Le plugin fonctionnait très bien jusqu’à il y a quelques jours, maintenant j’ai l’erreur « Erreur login API PSA ».
J’ai tenté la réinstallation les dépendances, vérifié que tout était à jour dans Jeedom, rien n’y fait.
Voici les logs :
>Peugeotcars
[2024-01-31 11:50:06]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-01-31 11:50:07]ERROR : Erreur Login API PSA
> peugeotcars_otp
File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module>
from . import multiarray
File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module>
from . import overrides
File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module>
from numpy.core._multiarray_umath import (
ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module>
from numpy.__config__ import show as show_config
File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module>
File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module>
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.9 from "/usr/bin/python3"
* The NumPy version is: "1.26.3"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory
The above exception was the direct cause of the following exception:
File "/var/www/html/plugins/peugeotcars/core/ajax/../../3rdparty/psa_jeedom_daemon/jeedom_otp.py", line 16, in <module>
from psa_car_controller.psacc.application.car_controller import PSACarController
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module>
from .charge_control import ChargeControls
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module>
from .psa_client import PSAClient
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module>
from psa_car_controller.psacc.application.charging import Charging
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module>
from .ecomix import Ecomix
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module>
import reverse_geocode
File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module>
from scipy.spatial import cKDTree as KDTree
File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module>
from numpy import __version__ as __numpy_version__
File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module>
raise ImportError(msg) from e
ImportError: Error importing numpy: you should not try to import numpy from
its source directory; please exit the numpy source tree, and relaunch
your python interpreter from there.
> peugeotcars_remote
Log du plugin peugeotcars_remote
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there. Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.9/dist-packages/numpy/core/multiarray.py", line 10, in <module> from . import overrides File "/usr/local/lib/python3.9/dist-packages/numpy/core/overrides.py", line 8, in <module> from numpy.core._multiarray_umath import ( ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 130, in <module> from numpy.__config__ import show as show_config File "/usr/local/lib/python3.9/dist-packages/numpy/__config__.py", line 4, in <module> from numpy.core._multiarray_umath import ( File "/usr/local/lib/python3.9/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/usr/bin/python3" * The NumPy version is: "1.26.3" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/var/www/html/plugins/peugeotcars/core/class/../../3rdparty/psa_jeedom_daemon/jeedom_gateway.py", line 18, in <module> from psa_car_controller.psacc.application.car_controller import PSACarController File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in <module> from .charge_control import ChargeControls File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in <module> from .psa_client import PSAClient File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in <module> from psa_car_controller.psacc.application.charging import Charging File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in <module> from .ecomix import Ecomix File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in <module> import reverse_geocode File "/usr/local/lib/python3.9/dist-packages/reverse_geocode/__init__.py", line 12, in <module> from scipy.spatial import cKDTree as KDTree File "/usr/local/lib/python3.9/dist-packages/scipy/__init__.py", line 47, in <module> from numpy import __version__ as __numpy_version__ File "/usr/local/lib/python3.9/dist-packages/numpy/__init__.py", line 135, in <module> raise ImportError(msg) from e ImportError: Error importing numpy: you should not try to import numpy from its source directory; please exit the numpy source tree, and relaunch your python interpreter from there.
Merci à vous, bonne journée,
