En complément je mets ici un interminable LOG dont, en tant que débutant, j’avoue humblement ne pas savoir quoi faire…
[2020-10-08 20:56:52][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
ValueError: 1004 is not a valid ErrorCodes
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/meross_iot/api.py", line 102, in _authenticated_post
result_code = ErrorCodes(code)
File "/usr/lib/python3.7/enum.py", line 310, in __call__
return cls.__new__(cls, value)
File "/usr/lib/python3.7/enum.py", line 564, in __new__
raise exc
File "/usr/lib/python3.7/enum.py", line 548, in __new__
result = cls._missing_(value)
File "/usr/lib/python3.7/enum.py", line 577, in _missing_
raise ValueError("%r is not a valid %s" % (value, cls.__name__))
raise exc
File "/var/www/html/plugins/MerossIOT/resources/MerossIOTd/MerossIOTd.py", line 467, in <module>
mm = MerossManager.from_email_and_password(args.muser, args.mpswd)
File "/usr/local/lib/python3.7/dist-packages/meross_iot/manager.py", line 21, in from_email_and_password
cloud_creds = MerossHttpClient.login(email=meross_email, password=meross_password)
File "/usr/local/lib/python3.7/dist-packages/meross_iot/api.py", line 48, in login
response_data = cls._authenticated_post(_LOGIN_URL, params_data=data)
File "/usr/local/lib/python3.7/dist-packages/meross_iot/api.py", line 121, in _authenticated_post
raise AuthenticatedPostException("Failed request to API. Response was: %s" % str(jsondata))
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 19:56:52'}
[2020-10-08 21:57:09][ERROR] : Impossible de lancer le démon meross, vérifiez le log
2020-10-08 21:00:07,850 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:00:07][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:00:07'}
[2020-10-08 22:00:25][ERROR] : Impossible de lancer le démon meross, vérifiez le log
[2020-10-08 22:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
2020-10-08 21:05:05,885 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:05:05][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:05:05'}
[2020-10-08 22:06:20][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
2020-10-08 21:06:22,484 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:06:22][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:06:22'}
[2020-10-08 22:06:39][ERROR] : Impossible de lancer le démon meross, vérifiez le log
[2020-10-08 22:10:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
2020-10-08 21:10:06,937 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:10:06][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:10:06'}
[2020-10-08 22:10:23][ERROR] : Impossible de lancer le démon meross, vérifiez le log
[2020-10-08 22:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
2020-10-08 21:15:06,295 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:15:06][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:15:06'}
[2020-10-08 22:15:23][ERROR] : Impossible de lancer le démon meross, vérifiez le log
[2020-10-08 22:20:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
2020-10-08 21:20:07,181 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:20:07][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:20:07'}
[2020-10-08 22:20:24][ERROR] : Impossible de lancer le démon meross, vérifiez le log
[2020-10-08 22:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
2020-10-08 21:25:06,684 - meross.api - ERROR - Unknown/unsupported Value error
raise exc
[2020-10-08 21:25:06][ERROR][meross.api](MainThread) : Unknown/unsupported Value error
raise exc
raise exc
meross_iot.api.AuthenticatedPostException: Failed request to API. Response was: {'apiStatus': 1004, 'sysStatus': 0, 'data': None, 'info': 'A', 'timeStamp': '2020-10-08 20:25:06'}
[2020-10-08 22:25:23][ERROR] : Impossible de lancer le démon meross, vérifiez le log
