je n’arrive pas à installer les dépendances. Je suis sur Raspi4 Buster et jeedom 4.1.16. Je joint les logs :
* Install dependencies *
> Progress file: /tmp/jeedom/kTwinkly/dependencies
Sat Dec 12 13:48:58 CET 2020
* Update package list
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian-security buster/updates InRelease
Hit:4 http://deb.debian.org/debian buster-updates InRelease
Hit:5 https://repos.influxdata.com/debian buster InRelease
Hit:6 https://deb.nodesource.com/node_12.x buster InRelease
Hit:7 https://repository.salamek.cz/deb/pub all InRelease
Ign:8 https://repo.distrib.works/apt InRelease
Ign:9 https://repo.distrib.works/apt Release
Ign:10 https://repo.distrib.works/apt Packages
Ign:11 https://repo.distrib.works/apt Translation-en
Get:10 https://repo.distrib.works/apt Packages
Fetched 5281 B in 2s (2236 B/s)
Reading package lists...
* Remove apt package for mitmproxy
Building dependency tree...
Reading state information...
Package 'mitmproxy' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
* Python 3.7
Python 3.7.3
* Already installed
Python 3.7.3
* Install mitmproxy
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
Collecting mitmproxy
Using cached mitmproxy-5.3.0-py3-none-any.whl (1.1 MB)
Requirement already satisfied: blinker<1.5,>=1.4 in /usr/lib/python3/dist-packages (from mitmproxy) (1.4)
Requirement already satisfied: certifi>=2019.9.11 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2020.6.20)
Requirement already satisfied: protobuf<3.14,>=3.6.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (3.12.2)
Requirement already satisfied: click<8,>=7.0 in /usr/lib/python3/dist-packages (from mitmproxy) (7.0)
Collecting asgiref<3.4,>=3.2.10
Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.3.1-py3-none-any.whl (19 kB)
Using cached Brotli-1.0.9.zip (510 kB)
Collecting cryptography<3.3,>=3.2
Using cached cryptography-3.2.1-cp35-abi3-manylinux2014_aarch64.whl (2.6 MB)
Requirement already satisfied: six>=1.4.1 in /usr/local/lib/python3.7/dist-packages (from cryptography<3.3,>=3.2->mitmproxy) (1.15.0)
Collecting cffi!=1.11.3,>=1.8
Using cached cffi-1.14.4-cp37-cp37m-manylinux2014_aarch64.whl (206 kB)
Collecting flask<1.2,>=1.1.1
Using cached https://www.piwheels.org/simple/flask/Flask-1.1.2-py2.py3-none-any.whl (94 kB)
Requirement already satisfied: itsdangerous>=0.24 in /usr/lib/python3/dist-packages (from flask<1.2,>=1.1.1->mitmproxy) (0.24)
Collecting h2<5,>=4.0
Using cached https://www.piwheels.org/simple/h2/h2-4.0.0-py3-none-any.whl (57 kB)
Collecting hpack<5,>=4.0
Using cached https://www.piwheels.org/simple/hpack/hpack-4.0.0-py3-none-any.whl (32 kB)
Collecting hyperframe<7,>=6.0
Using cached https://www.piwheels.org/simple/hyperframe/hyperframe-6.0.0-py3-none-any.whl (11 kB)
Collecting Jinja2>=2.10.1
Using cached https://www.piwheels.org/simple/jinja2/Jinja2-2.11.2-py2.py3-none-any.whl (127 kB)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/lib/python3/dist-packages (from Jinja2>=2.10.1->flask<1.2,>=1.1.1->mitmproxy) (1.1.0)
Collecting kaitaistruct<0.10,>=0.7
Using cached https://www.piwheels.org/simple/kaitaistruct/kaitaistruct-0.9-py2.py3-none-any.whl (6.9 kB)
Collecting ldap3<2.9,>=2.8
Using cached https://www.piwheels.org/simple/ldap3/ldap3-2.8.1-py2.py3-none-any.whl (423 kB)
Collecting msgpack<1.1.0,>=1.0.0
Using cached msgpack-1.0.1-cp37-cp37m-manylinux2014_aarch64.whl (296 kB)
Collecting passlib<1.8,>=1.6.5
Using cached https://www.piwheels.org/simple/passlib/passlib-1.7.4-py2.py3-none-any.whl (525 kB)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (from protobuf<3.14,>=3.6.0->mitmproxy) (50.3.2)
Collecting publicsuffix2<3,>=2.20190812
Using cached https://www.piwheels.org/simple/publicsuffix2/publicsuffix2-2.20191221-py2.py3-none-any.whl (89 kB)
Collecting pyasn1<0.5,>=0.3.1
Using cached https://www.piwheels.org/simple/pyasn1/pyasn1-0.4.8-py2.py3-none-any.whl (77 kB)
Collecting pycparser
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.20-py2.py3-none-any.whl (112 kB)
Collecting pyOpenSSL<19.2,>=19.1.0
Using cached https://www.piwheels.org/simple/pyopenssl/pyOpenSSL-19.1.0-py2.py3-none-any.whl (53 kB)
Collecting pyparsing<2.5,>=2.4.2
Using cached https://www.piwheels.org/simple/pyparsing/pyparsing-2.4.7-py2.py3-none-any.whl (67 kB)
Collecting pyperclip<1.9,>=1.6.0
Using cached https://www.piwheels.org/simple/pyperclip/pyperclip-1.8.1-py3-none-any.whl (10 kB)
Collecting ruamel.yaml<0.17,>=0.16
Using cached https://www.piwheels.org/simple/ruamel-yaml/ruamel.yaml-0.16.12-py2.py3-none-any.whl (111 kB)
Collecting ruamel.yaml.clib>=0.1.2
Using cached ruamel.yaml.clib-0.2.2-cp37-cp37m-manylinux2014_aarch64.whl (538 kB)
Collecting sortedcontainers<2.3,>=2.1
Using cached https://www.piwheels.org/simple/sortedcontainers/sortedcontainers-2.2.2-py2.py3-none-any.whl (29 kB)
Collecting urwid<2.2,>=2.1.1
Using cached urwid-2.1.2.tar.gz (634 kB)
Collecting Werkzeug>=0.15
Using cached https://www.piwheels.org/simple/werkzeug/Werkzeug-1.0.1-py2.py3-none-any.whl (298 kB)
Collecting wsproto<0.16,>=0.14
Using cached https://www.piwheels.org/simple/wsproto/wsproto-0.15.0-py2.py3-none-any.whl (24 kB)
Collecting h11>=0.8.1
Using cached https://www.piwheels.org/simple/h11/h11-0.11.0-py2.py3-none-any.whl (54 kB)
Collecting zstandard<0.15,>=0.11
Using cached zstandard-0.14.1.tar.gz (676 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'error'
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3.7 /usr/local/lib/python3.7/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-7wj3bai3/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=40.8.0' wheel
cwd: None
Complete output (14 lines):
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.7/dist-packages/pip/__main__.py", line 23, in <module>
from pip._internal.cli.main import main as _main # isort:skip # noqa
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/main.py", line 5, in <module>
import locale
File "/usr/lib/python3.7/locale.py", line 16, in <module>
import re
File "/usr/lib/python3.7/re.py", line 143, in <module>
class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
ERROR: Command errored out with exit status 1: /usr/bin/python3.7 /usr/local/lib/python3.7/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-7wj3bai3/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=40.8.0' wheel Check the logs for full command output.
Sat Dec 12 13:49:37 CET 2020
* End dependencies Installation *
Merci par avance pour votre aide.
