Ce ne sont que des « warning » dans la log « cron_execution ». A priori, ça ne gène pas la bon fonctionnement du plugin
PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576
PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576
PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576
PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576
et dans la log « http.error »
[Thu Sep 12 07:37:47.348273 2024] [php:warn] [pid 296805:tid 296805] [client 192.168.1.119:59702] PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 07:37:47.348307 2024] [php:warn] [pid 296805:tid 296805] [client 192.168.1.119:59702] PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 07:37:47.348468 2024] [php:warn] [pid 296805:tid 296805] [client 192.168.1.119:59702] PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 07:37:47.348478 2024] [php:warn] [pid 296805:tid 296805] [client 192.168.1.119:59702] PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 12:22:13.061122 2024] [php:warn] [pid 377101:tid 377101] [client 192.168.1.119:60228] PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576, referer: http://192.168.1.62/index.php?v=d
[Thu Sep 12 12:22:13.061148 2024] [php:warn] [pid 377101:tid 377101] [client 192.168.1.119:60228] PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576, referer: http://192.168.1.62/index.php?v=d
[Thu Sep 12 12:22:13.061291 2024] [php:warn] [pid 377101:tid 377101] [client 192.168.1.119:60228] PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576, referer: http://192.168.1.62/index.php?v=d
[Thu Sep 12 12:22:13.061300 2024] [php:warn] [pid 377101:tid 377101] [client 192.168.1.119:60228] PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576, referer: http://192.168.1.62/index.php?v=d
[Thu Sep 12 12:22:13.211479 2024] [php:warn] [pid 296799:tid 296799] [client 192.168.1.119:60230] PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 12:22:13.211521 2024] [php:warn] [pid 296799:tid 296799] [client 192.168.1.119:60230] PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareTrait.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 12:22:13.211628 2024] [php:warn] [pid 296799:tid 296799] [client 192.168.1.119:60230] PHP Warning: include(/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/ClassLoader.php on line 576
[Thu Sep 12 12:22:13.211636 2024] [php:warn] [pid 296799:tid 296799] [client 192.168.1.119:60230] PHP Warning: include(): Failed opening '/var/www/html/plugins/fully_kiosk/vendor/composer/../psr/log/src/LoggerAwareInterface.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/ClassLoader.php on line 576
Je pense que les messages apparaissent dans la log « http.error » à chaque fois que je passe sur le dashboard. Par contre, pour la log « cron_execution », je pense que c’est à chaque fois que l’équipement se refresh.
