Savez-vous si il est possible de récupérer les informations de MyT (Toyota) et de les intégrer à Jeedom ?
J’ai vu ce Github, mais je sais pas si c’est intégrable.
Voici le script
# Copyright 2020 Janne Määttä
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
MyT interaction library
import glob
import json
import logging
import os
from pathlib import Path
import platform
import sys
import pendulum
import requests
logging.basicConfig(format='%(asctime)s:%(name)s:%(levelname)s: %(message)s')
log = logging.getLogger(__name__)
log.setLevel(logging.DEBUG)
CACHE_DIR = 'cache'
USER_DATA = 'user_data.json'
INFLUXDB_URL = 'http://localhost:8086/write?db=tojota'
class Myt:
Class for interacting with Toyota vehicle API
def __init__(self):
Create cache directory, try to load existing user data or if it doesn't exists do login.
os.makedirs(CACHE_DIR, exist_ok=True)
self.config_data = self._get_config()
self.user_data = self._get_user_data()
if self.user_data:
self.headers = {'X-TME-TOKEN': self.user_data['token']}
else:
self.login()
@staticmethod
def _get_config(config_file='myt.json'):
Load configuration values from config file. Return config as a dict.
:param config_file: Filename on configs directory
:return: dict
with open(Path('configs')/config_file) as f:
try:
config_data = json.load(f)
except Exception as e: # pylint: disable=W0703
log.error('Failed to load configuration JSON! %s', str(e))
raise
return config_data
@staticmethod
def _get_user_data():
Try to load existing user data from CACHE_DIR. If it doesn't exists or is malformed return None
:return: user_data dict or None
try:
with open(Path(CACHE_DIR) / USER_DATA) as f:
try:
user_data = json.load(f)
log.error('Failed to load cached user data JSON! %s', str(e))
raise
return user_data
except FileNotFoundError:
return None
@staticmethod
def _read_file(file_path):
Load file contents or return None if loading fails
:param file_path: Path for a file
:return: File contents
try:
with open(file_path, 'r') as f:
return f.read()
except (FileNotFoundError, TypeError):
return None
@staticmethod
def _write_file(file_path, contents):
Write string to a file
:param contents: String to be written
:return:
if platform.system() == 'Windows':
file_path = str(file_path).replace(':', '')
with open(file_path, 'w') as f:
f.write(contents)
@staticmethod
def _find_latest_file(path):
Return latest file with given path pattern or None if not found
:param path: Path expression for directory contents. Like 'cache/trips/trips*'
:return: Latest file path or None if not found
files = glob.glob(path)
if files:
return max(files, key=os.path.getctime)
return None
def login(self, locale='fi-fi'):
Do Toyota SSO login. Saves user data for configured account in self.user_data and sets token to self.headers.
User data is saved to CACHE_DIR for reuse.
:param locale: Locale for login is required but doesn't seem to have any effect
:return: None
login_headers = {'X-TME-BRAND': 'TOYOTA', 'X-TME-LC': locale, 'Accept': 'application/json, text/plain, */*',
'Sec-Fetch-Dest': 'empty'}
log.info('Logging in...')
r = requests.post('https://ssoms.toyota-europe.com/authenticate', headers=login_headers, json=self.config_data)
if r.status_code != 200:
raise ValueError('Login failed, check your credentials! {}'.format(r.text))
user_data = r.json()
self.user_data = user_data
self.headers = {'X-TME-TOKEN': user_data['token']}
self._write_file(Path(CACHE_DIR) / USER_DATA, r.text)
def get_trips(self, trip=1):
Get latest 10 trips. Save trips to CACHE_DIR/trips/trips-`datetime` file. Will save every time there is a new
trip or daily because of changing metadata if no new trips. Saved information is not currently used for
anything.
:param trip: There is paging, but it doesn't seem to do anything. 1 is the default value.
:return: recentTrips dict, fresh boolean True is new data was fetched
fresh = False
trips_path = Path(CACHE_DIR) / 'trips'
trips_file = trips_path / 'trips-{}'.format(pendulum.now())
log.info('Fetching trips...')
r = requests.get(
'https://cpb2cs.toyota-europe.com/api/user/{}/cms/trips/v2/history/vin/{}/{}'.format(
self.user_data['customerProfile']['uuid'], self.config_data['vin'], trip), headers=self.headers)
raise ValueError('Failed to get data, {} {}'.format(r.status_code, r.headers))
os.makedirs(trips_path, exist_ok=True)
previous_trip = self._read_file(self._find_latest_file(str(trips_path / 'trips*')))
if r.text != previous_trip:
self._write_file(trips_file, r.text)
fresh = True
trips = r.json()
return trips, fresh
def get_trip(self, trip_id):
Get trip info. Trip is identified by uuidv4. Save trip data to CACHE_DIR/trips/[12]/[34]/uuid file. If given
trip already exists in CACHE_DIR just get it from there.
:param trip_id: tripId to fetch. uuid v4 that is received from get_trips().
:return: trip dict, fresh boolean True is new data was fetched
fresh = False
trip_base_path = Path(CACHE_DIR) / 'trips'
trip_path = trip_base_path / trip_id[0:2] / trip_id[2:4]
trip_file = trip_path / trip_id
if not trip_file.exists():
log.debug('Fetching trip...')
r = requests.get('https://cpb2cs.toyota-europe.com/api/user/{}/cms/trips/v2/{}/events/vin/{}'.format(
self.user_data['customerProfile']['uuid'], trip_id, self.config_data['vin']), headers=self.headers)
raise ValueError('Failed to get data {} {}'.format(r.status_code, r.headers))
os.makedirs(trip_path, exist_ok=True)
self._write_file(trip_file, r.text)
trip_data = r.json()
fresh = True
else:
with open(trip_file) as f:
trip_data = json.load(f)
return trip_data, fresh
def get_parking(self):
Get location information. Location is saved when vehicle is powered off. Save data to
CACHE_DIR/parking/parking-`datetime` file. Saved information is not currently used for anything. When vehicle
is powered on again tripStatus will change to '1'.
:return: Location dict, fresh Boolean if new data was fetched
fresh = False
parking_path = Path(CACHE_DIR) / 'parking'
parking_file = parking_path / 'parking-{}'.format(pendulum.now())
token = self.user_data['token']
uuid = self.user_data['customerProfile']['uuid']
vin = self.config_data['vin']
headers = {'Cookie': f'iPlanetDirectoryPro={token}', 'VIN': vin}
url = f'https://myt-agg.toyota-europe.com/cma/api/users/{uuid}/vehicle/location'
r = requests.get(url, headers=headers)
raise ValueError('Failed to get data {} {} {}'.format(r.text, r.status_code, r.headers))
os.makedirs(parking_path, exist_ok=True)
previous_parking = self._read_file(self._find_latest_file(str(parking_path / 'parking*')))
if r.text != previous_parking:
self._write_file(parking_file, r.text)
fresh = True
return r.json(), fresh
def get_odometer_fuel(self):
Get mileage and fuel tank information. Data is saved when vehicle is powered off. Save data to
CACHE_DIR/odometer/odometer-`datetime` file.
:return: list(odometer, odometer_unit, fuel_percentage, fresh)
fresh = False
odometer_path = Path(CACHE_DIR) / 'odometer'
odometer_file = odometer_path / 'odometer-{}'.format(pendulum.now())
headers = {'Cookie': f'iPlanetDirectoryPro={token}'}
url = f'https://myt-agg.toyota-europe.com/cma/api/vehicle/{vin}/addtionalInfo' # (sic)
os.makedirs(odometer_path, exist_ok=True)
previous_odometer = self._read_file(self._find_latest_file(str(odometer_path / 'odometer*')))
if r.text != previous_odometer:
self._write_file(odometer_file, r.text)
fresh = True
data = r.json()
odometer = 0
odometer_unit = ''
fuel = 0
for item in data:
if item['type'] == 'mileage':
odometer = item['value']
odometer_unit = item['unit']
if item['type'] == 'Fuel':
fuel = item['value']
return odometer, odometer_unit, fuel, fresh
def get_remote_control_status(self):
CACHE_DIR/remote_control/remote_control-`datetime` file.
fresh = False
remote_control_path = Path(CACHE_DIR) / 'remote_control'
remote_control_file = remote_control_path / 'remote_control-{}'.format(pendulum.now())
headers = {'Cookie': f'iPlanetDirectoryPro={token}', 'uuid': uuid}
url = f'https://myt-agg.toyota-europe.com/cma/api/vehicles/{vin}/remoteControl/status'
data = r.json()
os.makedirs(remote_control_path, exist_ok=True)
# remoteControl/status messages has varying order of the content, load it as a dict for comparison
try:
previous_remote_control = json.loads(self._read_file(self._find_latest_file(str(
remote_control_path / 'remote_control*'))))
except TypeError:
previous_remote_control = None
if data != previous_remote_control:
self._write_file(remote_control_file, json.dumps(r.json(), sort_keys=True))
fresh = True
return data, fresh
def insert_into_influxdb(measurement, value):
Insert data into influxdb (without authentication)
:param measurement: Measurement name
:param value: Measurement value
:return: null
headers = {'Content-Type': 'application/x-www-form-urlencoded'}
payload = "{} value={}".format(measurement, value)
requests.post(INFLUXDB_URL, headers=headers, data=payload)
def remote_control_to_db(myt, fresh, charge_info, hvac_info):
if fresh and myt.config_data['use_influxdb']:
log.debug('Saving remote control data to influxdb')
insert_into_influxdb('charge_level', charge_info['ChargeRemainingAmount'])
insert_into_influxdb('ev_range', charge_info['EvDistanceWithAirCoInKm'])
insert_into_influxdb('charge_type', charge_info['ChargeType'])
insert_into_influxdb('charge_week', charge_info['ChargeWeek'])
insert_into_influxdb('connector_status', charge_info['ConnectorStatus'])
insert_into_influxdb('subtraction_rate', charge_info['EvTravelableDistanceSubtractionRate'])
insert_into_influxdb('plugin_history', charge_info['PlugInHistory'])
insert_into_influxdb('plugin_status', charge_info['PlugStatus'])
insert_into_influxdb('temperature_inside', hvac_info['InsideTemperature'])
insert_into_influxdb('temperature_setting', hvac_info['SettingTemperature'])
insert_into_influxdb('temperature_level', hvac_info['Temperaturelevel'])
def odometer_to_db(myt, fresh, fuel_percent, odometer):
log.debug('Saving odometer data to influxdb')
insert_into_influxdb('odometer', odometer)
insert_into_influxdb('fuel_level', fuel_percent)
def trip_data_to_db(myt, fresh, average_consumption, stats):
insert_into_influxdb('trip_kilometers', stats['totalDistanceInKm'])
insert_into_influxdb('trip_liters', stats['fuelConsumptionInL'])
insert_into_influxdb('trip_average_consumption', average_consumption)
def main():
Get trips, get parking information, get trips information
:return:
myt = Myt()
# Try to fetch trips array with existing user_info. If it fails, do new login and try again.
try:
trips, fresh = myt.get_trips()
except ValueError:
log.info('Failed to use cached token, doing fresh login...')
myt.login()
try:
latest_address = trips['recentTrips'][0]['endAddress']
except (KeyError, IndexError):
latest_address = 'Unknown address'
# Check is vehicle is still parked or moving and print corresponding information. Parking timestamp is epoch
# timestamp with microseconds. Actual value seems to be at second precision level.
log.info('Get parking info...')
parking, fresh = myt.get_parking()
if parking['tripStatus'] == '0':
print('Car is parked at {} at {}'.format(latest_address,
pendulum.from_timestamp(int(parking['event']['timestamp']) / 1000).
in_tz(myt.config_data['timezone']).to_datetime_string()))
else:
print('Car left from {} parked at {}'.format(latest_address,
# Get odometer and fuel tank status
log.info('Get odometer info...')
odometer, odometer_unit, fuel_percent, fresh = myt.get_odometer_fuel()
print('Odometer {} {}, {}% fuel left'.format(odometer, odometer_unit, fuel_percent))
# Get remote control status
if myt.config_data['use_remote_control']:
log.info('Get remote control status...')
status, fresh = myt.get_remote_control_status()
charge_info = status['VehicleInfo']['ChargeInfo']
hvac_info = status['VehicleInfo']['RemoteHvacInfo']
print('Battery level {}%, EV range {} km, Inside temperature {}, Charging status {}, status reported at {}'.
format(charge_info['ChargeRemainingAmount'], charge_info['EvDistanceWithAirCoInKm'],
hvac_info['InsideTemperature'], charge_info['ChargingStatus'],
pendulum.parse(status['VehicleInfo']['AcquisitionDatetime']).
if charge_info['ChargingStatus'] == 'charging' and charge_info['RemainingChargeTime'] != 65535:
acquisition_datetime = pendulum.parse(status['VehicleInfo']['AcquisitionDatetime'])
charging_end_time = acquisition_datetime.add(minutes=charge_info['RemainingChargeTime'])
print('Charging will be completed at {}'.format(charging_end_time.in_tz(myt.config_data['timezone']).
# Get detailed information about trips and calculate cumulative kilometers and fuel liters
kms = 0
ls = 0
fresh_data = 0
for trip in trips['recentTrips']:
trip_data, fresh = myt.get_trip(trip['tripId'])
fresh_data += fresh
stats = trip_data['statistics']
# Parse UTC datetime strings to local time
start_time = pendulum.parse(trip['startTimeGmt']).in_tz(myt.config_data['timezone']).to_datetime_string()
end_time = pendulum.parse(trip['endTimeGmt']).in_tz(myt.config_data['timezone']).to_datetime_string()
# Remove country part from address strings
try:
start = trip['startAddress'].split(',')
except KeyError:
start = ['Unknown', ' Unknown']
try:
end = trip['endAddress'].split(',')
except KeyError:
end = ['Unknown', ' Unknown']
start_address = '{},{}'.format(start[0], start[1])
end_address = '{},{}'.format(end[0], end[1])
kms += stats['totalDistanceInKm']
ls += stats['fuelConsumptionInL']
average_consumption = (stats['fuelConsumptionInL']/stats['totalDistanceInKm'])*100
print('{} {} -> {} {}: {} km, {} km/h, {:.2f} l/100 km, {:.2f} l'.
format(start_time, start_address, end_time, end_address, stats['totalDistanceInKm'],
stats['averageSpeedInKmph'], average_consumption, stats['fuelConsumptionInL']))
if fresh_data and myt.config_data['use_influxdb']:
insert_into_influxdb('short_term_average_consumption', (ls/kms)*100)
print('Total distance: {:.3f} km, Fuel consumption: {:.2f} l, {:.2f} l/100 km'.format(kms, ls, (ls/kms)*100))
if __name__ == "__main__":
sys.exit(main())
J’ai tenté de le mettre dans le plugin Script, mais j’ai une erreur:
Erreur sur python /var/www/html/plugins/script/data/tojota.py 2>&1 valeur retournée : 1. Détails : File "/var/www/html/plugins/script/data/tojota.py", line 1 SyntaxError: Non-ASCII character '\xc3' in file /var/www/html/plugins/script/data/tojota.py on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Merci pour votre aide.
Mathieu
