 15:59:31][DEBUG] : {"ieee":"00:0d:6f:00:16:73:d1:16","nwk":32996,"status":2,"lqi":"223","rssi":"-66","last_seen":"1614092244.3871684","node_descriptor":"02:40:80:28:12:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":498,"profile_id":260,"manufacturer":null,"model":"TERNCY-SD01","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":3},{"id":5,"name":"model","value":"TERNCY-SD01"},{"id":7,"name":"power_source","value":3}]},{"id":1,"name":"Power Configuration","attributes":[]},{"id":3,"name":"Identify","attributes":[]},{"id":32,"name":"Poll Control","attributes":[]},{"id":64716,"name":"Terncy Raw cluster","attributes":[]}]}],"signature":{"model":"TERNCY-SD01","node_desc":{"byte1":2,"byte2":64,"mac_capability_flags":128,"manufacturer_code":4648,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":498,"input_clusters":[0,1,3,32,64716],"output_clusters":[25]}}},"class":"zhaquirks.terncy.sd01"}
Ai-je un paramètre incorrect ? J’ai aussi des messages qui semblent être plus du contrôleur vers le module (voir zigbee.log (171,5 Ko) )
Merci pour votre aide.
Bon ben je pense c’est mort ca semble tout proprietaire…
Petite contribution a ajouter
"ieee": "01:12:4b:00:1c:2e:84:90",
"nwk": 54478,
"status": 2,
"lqi": "192",
"rssi": "-52",
"last_seen": "1614096963.2800467",
"node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "SZ",
"model": "Lamp_01",
"id": 0,
"name": "Basic",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 1
"id": 1,
"value": 1
"id": 3,
"value": 1
"id": 4,
"value": "SZ"
"id": 5,
"name": "model",
"value": "Lamp_01"
"id": 6,
"value": "20181107"
"id": 7,
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"signature": {
"model": "Lamp_01",
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 0,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"11": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
3,
4,
5,
6
0
Ca sera disponible dans la beta de demain. merci
Après avoir lu de bons commentaires j’ai acheté et reçu aujourd’hui des ampoules LEXMAN E27 RGB vendu ICI 12,90€ pièce par Leroy Merlin (compatible ENKI).
A première vue ces ampoules sont aussi puissantes en blanc qu’en couleur (ce qui n’est pas le cas des modèles Lidl équivalents). J’ai hâte de tester
Voici l’image détourée :
Et voici les informations brutes :
"ieee": "5c:02:72:ff:fe:2e:0a:db",
"nwk": 27945,
"status": 2,
"lqi": "172",
"rssi": "-57",
"last_seen": "1614102959.232533",
"node_descriptor": "01:40:8e:77:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 269,
"profile_id": 260,
"manufacturer": "Adeo",
"model": "LXEK-1",
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 1
"id": 2,
"value": 2
"id": 3,
"value": 1
"id": 4,
"value": "Adeo"
"id": 5,
"name": "model",
"value": "LXEK-1"
"id": 6,
"value": "20200526"
"id": 7,
"value": 1
"id": 16384,
"value": "2.4.0"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"id": 4096,
"attributes": []
"id": 64642,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "LXEK-1",
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4727,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 269,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64642
25
"242": {
"device_type": 97,
"input_clusters": [],
33
Merci @Loic
Bonjour, Loïc
Merci pour le spot Swing (TZ3000_40zcsvfv.TS0502A).
Il s’intègre maintenant directement et est bien reconnu.
Pourrais-tu faire une dernière correction : mettre le minimum de l’action de luminosité à 3 au lieu de 0.
Si on fait une mise à jour de luminosité à 0, 1 ou 2, elle est sans effet.
Elle ne fonctionne bien qu’à partir de 3.
Merci d’avance.
Ca sera bon dans la beta de demain merci pour le retour
