Effectivement au niveau intensité, le plugin n’accepte que 3 chiffres. Tu es sur que ton paramétrages est bon? Car ça fait une consommation instantanée de 911 kW. Je ne suis pas sur que Enedis fournisse des abonnements aussi important
J’ai pareil suite à la mise à jour du plugin
Jeedom V3.3.39 je peux fournir des logs ?
Notice: Undefined index: total_inte in /var/www/html/plugins/conso/core/class/conso_teleinfo.class.php on line 1289
Notice: Undefined index: kwh in /var/www/html/plugins/conso/core/class/conso_teleinfo.class.php on line 1329
Notice: Undefined variable: total_hp in /var/www/html/plugins/conso/core/class/conso_teleinfo.class.php on line 1349
{"state":"ok","result":{"day_conso":{"prix_hp":0.2298,"tprix_hc":0,"total_hp":1.16,"total_hc":0,"total":5.07,"hp":5.07,"hc":0,"total_hc_ttc":0,"total_hp_ttc":1.16,"total_abo":0.013923287671233,"total_ttc":1.2,"total_fixe":0.03,"total_inte":0,"total_multi_ttc":0,"kwh":0,"prix_hc":0.1667,"total_ht":1.16},"yesterday_conso":{"prix_hp":0.2298,"tprix_hc":0,"total_hp":1.24,"total_hc":0,"total":5.39,"hp":5.39,"hc":0,"total_hc_ttc":0,"total_hp_ttc":1.24,"total_abo":0.013923287671233,"total_ttc":1.28,"total_fixe":0.03,"total_inte":0,"total_multi_ttc":0,"kwh":0,"prix_hc":0.1667,"total_ht":1.24},"week_conso":{"prix_hp":0.2298,"tprix_hc":0,"total_hp":5.51,"total_hc":0,"total":23.97,"hp":23.97,"hc":0,"total_hc_ttc":0,"total_hp_ttc":5.51,"total_abo":0.097730769230769,"total_ttc":5.85,"total_fixe":0.24,"total_inte":0,"total_multi_ttc":0,"kwh":0,"prix_hc":0.1667,"total_ht":5.51},"month_conso":{"prix_hp":0.2298,"tprix_hc":0,"total_hp":29.82,"total_hc":0,"total":129.77,"hp":129.77,"hc":0,"total_hc_ttc":0,"total_hp_ttc":29.82,"total_abo":0.4235,"total_ttc":31.23,"total_fixe":0.99,"total_inte":0,"total_multi_ttc":0,"kwh":0.02,"prix_hc":0.1667,"total_ht":29.82},"year_conso":{"prix_hp":0.2298,"tprix_hc":0,"total_hp":287.95,"total_hc":0,"total":1253.04,"hp":1253.04,"hc":0,"total_hc_ttc":0,"total_hp_ttc":287.95,"total_abo":2.541,"total_ttc":315.59,"total_fixe":25.1,"total_inte":0,"total_multi_ttc":0,"kwh":0.2,"prix_hc":0.1667,"total_ht":287.95},"display":false,"titletype":"HB","title":"Du 2019-09-01 au 2020-09-01 : vous pouvez changer cette date dans l'onglet outils ","titleold":"Du 2018-09-01 au 2019-09-01 : vous pouvez changer cette date dans l'onglet outils "}}
@superbricolo une idée ?
Après quelques combats avec la page du correcteur qui fonctionne un peu bizarrement
J’ai supprimé les jours à problème et tout est ok maintenant, merci pour l’aide
il y a donc bien un calcul par jour donc si l’index change d’une journée à l’autre pas de soucis, si c’est pendant la journée alors là cela créé un pic de conso, c’est plutôt logique
Testé suivi conso widgets… tres bien…Merci
ça me le fait depuis les mises à jour. et aléatoirement.
J’ai indiqué une valeur max pour papp de 13200 (watts), ainsi que pour mon équipement rfxcom. et une valeur max de 60 (amperes) pour IMAX… souhaitant que cela évite les faux pics qui plantent le deamon après 3 tentatives. Sachant que je fais un delestage si je dépasse 10000 watt ça ne m’arrange pas car cela risque de faire un délestage non nécessaire. car ça ne dépasse pas 10000 mais il croira que oui.
Si je comprend bien le problème ne vient pas du plugin mais des données que tu lui fournis. Si c’est bien le cas, on ne pas faire grand chose
Bon parfait alors
Je cherche encore
Si je peux fournir quelque chose dis moi J’espère pas devoir retourner au backup de cette nuit
oui mais la case « PUISSANCE : Ne pas insérer la valeur si la puissance est > 50 000 » étant cochée, je ne devrais pas avoir ces fausses valeurs ? si ?
Non mais la ton problème, c’est pas la puissance, c’est l’intensité ! Affiche le paramétrage de ton équipement
L’intensité est calculée avec la puissance :
IMAX1 : maxBetween(#[Maison/jardin][OWL 180-2][Puissance]#,midnight,now)/230
PAPP : #[Maison/jardin][OWL 180-2][Puissance]#
La valeur posant problème dans la base étant IMAX1, IMAX1 étant calculée sur la puissance, j’en déduis que c’est la puissance.
Mais ce qui est étonnant c’est que PAPP (puissance) est indiqué à 1722 dans la ligne d’erreur :
(1582107054,« 2020-02-19 »,« 11:10:54 »,44960152,18457149,« HP »,7,1722,4558,432,7.9
Ok, je comprend mieux. La case > 50000 ne vaut que pour les cases puissance. Là ton calcul est externe au plugin. Il ne peut pas filtrer… Cela dit je ne connait pas ton abonnement, mais par exemple si tu as un abonnement de 9kVA soit 45 A tu ne doit normalement pas aller beaucoup plus haut. Après la récupération des données de ton module OWL sont peut-être sujet à caution en fonction de la portée, d’où tes anomalies.
Donc la bonne solution est effectivement de mettre une valeur max sur la puissance de ton équipement OWL, afin de ne pas obtenir une intensité délirante
ok. merci superbricolo toujours aussi réactif
J’ai 12KW soit 60A
du coup en puissance max sur ton owl, je mettrrais 14000 ou 15000 W
Tu peux me montrer le paramétrage de tes taxes. Toi aussi @Brelok
Tu n’as pas de taxe variable?
Non je pense pas, mais j’avais fait ça y a un moment mtn
