C’est normal j’ai rajouté ca ce matin donc ca sera dispo demain
Ok je te fait un retour demain donc
Moi c’est les caméras .
juste pour comprendre
je fais un backup ce jour
je rajouter et supprime des équipements par la suite
ma clef ne fonctionne plus deux semaine après, j’en rachète une nouvelle de même type
je lance la restauration
j’ai quoi au final.
l’état de deux semaine avant ou l’etat de la veille.
est ce bien compatible avec ma clef. j ai pas l’impression
cela reste vide au niveau des log
je viens de me commander une clef Elelabs
Bonjour @Loic
Pour le module
il manque la commande 3::18::0 d’appui simultané sur les 2 boutons (both-single; both-double et both-long-press)
Informations brutes :
"ieee": "00:15:8d:00:04:0c:14:42",
"nwk": 6359,
"status": 2,
"lqi": "255",
"rssi": "-47",
"last_seen": "1613678357.301851",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.remote.b286acn01",
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 65535,
"name": "Manufacturer Specific",
"attributes": []
"id": 18,
"name": "MultistateInputCluster",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"input_clusters": [
"id": 0,
"name": "BasicCluster",
"attributes": [
"id": 1,
"name": "app_version",
"value": 9
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.remote.b286acn01"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 27
"id": 33,
"name": "battery_percentage_remaining",
"value": 0
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 65535,
"attributes": []
"id": 18,
"attributes": [
"id": 85,
"name": "present_value",
"value": 0
"id": 2,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": null,
"model": null,
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 18,
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 18,
"attributes": [
"id": 85,
"value": 0
"id": 3,
"status": 1,
"device_type": 6,
"profile_id": 260,
"model": null,
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 12,
"name": "AnalogInput",
"attributes": []
"id": 18,
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 18,
"attributes": [
"id": 85,
"value": 2
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
0,
1,
3,
25,
65535,
18
0,
3,
4,
5,
25,
65535,
18,
6
"2": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
3,
18
3,
4,
5,
18,
6
"3": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
3,
18
3,
4,
5,
12,
18,
6
"class": "zhaquirks.xiaomi.aqara.remote_b286acn01"
Les commandes à ajouter stp
Both_single
[2021-02-18 20:56:04][DEBUG] : {"devices":{"00:15:8d:00:04:0c:14:42":{"3":{"18":{"85":{"value":"1.0","cluster_name":"MultistateInputCluster"},"event":{"both_single":{"value":{"button":"both","press_type":"single","attr_id":85,"value":1},"cluster_name":"MultistateInputCluster"}},"0":{"value":"both_single","cluster_name":"MultistateInputCluster"}}}}}}
[2021-02-18 20:56:04][DEBUG] : Search attribut for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::85 => 1.0
[2021-02-18 20:56:04][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_single::button => both
[2021-02-18 20:56:04][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_single::press_type => single
[2021-02-18 20:56:04][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_single::attr_id => 85
[2021-02-18 20:56:04][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_single::value => 1
[2021-02-18 20:56:04][DEBUG] : Search attribut for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::0 => both_single
both_double
[2021-02-18 20:56:14][DEBUG] : {"devices":{"00:15:8d:00:04:0c:14:42":{"3":{"18":{"85":{"value":"2.0","cluster_name":"MultistateInputCluster"},"event":{"both_double":{"value":{"button":"both","press_type":"double","attr_id":85,"value":2},"cluster_name":"MultistateInputCluster"}},"0":{"value":"both_double","cluster_name":"MultistateInputCluster"}}}}}}
[2021-02-18 20:56:14][DEBUG] : Search attribut for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::85 => 2.0
[2021-02-18 20:56:14][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_double::button => both
[2021-02-18 20:56:14][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_double::press_type => double
[2021-02-18 20:56:14][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_double::attr_id => 85
[2021-02-18 20:56:14][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_double::value => 2
[2021-02-18 20:56:14][DEBUG] : Search attribut for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::0 => both_double
both_long press
[2021-02-18 20:56:20][DEBUG] : {"devices":{"00:15:8d:00:04:0c:14:42":{"3":{"18":{"85":{"value":"0.0","cluster_name":"MultistateInputCluster"},"event":{"both_long press":{"value":{"button":"both","press_type":"long press","attr_id":85,"value":0},"cluster_name":"MultistateInputCluster"}},"0":{"value":"both_long press","cluster_name":"MultistateInputCluster"}}}}}}
[2021-02-18 20:56:20][DEBUG] : Search attribut for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::85 => 0.0
[2021-02-18 20:56:20][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_long press::button => both
[2021-02-18 20:56:20][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_long press::press_type => long press
[2021-02-18 20:56:20][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_long press::attr_id => 85
[2021-02-18 20:56:20][DEBUG] : Search event command for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::event::both_long press::value => 1
[2021-02-18 20:56:20][DEBUG] : Search attribut for 00:15:8d:00:04:0c:14:42 logicalId : 3::18::0 => both_long press
Par avance merci
A toutes fins utiles ci-joint les infos brutes de l’ampoule E14 de chez Lexman (Leroy Merlin) identifiée sous la référence Adeo.LEXK-3
"ieee": "60:a4:23:ff:fe:8c:d2:9e",
"nwk": 9382,
"status": 2,
"lqi": "223",
"rssi": "-66",
"last_seen": "1613692818.4757686",
"node_descriptor": "01:40:8e:77:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 269,
"profile_id": 260,
"manufacturer": "Adeo",
"model": "LXEK-3",
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"value": "Adeo"
"id": 5,
"name": "model",
"value": "LXEK-3"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64642,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "LXEK-3",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4727,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 269,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64642
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Merci Loic
Tout cela sera documenté (en vrai ca l’est deja si vous allez voir le fichier de doc dans le plugin avec l’editeur de fichier). Mais pour resumé le backup n’est a faire que une fois dans toute la vie de la clef, il contient juste les clef du réseaux et non les modules connecté. Donc en gros une fois restaurer les modules vont se reconnecter tout seule. Coté plugin normalement pas de soucis il retrouvera ses petits.
Pour le backup qui fait rien je n’ai pas de clef ZNP donc je ne peux absolument pas tester il faudrait que quelqu’un fasse a la main les lignes de commandes fournis sur le wiki zigpy pour voir deja si ca marche.
Merci pour le retour ca sera dans la beta de demain
Merci pour la configuration ca sera dans la beta de demain
Bonjour Loîc
J’avais demandé ici (avant la création du blabla) plus d’info pour participer également au partage des json, hormis une critique, rien de constructif, alors désolé si je me trompe mais voici les miennes (qui me semble être différentes)
#1 Xiaomi Aqara simple avec Neutre
"ieee": "00:15:8d:00:02:28:9a:af",
"nwk": 35639,
"status": 2,
"lqi": "240",
"rssi": "-40",
"last_seen": "1613724997.3460734",
"node_descriptor": "01:40:8e:5f:11:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"model": "lumi.ctrl_ln1.aq1",
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"value": 92
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 18
"id": 4,
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.ctrl_ln1.aq1"
"id": 6,
"name": "date_code",
"value": "06-12-2020"
"id": 7,
"name": "power_source",
"value": 1
"id": 4,
"name": "Groups",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16,
"name": "BinaryOutput",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 1,
"attributes": []
"id": 2,
"name": "Device Temperature",
"attributes": []
"id": 2,
"status": 1,
"device_type": 9,
"profile_id": 260,
"model": null,
"id": 12,
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"input_clusters": [
"id": 12,
"attributes": [
"id": 85,
"value": 0
"id": 3,
"status": 1,
"device_type": 83,
"profile_id": 260,
"model": null,
"id": 12,
"attributes": []
"input_clusters": [
"id": 12,
"attributes": []
"id": 5,
"status": 1,
"device_type": 0,
"profile_id": 260,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 18,
"name": "MultistateInput",
"attributes": [
"id": 85,
"value": 1
"id": 16,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4447,
"server_mask": 0,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
4,
3,
6,
16,
5,
10,
1,
2
25,
10
"2": {
"profile_id": 260,
"device_type": 9,
"input_clusters": [
12
12,
4
"3": {
"profile_id": 260,
"device_type": 83,
"input_clusters": [
12
12
"5": {
"profile_id": 260,
"device_type": 0,
"input_clusters": [
18,
16
#2 Xiaomi Aqara double avec Neutre
"ieee": "00:15:8d:00:04:05:2d:33",
"nwk": 43142,
"status": 2,
"lqi": "144",
"rssi": "-64",
"last_seen": "1613724882.1663568",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"model": "lumi.ctrl_ln2.aq1",
"id": 10,
"name": "Time",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"attributes": [
"id": 0,
"value": 1
"id": 1,
"value": 1
"id": 2,
"value": 2
"id": 3,
"value": 18
"id": 4,
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.ctrl_ln2.aq1"
"id": 6,
"value": "06-11-2020"
"id": 1,
"attributes": []
"id": 2,
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 10,
"name": "Time",
"attributes": []
"id": 16,
"attributes": []
"id": 2,
"status": 1,
"device_type": 81,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16,
"attributes": []
"id": 3,
"status": 1,
"device_type": 9,
"profile_id": 260,
"model": null,
"id": 4,
"name": "Groups",
"attributes": []
"id": 12,
"attributes": []
"input_clusters": [
"id": 12,
"name": "AnalogInputCluster",
"attributes": [
"id": 85,
"value": 0
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"server_mask": 0,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
1,
2,
3,
4,
5,
6,
10,
16
10,
25
"2": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
6,
16
"3": {
"profile_id": 260,
"device_type": 9,
"input_clusters": [
12
4,
12
"class": "zhaquirks.xiaomi.aqara.ctrl_ln"
Ca sera bon demain pour le 1er, pour le deuxieme la configuration est deja la
Loic,
Peux-tu rajouter cette ampoule : GLEDOPTO LED 6W RGB + CCT
"ieee": "00:12:4b:00:1e:e9:c1:5e",
"nwk": 8962,
"status": 2,
"lqi": "180",
"rssi": "-52",
"last_seen": "1613726471.1481442",
"node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 528,
"profile_id": 49246,
"manufacturer": "GLEDOPTO",
"model": "GL-B-007Z",
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 1
"id": 1,
"value": 1
"id": 2,
"value": 2
"id": 3,
"value": 1
"id": 4,
"value": "GLEDOPTO"
"id": 5,
"name": "model",
"value": "GL-B-007Z"
"id": 6,
"value": "20131206"
"id": 7,
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.0.2"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"attributes": []
"id": 768,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 0,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"11": {
"device_type": 528,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768
"class": "zhaquirks.gledopto.soposhgu10"
Photo :
Je viens récemment de basculer sur un combo Conbee II / plugin Zigbee (auparavant, Zigate / Abeille) et je suis en train de réinclure tout mon petit écosystème Zigbee
Je tombe sur un souci pour des lampes Ikea, voici ce que j’obtiens pour le modèle Bulb E27 WS opal 980 lm
Erreur exécution de la commande [Lumières][Lampe salle à manger][Luminosité] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"90:fd:9f:ff:fe:e5:6d:66","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["338","0"]}],"allowQueue":false} erreur : {"state":"error","result":"int too big to convert","code":0}
à savoir que la commande ON/OFF fonctionne elle parfaitement, seules les commandes de choix de la température et de l’intensité génèrent un/ce message d’erreur.
Une idée ?
Quelques informations supplémentaires qui peuvent aider :
- ma version 4.2.1 de Jeedom
- j’ai d’autres lampes Ikea (ie d’autres modèles) qui sont complètement fonctionnelles, par exemple sur mes Bulb GU10 WW 400lm, la modification de l’intensité est ok.
D’avance merci et j’en profite pour dire à tous les contributeurs de ce plugin, vous assurez .
Ludo
Merci pour le retour ca sera disponible demain
Tu as essayé une valeur plus petite ?
J’ai les mêmes ampoules et cela fonctionne…par contre lors de la première création dans le plugin non et j’avais donné à Loic les valeurs mini et maxi des curseurs pour que ce soit ok. Je sais pas si depuis c’est pris en compte car je l’avais changé manuellement dans mon plugin et j’ai pas rechargé les commandes depuis.
Regarde si tu as les mêmes configurations de commande que moi
Par contre j’ai une clé EZSP et non Conbee II…
Loic,
j’ai redressé la photo, c’est peut-être mieux
Dominique
Bonjour @Loic
Toujours moi , mais ca va pas .
Dans Tuya , il y a DEUX LCA001 sirene avec des commandes de philips Hue ,donc a supprimer .
Et a ajouter :
Marque : Tuya
Model : TS0601 Sirene
"ieee": "5c:02:72:ff:fe:ce:a2:1f",
"nwk": 55671,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1027,
"profile_id": 260,
"manufacturer": "_TZE200_d0yu2xgi",
"model": "TS0601",
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 83
"id": 2,
"value": 0
"id": 3,
"value": 1
"id": 4,
"value": "_TZE200_d0yu2xgi"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 6,
"value": ""
"id": 7,
"value": 3
"id": 3,
"name": "Identify",
"attributes": []
"id": 61184,
"name": "Tuya Manufacturer Specicific",
"attributes": [
"id": 617,
"name": "temperature",
"value": 214
"id": 618,
"name": "humidity",
"value": 36
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 2140
"id": 1029,
"name": "Relative Humidity Measurement",
"attributes": [
"id": 0,
"value": 3600
"id": 6,
"name": "On\/Off",
"attributes": []
"signature": {
"model": "TS0601",
"node_desc": {
"byte1": 2,
"byte2": 64,
"manufacturer_code": 4098,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
3,
61184,
1026,
1029,
6
3,
25
"class": "zhaquirks.tuya.siren"
merci pour la piste
du coup c’est ce que je viens d’essayer suite à ton retour et celui d’@olivr2s, ça fonctionne pour moi en mettant au niveau des bornes 0 et 254.
J’ai en revanche un autre souci et je le mets pour info, il faut des valeurs entières, si je mets par exemple intensité 152,5 j’obtiens ce message d’erreur :
Erreur exécution de la commande [Lumières][Lampe salle à manger][Luminosité] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"90:fd:9f:ff:fe:e5:6d:66","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["152.5","0"]}],"allowQueue":false} erreur : {"state":"error","result":"invalid literal for int() with base 10: '152.5'","code":0}
je vais m’en sortir en redéfinissant un widget curseur spécifique qui ne renvoie que des valeurs entières.
reste néanmoins la question du pourquoi sur certaines installations l’intensité fonctionne avec des bornes [250, 454] et d’autres [0,254]
hello @olivr2s
merci pour ton retour et cette piste, j’avais bien ces bornes de définies chez moi = infos créées automatiquement lors de l’inclusion de l’ampoule.
J’ai testé plusieurs autres valeurs, et si je fixe 0 en min et 254 en max, ça fonctionne chez moi.
