Je viens de recevoir mon KLF-200 Velux afin de commander mes fenêtres de toit Velux.
La reconnaissance des Velux (via les télécommandes actuelles se sont bien déroulées).
Par contre le lancement des dépendances échoue systématiquement
attention : http:// est remplacé par web// ci-dessous pour contourner l’impossibilité d’ajouter plus de deux liens dans
12/12/2023 23:23:14 Installation des dépendances
Hit:1 web//phoscon.de/apt/deconz buster InRelease
Get:2 web//raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 web//archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Reading package lists...
E: Repository 'web//raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'web//archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
Installation des dépendances apt
Building dependency tree...
Reading state information...
python3-dev is already the newest version (3.7.3-1).
The following additional packages will be installed:
libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
python3.7 python3.7-dev python3.7-minimal python3.7-venv
Suggested packages:
python3.7-doc binfmt-support
python3-venv python3.7-venv
The following packages will be upgraded:
7 upgraded, 2 newly installed, 0 to remove and 283 not upgraded.
Need to get 53.0 MB/53.0 MB of archives.
After this operation, 117 kB of additional disk space will be used.
Err:1 web//raspbian.raspberrypi.org/raspbian buster/main armhf python3.7-dev armhf 3.7.3-2+deb10u5
404 Not Found [IP: 93.93.128.193 80]
Err:2 web//raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7-dev armhf 3.7.3-2+deb10u5
Err:3 web//raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7 armhf 3.7.3-2+deb10u5
Err:4 web//raspbian.raspberrypi.org/raspbian buster/main armhf python3.7 armhf 3.7.3-2+deb10u5
Err:5 web//raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7-stdlib armhf 3.7.3-2+deb10u5
Err:6 web//raspbian.raspberrypi.org/raspbian buster/main armhf python3.7-minimal armhf 3.7.3-2+deb10u5
Err:7 web//raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7-minimal armhf 3.7.3-2+deb10u5
Err:8 web//raspbian.raspberrypi.org/raspbian buster/main armhf python3.7-venv armhf 3.7.3-2+deb10u5
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-dev_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-dev_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-stdlib_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-minimal_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-minimal_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch web//raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-venv_3.7.3-2+deb10u5_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
The virtual environment was not created successfully because ensurepip is not
available. On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
apt-get install python3-venv
You may need to use sudo with that command. After installing the python3-venv
package, recreate your virtual environment.
Failing command: ['/var/www/html/plugins/klf200/resources/venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
/var/www/html/plugins/klf200/resources/install.sh: line 17: /var/www/html/plugins/klf200/resources/venv/bin/pip3: No such file or directory
/var/www/html/plugins/klf200/resources/install.sh: line 20: /var/www/html/plugins/klf200/resources/venv/bin/pip3: No such file or directory
/var/www/html/plugins/klf200/resources/install.sh: line 23: /var/www/html/plugins/klf200/resources/venv/bin/pip3: No such file or directory
/var/www/html/plugins/klf200/resources/install.sh: line 26: /var/www/html/plugins/klf200/resources/venv/bin/pip3: No such file or directory
12/12/2023 23:23:24 Installation terminée
J’ai cherché sur le forum. Des sujets de dépendances existent mais ne semblent pas correcpondre à mon problème…
