J’utilise le plugin kroomba depuis plusieurs mois sans aucun probleme, mais depuis une semaine je n’ai plus de retour d’état et je ne peux plus lancer aucune commande.
Voici une partie du log:
[2020-12-04 10:26:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:26:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 10:30:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 10:31:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:31:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 10:35:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 10:36:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:36:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 10:40:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 10:41:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:41:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 10:45:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 10:46:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:46:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 10:50:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 10:51:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:51:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 10:55:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 10:56:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 10:56:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:00:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:01:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:01:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:05:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:06:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:06:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:10:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:11:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:11:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:15:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:16:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:16:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:20:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:21:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:21:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:25:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:26:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:26:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:30:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:31:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:31:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:35:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:36:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:36:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:40:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:41:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:41:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:45:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:46:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:46:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:50:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:51:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:51:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 11:55:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 11:56:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 11:56:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:00:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:01:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:01:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:05:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:06:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:06:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:10:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:11:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:11:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:15:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:16:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:16:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:20:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:21:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:21:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:25:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:26:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:26:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:30:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:31:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:31:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:35:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:36:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:36:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:40:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:41:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:41:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:45:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:46:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:46:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:50:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:51:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:51:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 12:55:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 12:56:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 12:56:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:00:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:01:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:01:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:05:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:06:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:06:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:10:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:11:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:11:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:15:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:16:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:16:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:20:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:21:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:21:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:25:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:26:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:26:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:30:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:31:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:31:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:35:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:36:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:36:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:40:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:41:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:41:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:45:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:46:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:46:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:50:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:51:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:51:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 13:55:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 13:56:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 13:56:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:00:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:01:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:01:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:05:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:06:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:06:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:10:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:11:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:11:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:15:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:16:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:16:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:20:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:21:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:21:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:25:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:25:40][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py start "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:25:50][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py start "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:26:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:26:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:26:14][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py start "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:26:40][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:26:44][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:26:50][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:26:54][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:27:15][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:27:19][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:27:45][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:27:45][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:27:55][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:27:55][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:28:19][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:28:19][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:30:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:31:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:31:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:35:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:36:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:36:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:40:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:41:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:41:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:45:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:46:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:46:04][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:50:02][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:51:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:51:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:55:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:56:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:56:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 14:58:19][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py stop "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:58:29][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py pause "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:59:05][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py pause "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:59:19][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:59:23][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 14:59:29][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 14:59:33][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:00:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:00:05][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:00:09][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:00:24][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:00:24][DEBUG] : Wrong answer : Array ( )
[2020-12-04 15:00:26][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:00:34][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:00:34][DEBUG] : Wrong answer : Array ( )
[2020-12-04 15:01:03][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:01:03][DEBUG] : Wrong answer : Array ( )
[2020-12-04 15:01:10][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:01:10][DEBUG] : Wrong answer : Array ( )
[2020-12-04 15:01:15][DEBUG] : Action : discover
[2020-12-04 15:01:15][DEBUG] : myDiscover
[2020-12-04 15:01:15][DEBUG] : Discover
[2020-12-04 15:01:26][DEBUG] : Discover Results :IP:192.168.1.82,blid:3192C22091021760
[2020-12-04 15:01:26][DEBUG] : Discover Result :IP:192.168.1.82,blid:3192C22091021760
[2020-12-04 15:01:26][DEBUG] : Discover ip :192.168.1.82
[2020-12-04 15:01:26][DEBUG] : Discover blid :3192C22091021760
[2020-12-04 15:01:27][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:01:27][DEBUG] : Wrong answer : Array ( )
[2020-12-04 15:02:13][DEBUG] : Send command : cd /var/www/html/plugins/kroomba/resources && python3 roombaCmd.py pause "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:03:14][DEBUG] : Send command result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:03:18][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:04:18][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:04:18][DEBUG] : Wrong answer : Array ( )
[2020-12-04 15:05:03][DEBUG] : Mission command : cd /var/www/html/plugins/kroomba/resources && python3 roombaStatus.py "192.168.1.82" "3192C22091021760" "****"
[2020-12-04 15:06:04][DEBUG] : Mission raw result : Array ( [0] => Error: timed out [1] => CV or numpy module not found, falling back to PIL [2] => PIL module not found, maps are disabled )
[2020-12-04 15:06:04][DEBUG] : Wrong answer : Array ( )
Version de Jeedom : 4.0.61
Roomba modèle 980
Je n’ai pas toucher à jeedom depuis plus d’une semaine donc pas possible ça soit une manip ou une mise à jou.
Si quelqu’un peut aider.
