Sans raison ni changement de mes informations d’authentification je n’arrive plus à lancer le démon Meross. Depuis l’application mobile Meross tout fonctionne correctement. Je n’ai pas la double authentification.
Comment résoudre ce problème ?
Cordialement.
Logs :
[2024-07-09 12:30:06][ERROR] : Aucun équipement connecté ou problème de connexion. Merci de consulter la log.
[2024-07-09 10:32:33][ERROR][DemonPython] : ‹ mfaLockExpire ›
[2024-07-09 10:32:33][ERROR][DemonPython] : aSetOn - Device not found 2208026787224851080548e1e99e697c
[2024-07-09 10:32:33][ERROR][DemonPython] : setOn Failed: The provided token has expired
[2024-07-09 10:33:16][ERROR][DemonPython] : ‹ mfaLockExpire ›
[2024-07-09 10:33:16][ERROR][DemonPython] : aSetOn - Device not found 2208026787224851080548e1e99e697c
[2024-07-09 10:33:16][ERROR][DemonPython] : setOn Failed: The provided token has expired
[2024-07-09 10:33:47][ERROR][DemonPython] : ‹ mfaLockExpire ›
[2024-07-09 10:33:47][ERROR][DemonPython] : aSetOn - Device not found 2208026787224851080548e1e99e697c
[2024-07-09 10:33:47][ERROR][DemonPython] : setOn Failed: The provided token has expired
[2024-07-09 10:34:10][ERROR][DemonPython] : ‹ mfaLockExpire ›
[2024-07-09 10:34:10][ERROR][DemonPython] : aSetOn - Device not found 2208026787224851080548e1e99e697c
[2024-07-09 10:34:10][ERROR][DemonPython] : setOn Failed: The provided token has expired
[2024-07-09 10:36:51][ERROR][DemonPython] : ‹ mfaLockExpire ›
[2024-07-09 10:36:51][ERROR][DemonPython] : aSetOn - Device not found 2208026787224851080548e1e99e697c
[2024-07-09 10:36:51][ERROR][DemonPython] : setOn Failed: The provided token has expired
[2024-07-09 10:37:58][ERROR][DemonPython] : ‹ mfaLockExpire ›
‹ mfaLockExpire ›
[2024-07-09 12:38:00][ERROR] : Impossible de lancer le démon meross, vérifiez la log
[2024-07-09 12:40:05][ERROR] : Merci de démarrer le démon !
[2024-07-09 10:40:11][ERROR][DemonPython] : ‹ mfaLockExpire ›
‹ mfaLockExpire ›
