Plugin LegrandIoblMyHome demon KO
Suite à l’installation de Debian 11, Boxio ne fonctionnant plus, je viens d’acheter et installer le plugin LegrandIoblMyHome.
Les dépendances sont bien installées et la migration des modules Boxio semble s’être bien déroulée.
Par contre le démon ne se lance pas donc impossible de communiquer avec les modules.
Voici les logs :
0000|usage: LegrandIoblMyhomed.py [-h] [--device DEVICE] [--socketport SOCKETPORT]
0001|[--loglevel LOGLEVEL] [--protocol PROTOCOL]
0002|[--callback CALLBACK] [--apikey APIKEY]
0003|[--cycle CYCLE] [--serialrate SERIALRATE]
0004|[--pid PID] [--sendmsg SENDMSG] [--status STATUS]
0005|[--version VERSION]
0006|LegrandIoblMyhomed.py: error: argument --cycle: expected one argument
0000|********************************************************
0001|*             Installation des dépendances             *
0002|********************************************************
0003|Hit:1 http://deb.debian.org/debian bullseye InRelease
0004|Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
0005|Hit:3 http://security.debian.org bullseye-security InRelease
0006|Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
0007|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0008|Hit:6 http://armbian.tnahosting.net/apt buster InRelease
0009|Reading package lists...
0010|WARNING: Skipping serial as it is not installed.
0011|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
0012|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0013|Reading package lists...
0014|Building dependency tree...
0015|Reading state information...
0016|The following packages will be REMOVED:
0017|python3-serial
0018|0 upgraded, 0 newly installed, 1 to remove and 169 not upgraded.
0019|After this operation, 469 kB disk space will be freed.
0020|(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 63854 files and directories currently installed.)
0021|Removing python3-serial (3.5~b0-1) ...
0022|Reading package lists...
0023|Building dependency tree...
0024|Reading state information...
0025|python3-pip is already the newest version (20.3.4-4+deb11u1).
0026|python3 is already the newest version (3.9.2-3).
0027|python3-pyudev is already the newest version (0.22.0-2).
0028|python3-requests is already the newest version (2.25.1+dfsg-2).
0029|0 upgraded, 0 newly installed, 0 to remove and 169 not upgraded.
0030|Collecting pyserial
0031|Downloading pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB)
0032|Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
0033|Installing collected packages: pyserial
0034|Successfully installed pyserial-3.5
0035|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
0036|Lancement de la synchronisation des templates LegrandIoblMyhome
0037|Changement du répertoire courant
0038|Récupération des templates (cette étape peut durer quelques minutes)
0039|Cloning into 'pluginjeedom-legrandioblmyhomePub'...
0040|Recopie des nouveaux templates LegrandIoblMyhome
0041|Nettoyage du répertoire temporaire
0042|Vos templates sont maintenant à jour !
0043|********************************************************
0044|*             Installation terminée                    *
0045|********************************************************
Informations Jeedom Atlas
Core : 4.4.12 (master)
DNS Jeedom Atlas : oui
Plugin : Legrand IOBL and MyHome
Version : 2024-09-29 20:03:19 (beta)
Statut Démon : Stoppé - (2024-12-14 15:50:02)
Il manquait le nombre dans « cycles »
On peut mettre n’importe quel chiffre : 1 ou 5 ou 10 ou 100… je vois pas la différence…
