Bonjour @Steeve,
la configuration du port de l’id et du mot de passe sont OK ? si mosquitto est paramétré pour …
Peux on avoir une copie de la config de MQTT ?
Une autre erreur :
PHP Warning: PHP Startup: Unable to load dynamic library ‹ mosquitto.so › (tried: /usr/lib/php/20180731/mosquitto.so (/usr/lib/php/20180731/mosquitto.so: cannot open shared object file: Permission denied), /usr/lib/php/20180731/mosquitto.so.so (/usr/lib/php/20180731/mosquitto.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
J’ai exécuté chmod 0777 /usr/lib/php/20180731/mosquitto.so
Et l’erreur a disparu…
Et voici le resultat de pecl install Mosquitto-beta :
WARNING: channel « pecl.php.net » has updated its protocols, use « pecl channel-update pecl.php.net » to update
downloading Mosquitto-0.4.0.tgz …
Starting to download Mosquitto-0.4.0.tgz (23,804 bytes)
…done: 23,804 bytes
5 source files, building
running: phpize
Configuring for:
PHP Api Version: 20180731
Zend Module Api No: 20180731
Zend Extension Api No: 320180731
Please provide the prefix of the libmosquitto installation [autodetect] : building in /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0
running: /tmp/pear/temp/Mosquitto/configure --with-php-config=/usr/bin/php-config --with-mosquitto
checking for grep that handles long lines and -e… /usr/bin/grep
checking for egrep… /usr/bin/grep -E
checking for a sed that does not truncate output… /usr/bin/sed
checking for cc… cc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether cc accepts -g… yes
checking for cc option to accept ISO C89… none needed
checking how to run the C preprocessor… cc -E
checking for icc… no
checking for suncc… no
checking whether cc understands -c and -o together… yes
checking for system library directory… lib
checking if compiler supports -R… no
checking if compiler supports -Wl,-rpath,… yes
checking build system type… aarch64-unknown-linux-gnu
checking host system type… aarch64-unknown-linux-gnu
checking target system type… aarch64-unknown-linux-gnu
checking for PHP prefix… /usr
checking for PHP includes… -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib
checking for PHP extension directory… /usr/lib/php/20180731
checking for PHP installed headers prefix… /usr/include/php/20180731
checking if debug is enabled… no
checking if zts is enabled… no
checking for re2c… no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk… gawk
checking for mosquitto support… yes, shared
checking for mosquitto files in default path… checking /usr… found in /usr
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking whether strerror_r is declared… yes
checking for strerror_r… yes
checking whether strerror_r returns char *… no
checking how to print strings… printf
checking for a sed that does not truncate output… (cached) /usr/bin/sed
checking for fgrep… /usr/bin/grep -F
checking for ld used by cc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 1572864
checking how to convert aarch64-unknown-linux-gnu file names to aarch64-unknown-linux-gnu format… func_convert_file_noop
checking how to convert aarch64-unknown-linux-gnu file names to toolchain format… func_convert_file_noop
checking for /usr/bin/ld option to reload object files… -r
checking for objdump… objdump
checking how to recognize dependent libraries… pass_all
checking for dlltool… no
checking how to associate runtime and link libraries… printf %s\n
checking for ar… ar
checking for archiver @FILE support… @
checking for strip… strip
checking for ranlib… ranlib
checking for gawk… (cached) gawk
checking command to parse /usr/bin/nm -B output from cc object… ok
checking for sysroot… no
checking for a working dd… /usr/bin/dd
checking how to truncate binary pipes… /usr/bin/dd bs=4096 count=1
checking for mt… mt
checking if mt is a manifest tool… no
checking for dlfcn.h… yes
checking for objdir… .libs
checking if cc supports -fno-rtti -fno-exceptions… no
checking for cc option to produce PIC… -fPIC -DPIC
checking if cc PIC flag -fPIC -DPIC works… yes
checking if cc static flag -static works… yes
checking if cc supports -c -o file.o… yes
checking if cc supports -c -o file.o… (cached) yes
checking whether the cc linker (/usr/bin/ld) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… no
configure: creating ./config.status
config.status: creating config.h
config.status: executing libtool commands
running: make
/bin/bash /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/libtool --mode=compile cc -I. -I/tmp/pear/temp/Mosquitto -DPHP_ATOM_INC -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/include -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/main -I/tmp/pear/temp/Mosquitto -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/Mosquitto/mosquitto.c -o mosquitto.lo
libtool: compile: cc -I. -I/tmp/pear/temp/Mosquitto -DPHP_ATOM_INC -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/include -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/main -I/tmp/pear/temp/Mosquitto -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/Mosquitto/mosquitto.c -fPIC -DPIC -o .libs/mosquitto.o
/bin/bash /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/libtool --mode=compile cc -I. -I/tmp/pear/temp/Mosquitto -DPHP_ATOM_INC -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/include -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/main -I/tmp/pear/temp/Mosquitto -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/Mosquitto/mosquitto_message.c -o mosquitto_message.lo
libtool: compile: cc -I. -I/tmp/pear/temp/Mosquitto -DPHP_ATOM_INC -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/include -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/main -I/tmp/pear/temp/Mosquitto -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/Mosquitto/mosquitto_message.c -fPIC -DPIC -o .libs/mosquitto_message.o
In file included from /usr/include/php/20180731/Zend/zend.h:334,
from /usr/include/php/20180731/main/php.h:34,
from /tmp/pear/temp/Mosquitto/mosquitto_message.c:5:
/tmp/pear/temp/Mosquitto/mosquitto_message.c: In function ‘php_mosquitto_message_read_property’:
/usr/include/php/20180731/Zend/zend_object_handlers.h:169:2: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
(&std_object_handlers)
/tmp/pear/temp/Mosquitto/mosquitto_message.c:292:36: note: in expansion of macro ‘zend_get_std_object_handlers’
zend_object_handlers * std_hnd = zend_get_std_object_handlers();
/tmp/pear/temp/Mosquitto/mosquitto_message.c: In function ‘php_mosquitto_message_write_property’:
/tmp/pear/temp/Mosquitto/mosquitto_message.c:332:36: note: in expansion of macro ‘zend_get_std_object_handlers’
/tmp/pear/temp/Mosquitto/mosquitto_message.c: In function ‘php_mosquitto_message_has_property’:
/tmp/pear/temp/Mosquitto/mosquitto_message.c:392:36: note: in expansion of macro ‘zend_get_std_object_handlers’
/bin/bash /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/libtool --mode=link cc -DPHP_ATOM_INC -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/include -I/tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/main -I/tmp/pear/temp/Mosquitto -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib -DHAVE_CONFIG_H -g -O2 -o mosquitto.la -export-dynamic -avoid-version -prefer-pic -module -rpath /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/modules mosquitto.lo mosquitto_message.lo -lmosquitto
libtool: link: cc -shared -fPIC -DPIC .libs/mosquitto.o .libs/mosquitto_message.o -lmosquitto -g -O2 -Wl,-soname -Wl,mosquitto.so -o .libs/mosquitto.so
libtool: link: ( cd « .libs » && rm -f « mosquitto.la » && ln -s « …/mosquitto.la » « mosquitto.la » )
/bin/bash /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/libtool --mode=install cp ./mosquitto.la /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/modules
libtool: install: cp ./.libs/mosquitto.so /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/modules/mosquitto.so
libtool: install: cp ./.libs/mosquitto.lai /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/modules/mosquitto.la
libtool: finish: PATH="/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /tmp/pear/temp/pear-build-rootWG9MRc/Mosquitto-0.4.0/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the ‹ -LLIBDIR ›
flag during linking and do at least one of the following:
add LIBDIR to the ‹ LD_LIBRARY_PATH › environment variable
during execution
add LIBDIR to the ‹ LD_RUN_PATH › environment variable
during linking
use the ‹ -Wl,-rpath -Wl,LIBDIR › linker flag
have your system administrator add LIBDIR to ‹ /etc/ld.so.conf ›
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Build complete.
Don’t forget to run ‹ make test ›.
Build process completed successfully
Installing ‹ /usr/lib/php/20180731/mosquitto.so ›
install ok: channel://pecl.php.net/Mosquitto-0.4.0
configuration option « php_ini » is not set to php.ini location
You should add « extension=mosquitto.so » to php.ini
extension=mosquitto.so ajouté à tous les PHP.INI de php7.3
En executant en ligne de commande avant :
mosquitto -d
et ensuite
mosquitto_sub -d -u s.keller -P xxxx -t « # »
Client mosqsub|4772-VMM-FREEBO sending CONNECT
Client mosqsub|4772-VMM-FREEBO received CONNACK (0)
Client mosqsub|4772-VMM-FREEBO sending SUBSCRIBE (Mid: 1, Topic: #, QoS: 0)
Client mosqsub|4772-VMM-FREEBO received SUBACK
Subscribed (mid: 1): 0
Alors cela fonctionne mais uniquement en ligne de commande pas sur jeedom…
J’ai effectivement changé le port de mosquitto, mais encore une fois cela fonctionne bien sous node-red par exemple. Je pense que le souci vient de l’accès par mot de passe à mosquitto…
essai aussi a la place de 127.0.0.1 de mettre l’ip la ou est ton mosquito …
pour les id mot de passe toi seul peut savoir ce que tu a mis dans ta config mosquito …
en alternative desinstalle le plugin-mqtt et essai le plugin-jmqtt certains ici on de meilleur résultat avec celui-ci.
