je viens sur ce forum car je ne trouve pas de solutions à mon problème. J’ai l’impression que les dépendances ne s’installe pas. donc impossible de passer le demon au statut ok. j’espère que quelqu’un pourra trouver mon problème.
merci d’avance. `
Voila le log d’installation
Installation des dépendance *
E: dpkg was interrupted, you must manually run ‹ sudo dpkg --configure -a › to correct the problem.
Installation de FFMPEG *
Compilation de motion: *
Cloning into ‹ motion ›…
autoreconf: Entering directory .' autoreconf: running: autopoint --force Copying file ABOUT-NLS Copying file config.rpath Creating directory m4 Copying file m4/codeset.m4 Copying file m4/fcntl-o.m4 Copying file m4/gettext.m4 Copying file m4/glibc2.m4 Copying file m4/glibc21.m4 Copying file m4/iconv.m4 Copying file m4/intdiv0.m4 Copying file m4/intl.m4 Copying file m4/intldir.m4 Copying file m4/intlmacosx.m4 Copying file m4/intmax.m4 Copying file m4/inttypes-pri.m4 Copying file m4/inttypes_h.m4 Copying file m4/lcmessage.m4 Copying file m4/lib-ld.m4 Copying file m4/lib-link.m4 Copying file m4/lib-prefix.m4 Copying file m4/lock.m4 Copying file m4/longlong.m4 Copying file m4/nls.m4 Copying file m4/po.m4 Copying file m4/printf-posix.m4 Copying file m4/progtest.m4 Copying file m4/size_max.m4 Copying file m4/stdint_h.m4 Copying file m4/threadlib.m4 Copying file m4/uintmax_t.m4 Copying file m4/visibility.m4 Copying file m4/wchar_t.m4 Copying file m4/wint_t.m4 Copying file m4/xsize.m4 Copying file po/Makefile.in.in Copying file po/Makevars.template Copying file po/Rules-quot Copying file po/boldquot.sed Copying file po/en@boldquot.header Copying file po/en@quot.header Copying file po/insert-header.sin Copying file po/quot.sed Copying file po/remove-potcdate.sin autoreconf: running: aclocal --force -I m4 autoreconf: configure.ac: tracing autoreconf: configure.ac: not using Libtool autoreconf: running: /usr/bin/autoconf --force autoreconf: running: /usr/bin/autoheader --force autoreconf: running: automake --add-missing --copy --force-missing configure.ac:11: warning: The 'AM_PROG_MKDIR_P' macro is deprecated, and its use is discouraged. configure.ac:11: You should use the Autoconf-provided 'AC_PROG_MKDIR_P' macro instead, configure.ac:11: and use '$(MKDIR_P)' instead of '$(mkdir_p)'in your Makefile.am files. configure.ac:3: installing './compile' configure.ac:8: installing './config.guess' configure.ac:8: installing './config.sub' configure.ac:2: installing './install-sh' configure.ac:2: installing './missing' src/Makefile.am: installing './depcomp' autoreconf: Leaving directory .’
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… gawk
checking whether make sets $(MAKE)… yes
checking whether make supports nested variables… yes
checking for gcc… gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking whether gcc understands -c and -o together… yes
checking for style of include used by make… GNU
checking dependency style of gcc… gcc3
checking for g++… g++
checking whether we are using the GNU C++ compiler… yes
checking whether g++ accepts -g… yes
checking dependency style of g++… gcc3
checking how to run the C preprocessor… gcc -E
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking minix/config.h usability… no
checking minix/config.h presence… no
checking for minix/config.h… no
checking whether it is safe to define EXTENSIONS… yes
checking build system type… armv7l-unknown-linux-gnueabihf
checking host system type… armv7l-unknown-linux-gnueabihf
checking whether NLS is requested… yes
checking for msgfmt… /usr/bin/msgfmt
checking for gmsgfmt… /usr/bin/msgfmt
checking for xgettext… /usr/bin/xgettext
checking for msgmerge… /usr/bin/msgmerge
checking for ld used by GCC… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for shared library run path origin… done
checking for CFPreferencesCopyAppValue… no
checking for CFLocaleCopyCurrent… no
checking for GNU gettext in libc… yes
checking whether to use NLS… yes
checking where the gettext function comes from… libc
checking stdio.h usability… yes
checking stdio.h presence… yes
checking for stdio.h… yes
checking for stdlib.h… (cached) yes
checking sys/time.h usability… yes
checking sys/time.h presence… yes
checking for sys/time.h… yes
checking sys/wait.h usability… yes
checking sys/wait.h presence… yes
checking for sys/wait.h… yes
checking sys/ioctl.h usability… yes
checking sys/ioctl.h presence… yes
checking for sys/ioctl.h… yes
checking sys/mman.h usability… yes
checking sys/mman.h presence… yes
checking for sys/mman.h… yes
checking sys/param.h usability… yes
checking sys/param.h presence… yes
checking for sys/param.h… yes
checking sys/socket.h usability… yes
checking sys/socket.h presence… yes
checking for sys/socket.h… yes
checking stdarg.h usability… yes
checking stdarg.h presence… yes
checking for stdarg.h… yes
checking fcntl.h usability… yes
checking fcntl.h presence… yes
checking for fcntl.h… yes
checking time.h usability… yes
checking time.h presence… yes
checking for time.h… yes
checking signal.h usability… yes
checking signal.h presence… yes
checking for signal.h… yes
checking limits.h usability… yes
checking limits.h presence… yes
checking for limits.h… yes
checking errno.h usability… yes
checking errno.h presence… yes
checking for errno.h… yes
checking assert.h usability… yes
checking assert.h presence… yes
checking for assert.h… yes
checking netdb.h usability… yes
checking netdb.h presence… yes
checking for netdb.h… yes
checking ctype.h usability… yes
checking ctype.h presence… yes
checking for ctype.h… yes
checking regex.h usability… yes
checking regex.h presence… yes
checking for regex.h… yes
checking math.h usability… yes
checking math.h presence… yes
checking for math.h… yes
checking locale.h usability… yes
checking locale.h presence… yes
checking for locale.h… yes
checking dirent.h usability… yes
checking dirent.h presence… yes
checking for dirent.h… yes
checking for ctype.h… (cached) yes
checking arpa/inet.h usability… yes
checking arpa/inet.h presence… yes
checking for arpa/inet.h… yes
checking netinet/in.h usability… yes
checking netinet/in.h presence… yes
checking for netinet/in.h… yes
checking termios.h usability… yes
checking termios.h presence… yes
checking for termios.h… yes
checking for pkg-config… yes
checking pthread.h usability… yes
checking pthread.h presence… yes
checking for pthread.h… yes
checking setjmp.h usability… yes
checking setjmp.h presence… yes
checking for setjmp.h… yes
checking jerror.h usability… yes
checking jerror.h presence… yes
checking for jerror.h… yes
checking jpeglib.h usability… yes
checking jpeglib.h presence… yes
checking for jpeglib.h… yes
checking jpg libraries… yes
checking microhttpd.h usability… no
checking microhttpd.h presence… no
checking for microhttpd.h… no
checking libmicrohttpd libraries… no
configure: error: Required package libmicrohttpd-dev not found, please check motion_guide.html and install necessary dependencies
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target ‹ install ›. Stop.
usermod: group ‹ motion › does not exist
Installation de motion terminé *
