Salut @Flobul . Je n’ai pas trouvé le tag plugin-gkeep. Je suis les étapes mais la boîte à jetons n’apparaît pas. Merci.
[2023-07-26 20:42:13]DEBUG : login : __AT__début
[2023-07-26 20:42:13]DEBUG : __AT__Commande envoyée : sudo /var/www/html/plugins/gkeep/core/class/../../resources/venv/bin/python3 /var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py --username xxxxxxx@gmail.com save_master_token --password xxxxxxx
[2023-07-26 20:42:14]DEBUG : sendCmdAndFormatResult : __AT__Résultat brut
[2023-07-26 20:42:14]INFO : sendCmdAndFormatResult : __AT__Résultat array null
[2023-07-26 20:42:14]WARNING : Erreur lors de l'exécution de la commande : --username xxxxxxx@gmail.com save_master_token --password xxxxxxx
* Launch install of dependencies *
Mon Jul 24 13:48:47 CEST 2023
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 https://deb.nodesource.com/node_14.x bullseye InRelease
Hit:3 http://ftp.es.debian.org/debian bullseye InRelease
Hit:4 http://ftp.es.debian.org/debian bullseye-updates InRelease
Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Reading package lists...
Install modules using apt-get
Building dependency tree...
Reading state information...
python3-pip is already the newest version (20.3.4-4+deb11u1).
python3 is already the newest version (3.9.2-3).
python3-venv is already the newest version (3.9.2-3).
python3-requests is already the newest version (2.25.1+dfsg-2).
python3-setuptools is already the newest version (52.0.0-4).
The following package was automatically installed and is no longer required:
linux-image-5.10.0-20-amd64
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
Creating python 3 virtual environment
Done
Install the required python libraries
Requirement already satisfied: pip in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (23.2.1)
Requirement already satisfied: wheel in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (0.41.0)
Requirement already satisfied: urllib3<2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (1.26.16)
Requirement already satisfied: keyring in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (24.2.0)
Requirement already satisfied: jaraco.classes in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from keyring) (3.3.0)
Requirement already satisfied: importlib-metadata>=4.11.4 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from keyring) (6.8.0)
Requirement already satisfied: SecretStorage>=3.2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from keyring) (3.3.3)
Requirement already satisfied: jeepney>=0.4.2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from keyring) (0.8.0)
Requirement already satisfied: zipp>=0.5 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from importlib-metadata>=4.11.4->keyring) (3.16.2)
Requirement already satisfied: cryptography>=2.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from SecretStorage>=3.2->keyring) (41.0.2)
Requirement already satisfied: more-itertools in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from jaraco.classes->keyring) (9.1.0)
Requirement already satisfied: cffi>=1.12 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from cryptography>=2.0->SecretStorage>=3.2->keyring) (1.15.1)
Requirement already satisfied: pycparser in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from cffi>=1.12->cryptography>=2.0->SecretStorage>=3.2->keyring) (2.21)
Requirement already satisfied: keyrings.alt in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (5.0.0)
Requirement already satisfied: jaraco.classes in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from keyrings.alt) (3.3.0)
Requirement already satisfied: more-itertools in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from jaraco.classes->keyrings.alt) (9.1.0)
Requirement already satisfied: gkeepapi in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (0.14.2)
Requirement already satisfied: future>=0.16.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from gkeepapi) (0.18.3)
Requirement already satisfied: gpsoauth>=1.0.2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from gkeepapi) (1.0.2)
Requirement already satisfied: pycryptodomex>=3.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from gpsoauth>=1.0.2->gkeepapi) (3.18.0)
Requirement already satisfied: requests>=2.0.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from gpsoauth>=1.0.2->gkeepapi) (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from requests>=2.0.0->gpsoauth>=1.0.2->gkeepapi) (3.2.0)
Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from requests>=2.0.0->gpsoauth>=1.0.2->gkeepapi) (3.4)
Requirement already satisfied: urllib3<3,>=1.21.1 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from requests>=2.0.0->gpsoauth>=1.0.2->gkeepapi) (1.26.16)
Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.9/site-packages (from requests>=2.0.0->gpsoauth>=1.0.2->gkeepapi) (2023.7.22)
Mon Jul 24 13:48:54 CEST 2023
* Install ended *
