J’ai vu les sujets précédents pourquoi mon stick AEOTEC 5 USB n’était pas reconnu, j’ai acheter un HUB 2.0, la clef s’allume en bleu, l’interface me montre que ma clef fonctionne, mais j’ai toujours le message « Control is Busy » quand je veux ajouter un accessoire Z-Wave
J’ai un Raspberry PI 4 avec la dernière image Jeedom 4.0 installé dessus.
Dans les logs Openzwaved, j’ai ceci:
2020-09-01 16:02:42.864 Always, OpenZwave Version 1.4.0 Starting Up
2020-09-01 16:02:42.867 Info, Setting Up Provided Network Key for Secure Communications
2020-09-01 16:02:42.867 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-09-01 16:02:42.867 Info, Opening controller /dev/ttyAMA0
2020-09-01 16:02:42.867 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-09-01 16:02:42.867 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-09-01 16:02:42.868 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-01 16:02:42.868 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-01 16:02:42.868 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-01 16:02:42.868 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-01 16:02:42.868 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-01 16:02:42.868 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-01 16:02:43.868 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-01 16:02:43.868 Detail, contrlr, Removing current message
2020-09-01 16:02:43.868 Detail, contrlr, Notification: Notification - TimeOut
2020-09-01 16:02:43.870 Detail,
2020-09-01 16:02:43.870 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-01 16:02:44.870 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-01 16:02:44.870 Detail, contrlr, Removing current message
2020-09-01 16:02:44.870 Detail, contrlr, Notification: Notification - TimeOut
2020-09-01 16:02:44.871 Detail,
2020-09-01 16:02:44.871 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-01 16:02:45.871 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-01 16:02:45.872 Detail, contrlr, Removing current message
2020-09-01 16:02:45.872 Detail, contrlr, Notification: Notification - TimeOut
2020-09-01 16:02:45.873 Detail,
2020-09-01 16:02:45.873 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-01 16:02:46.873 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-01 16:02:46.873 Detail, contrlr, Removing current message
2020-09-01 16:02:46.873 Detail, contrlr, Notification: Notification - TimeOut
2020-09-01 16:02:46.874 Detail,
2020-09-01 16:02:46.874 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-01 16:02:47.875 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-01 16:02:47.875 Detail, contrlr, Removing current message
2020-09-01 16:02:47.875 Detail, contrlr, Notification: Notification - TimeOut
Dans les logs OpenZwave ceci:
[2020-09-01 16:02:41][INFO] : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device /dev/ttyAMA0 --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey V10Inqa07TNKWmFwQm5erlMdcyi737VL --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
[2020-09-01 16:02:42][INFO] : Start openzwaved
[2020-09-01 16:02:42][INFO] : Log level : debug
[2020-09-01 16:02:42][DEBUG] : PID file : /tmp/jeedom/openzwave/deamon.pid
[2020-09-01 16:02:42][INFO] : Device : /dev/ttyAMA0
[2020-09-01 16:02:42][DEBUG] : Apikey : xxx.
[2020-09-01 16:02:42][INFO] : Callback : http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php
[2020-09-01 16:02:42][INFO] : Cycle : 0.3
[2020-09-01 16:02:42][DEBUG] : Initial disabled nodes list: []
[2020-09-01 16:02:42][DEBUG] : Init request module v2.21.0
[2020-09-01 16:02:42][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-09-01 16:02:42][INFO] : Check if the port REST server available
[2020-09-01 16:02:42][INFO] : --> pass
[2020-09-01 16:02:42][INFO] : Check OpenZWave Devices Database
[2020-09-01 16:02:42][INFO] : Validate zwcfg configuration file(s)
[2020-09-01 16:02:42][DEBUG] : Create network object.
[2020-09-01 16:02:42][DEBUG] : Use sqlite version : (u'3.27.2',)
[2020-09-01 16:02:42][DEBUG] : connect to the louie dispatcher
[2020-09-01 16:02:42][INFO] : ******** The ZWave network is being started ********
[2020-09-01 16:02:42][INFO] : Start Openzwave network.
[2020-09-01 16:02:42][INFO] : OpenZwave Library Version 1.4.0
[2020-09-01 16:02:42][INFO] : Python-OpenZwave Wrapper Version 0.3.1
[2020-09-01 16:02:42][INFO] : Waiting for network to become ready
[2020-09-01 16:02:42][DEBUG] : Writing PID 3931 to /tmp/jeedom/openzwave/deamon.pid
[2020-09-01 16:02:43][INFO] : Démon openzwave lancé
[2020-09-01 16:02:43][DEBUG] : notif_callback : new notification
[2020-09-01 16:02:43][DEBUG] : notif_callback : Notification type : 26, nodeId : 255
[2020-09-01 16:02:43][DEBUG] : notif_callback : call callback context
[2020-09-01 16:02:43][DEBUG] : zwcallback args=[{'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}]
[2020-09-01 16:02:43][DEBUG] : Z-Wave Notification : {'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}
[2020-09-01 16:02:43][DEBUG] : notif_callback : end
[2020-09-01 16:02:44][DEBUG] : notif_callback : new notification
[2020-09-01 16:02:44][DEBUG] : notif_callback : Notification type : 26, nodeId : 255
[2020-09-01 16:02:44][DEBUG] : notif_callback : call callback context
[2020-09-01 16:02:44][DEBUG] : zwcallback args=[{'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}]
[2020-09-01 16:02:44][DEBUG] : Z-Wave Notification : {'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}
[2020-09-01 16:02:44][DEBUG] : notif_callback : end
[2020-09-01 16:02:45][DEBUG] : notif_callback : new notification
[2020-09-01 16:02:45][DEBUG] : notif_callback : Notification type : 26, nodeId : 255
[2020-09-01 16:02:45][DEBUG] : notif_callback : call callback context
[2020-09-01 16:02:45][DEBUG] : zwcallback args=[{'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}]
[2020-09-01 16:02:45][DEBUG] : Z-Wave Notification : {'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}
[2020-09-01 16:02:45][DEBUG] : notif_callback : end
[2020-09-01 16:02:46][DEBUG] : notif_callback : new notification
[2020-09-01 16:02:46][DEBUG] : notif_callback : Notification type : 26, nodeId : 255
[2020-09-01 16:02:46][DEBUG] : notif_callback : call callback context
[2020-09-01 16:02:46][DEBUG] : zwcallback args=[{'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}]
[2020-09-01 16:02:46][DEBUG] : Z-Wave Notification : {'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}
[2020-09-01 16:02:46][DEBUG] : notif_callback : end
[2020-09-01 16:02:47][DEBUG] : notif_callback : new notification
[2020-09-01 16:02:47][DEBUG] : notif_callback : Notification type : 26, nodeId : 255
[2020-09-01 16:02:47][DEBUG] : notif_callback : call callback context
[2020-09-01 16:02:47][DEBUG] : zwcallback args=[{'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}]
[2020-09-01 16:02:47][DEBUG] : Z-Wave Notification : {'homeId': 0, 'notificationCode': 1, 'notificationType': 'Notification', 'nodeId': 255}
[2020-09-01 16:02:47][DEBUG] : notif_callback : end
