Puf suis vraiment nul ! je me mélange avec mes quelques périphérique zigbee sans photo .
J’ai modifié dans le poste plus haut .
Cette fois c’est la bonne
Merci pour ta patience
est il possible d’intégrer le XIAOMI AQARA - MICROMODULE ON/OFF ZIGBEE 3.0 2500W AVEC NEUTRE
Référence SSM-U01
"ieee": "54:ef:44:10:00:09:6b:a1",
"nwk": 33283,
"status": 2,
"lqi": "167",
"rssi": "-73",
"last_seen": "1613393347.3002105",
"node_descriptor": "01:40:8e:5f:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.switch.n0agl1",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 21
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.switch.n0agl1"
"id": 6,
"name": "date_code",
"value": "Aug 8 2020"
"id": 7,
"name": "power_source",
"value": 0
"id": 16384,
"name": "sw_build_id",
"value": ""
"id": 2,
"name": "Device Temperature",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 9,
"name": "Alarms",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 1794,
"name": "Metering",
"attributes": [
"id": 0,
"name": "current_summ_delivered",
"value": 0
"id": 2820,
"name": "Electrical Measurement",
"attributes": [
"id": 1291,
"name": "active_power",
"value": 0
"id": 64704,
"name": "Manufacturer Specific",
"attributes": []
"id": 41,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 18,
"name": "MultistateInput",
"attributes": [
"id": 85,
"name": "present_value",
"value": 0
"id": 21,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"name": "AnalogInput",
"attributes": []
"id": 31,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4447,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
2,
3,
4,
5,
6,
9,
10,
1794,
2820,
64704
25
"41": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
18
"21": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"31": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
}![aqara-micromodule-onoff-zigbee-30-2500w-avec-neutre|350x400](upload://pibOZTKOZ47iWmA9YAsaog5Lxg2.jpeg)
Bonjour Loic,
Depuis la dernière mise à jour j’ai remarqué un regression pour le capteur d’ouverture xiaomi, il ne me remonte plus l’état 0/1.
J’ai essayé avec le plugin deconz, cela fonctionne normalement. J’ai essayé de l’enlever de mon réseau rechager le plugin mais rien à faire.
"ieee": "00:15:8d:00:04:4f:bc:b5",
"nwk": 40056,
"status": 2,
"lqi": "207",
"rssi": "-68",
"last_seen": "1613395303.977865",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 24321,
"profile_id": 260,
"model": "lumi.sensor_magnet.aq2",
"id": 0,
"name": "BasicCluster",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 65535,
"attributes": []
"input_clusters": [
"id": 0,
"attributes": [
"id": 0,
"value": 1
"id": 1,
"value": 3
"id": 2,
"value": 2
"id": 3,
"value": 2
"id": 4,
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.sensor_magnet.aq2"
"id": 6,
"value": "20161128"
"id": 7,
"value": 3
"id": 16384,
"value": "3000-0001"
"id": 3,
"name": "Identify",
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 31
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 65535,
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
3,
1,
65535
0,
4,
6,
65535
"class": "zhaquirks.xiaomi.aqara.magnet_aq2"
merci de ton aide
Merci de mettre toute ce qui est demandé si vous voulez l’ajout d’un module. La je repond encore mais bien j’ignorerais juste le message
Aucun changement de notre coté sur le code du demon lui meme depuis plusieurs semaine. Pour avoir moi meme ces modules aucun soucis de fonctionnement dessus
merci du retour je continue les investigations
En zigbee les soucis c’est :
- Les piles => faut les changer
- Le routage qui merde => enlever remettre les piles aides
- Le module pas standard => rien a faire
désolé erreur de manipulation concernant le :
"nwk": 33283,
"status": 2,
"lqi": "175",
"rssi": "-72",
"last_seen": "1613397722.7286587",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 21
"id": 2,
"value": 0
"id": 3,
"value": 1
"id": 4,
"value": "LUMI"
"id": 5,
"name": "model",
"id": 6,
"id": 7,
"value": 0
"id": 16384,
"value": ""
"id": 2,
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 9,
"name": "Alarms",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 1794,
"name": "Metering",
"attributes": [
"id": 0,
"value": 0
"id": 2820,
"attributes": [
"id": 1291,
"value": 0
"id": 64704,
"attributes": []
"id": 41,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 18,
"attributes": [
"id": 85,
"value": 0
"id": 21,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"attributes": []
"id": 31,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"model": null,
"id": 33,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
2,
3,
4,
5,
6,
9,
10,
1794,
2820,
64704
25
"41": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
18
"21": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"31": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"242": {
"device_type": 97,
33
Ok la c’est tout bon ca sera dans la beta de demain
Est il prévu dans la doc : une référence des méthodes d’inclusion des modules ?
Sinon ce serait peut être une bonne idée de construire ça sur ce forum ?
Ca existe deja je le remplis quand on me donne les informations
@Loic ,
J’aurais un nouveau module dont je souhaite te demander l’intégration. Il s’agit d’une Multiprise 4 prises 10A + 2 prises USB technologie Tuya, où il semblerait que les 4 prises soient commandables individuellement, et les 2 ports USB ensemble (indépendamment des prises)
"ieee": "60:a4:23:ff:fe:4a:57:4c",
"nwk": 5303,
"status": 2,
"lqi": "255",
"rssi": "-62",
"last_seen": "1613402341.2868094",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": "_TZ3000_o005nuxx",
"model": "TS011F",
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 67
"id": 2,
"value": 0
"id": 3,
"value": 1
"id": 4,
"value": "_TZ3000_o005nuxx"
"id": 5,
"name": "model",
"value": "TS011F"
"id": 6,
"value": ""
"id": 7,
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 2,
"status": 1,
"device_type": 266,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 3,
"status": 1,
"device_type": 266,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 4,
"status": 1,
"device_type": 266,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 5,
"status": 1,
"device_type": 266,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"model": null,
"id": 33,
"attributes": []
"signature": {
"model": "TS011F",
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4098,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
0,
3,
4,
5,
6,
57344,
57345
25,
10
"2": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
3,
4,
5,
6,
57344,
57345
"3": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
3,
4,
5,
6,
57344,
57345
"4": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
3,
4,
5,
6,
57344,
57345
"5": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
3,
4,
5,
6,
57344,
57345
"242": {
"device_type": 97,
33
Voici l’image de ce produit :
Merci d’avance !
Non pas de pilotage independant des prise usb possible
Ca sera dans la beta de demain
Ah ok cool !
Tu as une liste des modules à compléter ?
Super merci !
Tous ceux qui n’ont pas d’info de pairing reset sur le site compatibility.jeedom.com… Soit a peut pret tous…
Bonjour @Loic,
Je pense que tu es passé au travers ma demande pour la sirène message numéro1402 .
Merci,
Bonjour Loic,
Peux-tu inclure ce module SWITCH LUMIERE
Vendeur : MOES
Modèle :TS0121
"ieee": "84:2e:14:ff:fe:fa:09:61",
"nwk": 58031,
"status": 2,
"lqi": "167",
"rssi": "-73",
"last_seen": "1613466045.1232913",
"node_descriptor": "01:40:8e:00:00:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TYZB01_iuepbmpv",
"model": "TS0121",
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 67
"id": 4,
"value": "_TYZB01_iuepbmpv"
"id": 5,
"name": "model",
"value": "TS0121"
"id": 7,
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 1794,
"name": "Metering",
"attributes": []
"id": 2820,
"attributes": []
"signature": {
"model": "TS0121",
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 0,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
3,
4,
5,
6,
1794,
2820
25
Photo :
Dominique
