Bonjour, merci pour votre réponse.
Voici le haut de la partie santé :
voici le log d’installation des dépendances :
* Installation des dépendances *
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
Reading package lists...
Building dependency tree...
Reading state information...
python3-pip is already the newest version.
python3-dev is already the newest version.
The following package was automatically installed and is no longer required:
linux-headers-3.14.29+
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
python3-pkg-resources
Suggested packages:
python-setuptools-doc
The following packages will be upgraded:
python3-pkg-resources python3-setuptools
2 upgraded, 0 newly installed, 0 to remove and 179 not upgraded.
Need to get 353 kB of archives.
After this operation, 695 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
python3-setuptools python3-pkg-resources
E: There are problems and -y was used without --force-yes
File "/usr/bin/pip3", line 9, in <module>
load_entry_point('pip==1.5.6', 'console_scripts', 'pip3')()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 356, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2476, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2190, in load
['__name__'])
File "/usr/lib/python3/dist-packages/pip/__init__.py", line 74, in <module>
from pip.vcs import git, mercurial, subversion, bazaar # noqa
File "/usr/lib/python3/dist-packages/pip/vcs/mercurial.py", line 9, in <module>
from pip.download import path_to_url
File "/usr/lib/python3/dist-packages/pip/download.py", line 25, in <module>
from requests.compat import IncompleteRead
ImportError: cannot import name 'IncompleteRead'
return ep.load()
['__name__'])
return ep.load()
['__name__'])
return ep.load()
['__name__'])
* Installation terminée *
j’ai la Smart box Jeedom.
je vous remercie beaucoup.
