C’est pas spécialement pour sortir du blabla mais la c’est de l’infos a ne pas noyer et plutot avec des tag deconz …
(ça peut y rester mais un copier coller et retag serait pas plus mal non ?)
Ma LEXK-3 fonctionne
"ieee": "60:a4:23:ff:fe:8c:d2:9e",
"nwk": 9382,
"status": 2,
"lqi": "247",
"rssi": "-63",
"last_seen": "1614187153.3661175",
"node_descriptor": "01:40:8e:77:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 269,
"profile_id": 260,
"manufacturer": "Adeo",
"model": "LXEK-3",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 4,
"name": "manufacturer",
"value": "Adeo"
"id": 5,
"name": "model",
"value": "LXEK-3"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 179
"id": 768,
"name": "Color Control",
"attributes": [
"id": 0,
"name": "current_hue",
"value": 24
"id": 1,
"name": "current_saturation",
"value": 201
"id": 3,
"name": "current_x",
"value": 29991
"id": 4,
"name": "current_y",
"value": 26872
"id": 7,
"name": "color_temperature",
"value": 370
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64642,
"name": "Manufacturer Specific",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "LXEK-3",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4727,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 269,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64642
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Pour les autres, cela semble avoir été corrigée par Loic
Arf j’avais pas calé que c’était refait récemment, je vais màj le plugin.
Mince désolé. L’ampoule n’est pas remontée automatiquement suite à l’inclusion, et comme je n’ai rien trouvé sous Luxman, ni sous Enki, ni sous Leroy-Merlin, j’ai fait ce post.
Du coup j’ai revérifié et il faut chercher sous :
Fabricant : ADEO
Equipement : LXEK-1
EDIT pour @Loic
Je n’arrive pas à faire fonctionner les ampoules Leroy-Merlin avec la configuration ADEO - LXEK-1. Aucune commande ne passe (on, off, couleur, température, durée).
Voici quelques logs d’erreur :
[2021-02-24 09:54:51][ERROR] : Erreur exécution de la commande [Chambre][Chevet D][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2e:0a:db","cmd":[{"endpoint":1,"cluster":"on","command":null,"await":1}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : on","code":0}
[2021-02-24 09:55:00][ERROR] : Erreur exécution de la commande [Chambre][Chevet D][Couleur] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2e:0a:db","cmd":[{"endpoint":1,"cluster":"move_to_color","command":"9217","await":1,"args":["9058","63"]}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : move_to_color","code":0}
[2021-02-24 09:55:04][ERROR] : Erreur exécution de la commande [Chambre][Chevet S][Couleur] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2f:7d:df","cmd":[{"endpoint":1,"cluster":"move_to_color","command":"9217","await":1,"args":["9058","57"]}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : move_to_color","code":0}
[2021-02-24 09:55:09][ERROR] : Erreur exécution de la commande [Chambre][Chevet D][Luminosité] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2e:0a:db","cmd":[{"endpoint":1,"cluster":"move_to_level","command":"156","await":1,"args":["63"]}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : move_to_level","code":0}
[2021-02-24 09:55:11][ERROR] : Erreur exécution de la commande [Chambre][Chevet S][Luminosité] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2f:7d:df","cmd":[{"endpoint":1,"cluster":"move_to_level","command":"125","await":1,"args":["57"]}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : move_to_level","code":0}
[2021-02-24 09:55:13][ERROR] : Erreur exécution de la commande [Chambre][Chevet D][Température couleur] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2e:0a:db","cmd":[{"endpoint":1,"cluster":"move_to_color_temp","command":"292","await":1,"args":["63"]}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : move_to_color_temp","code":0}
[2021-02-24 09:55:14][ERROR] : Erreur exécution de la commande [Chambre][Chevet S][Température couleur] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2f:7d:df","cmd":[{"endpoint":1,"cluster":"move_to_color_temp","command":"269","await":1,"args":["57"]}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : move_to_color_temp","code":0}
[2021-02-24 09:55:16][ERROR] : Erreur exécution de la commande [Chambre][Chevet D][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2e:0a:db","cmd":[{"endpoint":1,"cluster":"on","command":null,"await":1}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : on","code":0}
[2021-02-24 09:55:18][ERROR] : Erreur exécution de la commande [Chambre][Chevet S][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:2f:7d:df","cmd":[{"endpoint":1,"cluster":"on","command":null,"await":1}],"allowQueue":false} erreur : {"state":"error","result":"Cluster not found : on","code":0}
Il y a deja plusieurs post sur un problème de fonctionnement des ampoules ADEO ( leroy merlin / lexxman)
nous avons semble t’il tous ce message en commun dans nos log:
Cluster not found
J’espère que ce problème pourra être réglé
Réponse à moi même, malgré la màj ca reste dead comme @DamDam44
@MADomotique pas essayé j’ai fait la MAJ aujourd’hui mais je suis parti de chez moi qq jours rejoindre la famille. Par précaution j’ai mis mes nouveaux radiateurs en manuel avec une température basse. Je démarre tout juste la gestion du chauffage sous jeedom. A distance je ne voulais pas trop prendre de risque, retour dimanche suite semaine prochaine pour moi.
Je crois me souvenir que j’ai du ajouter :: dans les commandes
C’est identique et par défaut ![]()
ce n’etait pas sur ta première copie ecran
Qu’as tu dans les config anvancées (roue dentée) ?
c’était avant la màj du plugin
Redemarrage Jeedom ?
Jeedom ? Carrément ?
Edit : Dépendance à jour et Demon redémarrer oui
Avec Zigbee-Beta, j’ai pris l’habitude de redémarrer régulièrement Jeedom (voire tous les matins). Mais visiblement j’avais d’autres problèmes de reseau (supra).
super ça marche
merci
du coup c’est un bug du plugin ? il faut le remonter à @Loic ?
Bonsoir @ludoviclt, effectivement je n’arrive pas à créer un groupe sur le deamon 1, par contre cela fonctionne pour le deamon 2.
En fait le groupe pour le deamon 1 se crée en se mélangeant avec le premier créé sur le deamon 2, voir groupe « Test 2 » ci-dessous avec combee 2 Maison comme deamon 1
Par contre j’ai pu créer un groupe « test 2 » sur le deamon 2 « Combee 2 Garage », et ce dernier apparait correctement dans la liste des groupes et dans « Mes groupes Zigbee »
Si @Loic à l’occasion peut y jeter un coup d’oeil se serait sympa.
bonjour
quelqu’un pourrait-il m’expliquer comment associer une télécommande physique (ADEO.LXEK-5 ) à une ampoule (ADEO.LXEK-2) ? (les 2 en zigbee de chez Leroy merlin)
la commande groupe ne sert pas à ça
EDIT:
j’ai vu ce message:
la télécommande semble avoir des codes propriétaire
Je change ma question…
puis associer mon ampoule ET à la télécommande ET à mon réseau zigbee ?
merci
