plugin-ZIGBEE Beta BlaBla
nouveau dans le monde de la domotique Zigbee j’ai acheté des interrupteurs double et triples de type Tuya
les doubles sont bien pris en compte (famille des TS0012) sous le plugin mais pas les triples qui eux sont de la même famille mais des TS0013
serait il possible d’ajouter ce modèle
wifi-smart-light-switch-push-button-2-way-multi-control-3-gang-eu-uk-version-with-no-neutral-wire-673025_1800x1800-removebg-preview (1)
    "ieee": "5c:02:72:ff:fe:c2:6c:02",
    "nwk": 45341,
    "status": 2,
    "lqi": "255",
    "rssi": "-46",
    "last_seen": "1616171158.0722218",
    "node_descriptor": "02:40:80:02:10:52:00:02:00:2c:00:02:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TYZB01_mqel1whf",
            "model": "TS0013",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 65
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TYZB01_mqel1whf"
                            "id": 5,
                            "name": "model",
                            "value": "TS0013"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
    "signature": {
        "model": "TS0013",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 512,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 512,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    4,
                    5,
                    6
                    25
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
    "class": "zigpy.device"
