J’ai eu un retour du support merros
Dear Jean,
Thank you for contacting Meross.
Regarding the problem below, do you probably use the plug control from the github below? if that’s the case, please wait for 5 hours after you receive the error 1301, and try to login meross account again. At the same time, It’s told that the IoT library admin has solved the issue in reference below screenshot, kindly check at your end to see how it goes.
GitHub - albertogeniola/MerossIot: Async Python library for controlling Meross devices
Sorry for any inconvenience.
Have a nice day!
Best regards,
Alicia
Meross Customer Support
Mais resultat pourquoi le plugin ne fonctionner plus si il n’utilise pas le cloud c’est bien ca que je ne comprend pas.
Sachant que via alexa la prise repond toujours bien
Ce matin l’application meross repond a nouveau mais pas la prise via jeedom
dans les log je vois pas d’erreur
[2021-07-21 09:17:16][DEBUG] : Cmd : "togglex":{"onoff": 1,"channel": "0"} - url : http://10.0.0.2/config - type : POST - body : {"header": {"from": "http://10.0.0.2/config","messageId": "XXXidentifiantXXX","method": "SET","namespace": "Appliance.Control.ToggleX","payloadVersion": 1,"sign": "XXXjetonXXX","timestamp": XXXtimestampXXX,"triggerSrc": "AndroidLocal"},"payload": {"togglex":{"onoff": 1,"channel": "0"}}} - method: SET - Status:200
[2021-07-21 09:17:16][DEBUG] : Receive:
[2021-07-21 09:17:16][DEBUG] : Cmd : - url : http://10.0.0.2/config - type : POST - body : {"header": {"from": "http://10.0.0.2/config","messageId": "XXXidentifiantXXX","method": "GET","namespace": "Appliance.System.All","payloadVersion": 1,"sign": "XXXjetonXXX","timestamp": XXXtimestampXXX,"triggerSrc": "AndroidLocal"},"payload": {}} - method: GET - Status:200
[2021-07-21 09:17:16][DEBUG] : Receive:{"header":{"messageId":"XXXidentifiantXXX","namespace":"Appliance.System.All","method":"GETACK","payloadVersion":1,"from":"/appliance/1801160208316025131634298f111501/publish","timestamp":1626851835,"timestampMs":680,"sign":"f474dd10ecda3dd08df992f0af4344cd"},"payload":{"all":{"system":{"hardware":{"type":"mss310","subType":"us","version":"1.0.0","chipType":"MT7688","uuid":"1801160208316025131634298f111501","macAddress":"34:29:8f:11:15:01"},"firmware":{"version":"1.1.18","compileTime":"2018-12-03 11:15:36","wifiMac":"d8:07:b6:18:1e:1e","innerIp":"10.0.0.2","server":"mqtt-eu.meross.com","port":443,"secondServer":"mqtt-eu.meross.com","secondPort":443,"userId":269071},"time":{"timestamp":1626851835,"timezone":"Europe/Paris","timeRule":[[1585443600,7200,1],[1603587600,3600,0],[1616893200,7200,1],[1635642000,3600,0],[1648342800,7200,1],[1667091600,3600,0],[1679792400,7200,1],[1698541200,3600,0],[1711846800,7200,1],[1729990800,3600,0],[1743296400,7200,1],[1761440400,3600,0],[1774746000,7200,1],[1792890000,3600,0],[1806195600,7200,1],[1824944400,3600,0],[1837645200,7200,1],[1856394000,3600,0],[1869094800,7200,1],[1887843600,3600,0]]},"online":{"status":1}},"control":{"toggle":{"onoff":0,"lmTime":1626851648},"trigger":[],"timer":[]}}}}
[2021-07-21 09:17:16][DEBUG] : Cmd : - url : http://10.0.0.2/config - type : POST - body : {"header": {"from": "http://10.0.0.2/config","messageId": "XXXidentifiantXXX","method": "GET","namespace": "Appliance.Control.Electricity","payloadVersion": 1,"sign": "XXXjetonXXX","timestamp": XXXtimestampXXX,"triggerSrc": "AndroidLocal"},"payload": {}} - method: GET - Status:200
[2021-07-21 09:17:16][DEBUG] : Receive:{"header":{"messageId":"XXXidentifiantXXX","namespace":"Appliance.Control.Electricity","method":"GETACK","payloadVersion":1,"from":"/appliance/1801160208316025131634298f111501/publish","timestamp":1626851835,"timestampMs":760,"sign":"f474dd10ecda3dd08df992f0af4344cd"},"payload":{"electricity":{"channel":0,"current":0,"voltage":2293,"power":0}}}
[2021-07-21 09:17:16][DEBUG] : Meross State: Chan:1 Volt:229.3
J’ai vérifié que mes identifiant n’avais pas changer en regenerant via le script mais meme valeur que avant
