Citation
2021-10-20 11:57:21.624 Always, OpenZwave Version 1.4.0 Starting Up
2021-10-20 11:57:21.625 Info, Setting Up Provided Network Key for Secure Communications
2021-10-20 11:57:21.625 Info, mgr, Added driver for controller /dev/ttyACM0
2021-10-20 11:57:21.626 Info, Opening controller /dev/ttyACM0
2021-10-20 11:57:21.626 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2021-10-20 11:57:21.651 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2021-10-20 11:57:21.651 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-10-20 11:57:21.651 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-10-20 11:57:21.651 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-10-20 11:57:21.651 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-10-20 11:57:21.651 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-10-20 11:57:21.651 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-10-20 11:57:21.654 Warning, WARNING: Out of frame flow! (0x0f). Sending NAK.
2021-10-20 11:57:21.654 Warning, WARNING: Out of frame flow! (0x02). Sending NAK.
2021-10-20 11:57:21.654 Detail, Unsolicited message received while waiting for ACK.
2021-10-20 11:57:21.660 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0x00, 0x19, 0x0f, 0x32, 0x02, 0xf0
2021-10-20 11:57:21.660 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0x00190f32. Our node ID = 2
2021-10-20 11:57:21.663 Detail, Unsolicited message received while waiting for ACK.
2021-10-20 11:57:21.675 Detail, Node025, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x19, 0x0f, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x11, 0xd0, 0xe3, 0xca, 0x00, 0x00, 0x00, 0x00, 0x00, 0x65
2021-10-20 11:57:21.675 Detail, Unsolicited message received while waiting for ACK.
2021-10-20 11:57:21.680 Detail, Node025, Received: 0x01, 0x15, 0x00, 0x04, 0x00, 0x19, 0x0f, 0x01, 0x15, 0x00, 0x04, 0x00, 0x19, 0x0f, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x11, 0xd0, 0xe4
2021-10-20 11:57:21.680 Warning, Node025, WARNING: Checksum incorrect - sending NAK
2021-10-20 11:57:21.680 Warning, WARNING: Out of frame flow! (0x6c). Sending NAK.
2021-10-20 11:57:21.680 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2021-10-20 11:57:21.680 Warning, WARNING: Out of frame flow! (0xc4). Sending NAK.
2021-10-20 11:57:21.896 Detail, Unsolicited message received while waiting for ACK.
