Je suis actuellement avec la version 2020-12-07 13:19:10 du plugin et j’ai toujours le même soucis de lancement de mitmproxy.
[2020-12-07 20:21:08][DEBUG] : Tentative de démarrage de mitmproxy
[2020-12-07 20:21:08][DEBUG] : Démarre mitmproxy pour eqId=331
[2020-12-07 20:21:08][DEBUG] : is_mitm_running appelé sans PID
[2020-12-07 20:21:08][DEBUG] : Start MITM command = mitmdump -p 14233 -s /var/www/html/plugins/kTwinkly/core/class/../../resources/mitmdump/twinkly_v2.py --set filename=/tmp/jeedom/kTwinkly/tmovie_331 --set ipaddress=192.168.1.97 --set confdir=/tmp/jeedom/kTwinkly --confdir=/tmp/jeedom/kTwinkly
[2020-12-07 20:21:11][DEBUG] : is_mitm_running appelé avec PID=706
[2020-12-07 20:21:11][ERROR] : Impossible de démarrer mitmproxy. Vérifiez l'installation des dépendances ou un éventuel mesage d'erreur : Traceback (most recent call last): File "/usr/bin/mitmdump", line 11, in <module> load_entry_point('mitmproxy==4.0.4', 'console_scripts', 'mitmdump')() File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 490, in load_entry_point return get_distribution(dist).load_entry_point(group, name) File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 2859, in load_entry_point return ep.load() File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 2450, in load return self.resolve() File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 2456, in resolve module = __import__(self.module_name, fromlist=['__name__'], level=0) File "/usr/lib/python3/dist-packages/mitmproxy/tools/main.py", line 22, in <module> from ._main import * # noqa File "/usr/lib/python3/dist-packages/mitmproxy/tools/_main.py", line 13, in <module> from mitmproxy.tools import cmdline # noqa File "/usr/lib/python3/dist-packages/mitmproxy/tools/cmdline.py", line 3, in <module> from mitmproxy.addons import core File "/usr/lib/python3/dist-packages/mitmproxy/addons/__init__.py", line 11, in <module> from mitmproxy.addons import onboarding File "/usr/lib/python3/dist-packages/mitmproxy/addons/onboarding.py", line 2, in <module> from mitmproxy.addons.onboardingapp import app File "/usr/lib/python3/dist-packages/mitmproxy/addons/onboardingapp/app.py", line 13, in <module> class Adapter(tornado.wsgi.WSGIAdapter): AttributeError: module 'tornado.wsgi' has no attribute 'WSGIAdapter'
[2020-12-07 20:22:05][DEBUG] : is_mitm_running appelé sans PID
[2020-12-07 20:22:58][DEBUG] : Tentative de démarrage de mitmproxy
[2020-12-07 20:22:58][DEBUG] : Démarre mitmproxy pour eqId=331
[2020-12-07 20:22:58][DEBUG] : is_mitm_running appelé sans PID
[2020-12-07 20:22:58][DEBUG] : Start MITM command = mitmdump -p 14233 -s /var/www/html/plugins/kTwinkly/core/class/../../resources/mitmdump/twinkly_v2.py --set filename=/tmp/jeedom/kTwinkly/tmovie_331 --set ipaddress=192.168.1.97 --set confdir=/tmp/jeedom/kTwinkly --confdir=/tmp/jeedom/kTwinkly
[2020-12-07 20:23:01][DEBUG] : is_mitm_running appelé avec PID=6221
[2020-12-07 20:23:01][ERROR] : Impossible de démarrer mitmproxy. Vérifiez l'installation des dépendances ou un éventuel mesage d'erreur : Traceback (most recent call last): File "/usr/bin/mitmdump", line 11, in <module> load_entry_point('mitmproxy==4.0.4', 'console_scripts', 'mitmdump')() File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 490, in load_entry_point return get_distribution(dist).load_entry_point(group, name) File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 2859, in load_entry_point return ep.load() File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 2450, in load return self.resolve() File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 2456, in resolve module = __import__(self.module_name, fromlist=['__name__'], level=0) File "/usr/lib/python3/dist-packages/mitmproxy/tools/main.py", line 22, in <module> from ._main import * # noqa File "/usr/lib/python3/dist-packages/mitmproxy/tools/_main.py", line 13, in <module> from mitmproxy.tools import cmdline # noqa File "/usr/lib/python3/dist-packages/mitmproxy/tools/cmdline.py", line 3, in <module> from mitmproxy.addons import core File "/usr/lib/python3/dist-packages/mitmproxy/addons/__init__.py", line 11, in <module> from mitmproxy.addons import onboarding File "/usr/lib/python3/dist-packages/mitmproxy/addons/onboarding.py", line 2, in <module> from mitmproxy.addons.onboardingapp import app File "/usr/lib/python3/dist-packages/mitmproxy/addons/onboardingapp/app.py", line 13, in <module> class Adapter(tornado.wsgi.WSGIAdapter): AttributeError: module 'tornado.wsgi' has no attribute 'WSGIAdapter'
[2020-12-07 20:23:18][DEBUG] : is_mitm_running appelé sans PID
Je n’ai pas noté de « longueur » à l’installation du plugin ou des dépendances alors que je suis sur raspberry pi3… (pas sur que la mise à jour ai été poussée sur le market)
