J’ai cette erreur au démarrage du démon, des conseils ? Je sais que c’est un plugin abandonné
/usr/bin/python3 /var/www/html/plugins/googlecast/resources/googlecast.py --loglevel debug --socketport 55012 --sockethost 127.0.0.1 --callback http://127.0.0.1:80/plugins/googlecast/core/php/googlecast.api.php --apikey xxxxxxxxxxxxxxxxxx --ttsweb http://192.168.1.37 --ttslang es-ES --ttsengine picotts --ttsspeed 1.2 --ttscache 1 --ttsgapikey none --gcttsvoice fr-FR-Standard-A --ttsdefaultrestoretime 1300 --ttsdefaultsilenceduration 300 --daemonname local --cyclefactor 1 --defaultstatus ' '
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 45, in <module>
import pychromecast.pychromecast as pychromecast
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/__init__.py", line 14, in <module>
from . import socket_client
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 23, in <module>
from . import cast_channel_pb2
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/cast_channel_pb2.py", line 36, in <module>
type=None),
File "/usr/local/lib/python3.7/dist-packages/google/protobuf/descriptor.py", line 796, in __new__
_message.Message._CheckCalledFromGeneratedFile()
TypeError: Descriptors cannot not be created directly.
If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.19.0.
If you cannot immediately regenerate your protos, some other possible workarounds are:
1. Downgrade the protobuf package to 3.20.x or lower.
2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slower).
